#26 |
Re: 55-1 S-10 Chassis Swap
This a before and after the after is with the ZQ8 rear leaf springs wich brought the back end down 1 1/4 inches and axle relocated 1 inch forward
#27 |
And another of the hood orniment I got and a little practice with some clear coat
#28 |
Been awhile since I've had an up date yesterday I ruff mounted my RPC steering colum I got off ebay I used the original colum mounts for the dash and got a reproduction floor mount/rubber piece for the floor my computer would only post 1 pic I will try to put up the other 2
#29 |
Well maybe I won't up load any more pictures I get this pop up thing saying I'm missing a securety token, I have no idea what that means
#30 |
Alright figured out another way to post pictures (with my phone ) the one pic shows the how the original column mount under the dash and the one at the floor board is more of a seal and just keeps the column from moving around I just don't know if I should leave it as it is I kinda don't fell like it would be strong enough although there is metal in the rubber should I scrap that and put a brace of some kind any opinions would be appreciated
#31 |
This is a picture of the plate I welded onto my column. This gets bolted through the firewall.
http://67-72chevytrucks.com/vboard/s...s10+frame+swap |
#32 |
![]() Join Date: Aug 2008
I will follow along as i too have a 55 1st and the EZ Chassis swap kit. That project got put on the back burner to finish a 72 cheyenne swb my dad started.
Fu ny thing, i had a set of wheels like yours (after researching they were Z28, there are differences) that i thought about running, but sold them for a tidy profit. I picked up some slot mags instead. I am going to be running a 4.3 v6 in mine for the time being, since i have it already, but dream of an ls swap someday. |
#33 |
I forgot to ask. What is the purpose of the tubular a arms? Does it space the wheels out any further than stock?
#34 |
Just changed to tubular control arms because they look better and they came with new bushings and ball joints
#35 |
Alright I hope the pictures uploaded finally got som color going on
#36 |
![]() Join Date: May 2007
thats a great color!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#37 |
Thanks it's called Bahama Green my wife picked it out
#38 |
I've noticed that the axle is a little bit too far back on some S10 builds too. Where you moved your's to looks perfect. How did you relocated your axle 1-1/2 forward? I was thinking of using solid lowering blocks and simply drilling the hole in the bottom of the block off center to relocate the axle.
#39 |
That would work I used what came the E-Z chassis swap which could be a 1/4 block with off set hole
#40 |
About ready to sell this stupid truck trying to align the dang stoker plates has got me so aggravated
#41 |
Finally got my all aluminum L33 ls motor, just got to get it cleaned up anyone know of a way to make the aluminum look new
#42 |
Happy happy happy got my doors to close big thanks to Kevin at American Metal in Diboll Tx took him maybe 30 minutes now for the wind lace
#43 |
Put my door handles back on with matching locks
#44 |
And put new rollers on the window regulators for some reason I can't post more than 1 picture at a time would have got more done today but I forgot my cordless drill at home
#45 | |
Or an old trick for stripping anodizing from aluminum is EZ OFF oven cleaner. Dont leave it on for HOURS , just about 15-20 minutes does the trick. If you can warm them it works quicker. Then just take a medium 3M scotchbrite pad to them. I do this on all my old AN fittings that I buy in red blue black and make them look like polished alum again.... works great.
My Build: 57 Chevy Pro-Street |
#46 |
Love the build!!! Also, can I bug you to share a bit more info on the steering column? That is one good looking setup! What are all of the specs required to get one like this. I like it in plain steel, for a floor shift with a key? Also is it a 28" or a 30" thanks!
#47 |
Thanks ptc do I wipe off the easy off or wash it off
Steve Aleve I don't remember if the column is a 30 or 32 inch but either length should work for a floor shift but I don't think I will end up using it, I got it off ebay not a bad price if I remember, but once I put it together and installed it, the ignition switch would turn without a key in it, so my bud who is a locksmith put a new tumbler in it and that fixed that, then I noticed that I could shift gears with the ignition locked not good I don't know if I just install the shift lever in correctly, or if it is defective, if your going with a floor shifter I would get one, it's RPC brand Chinese made but unless I can get it squared away I will probly just use the S 10 column |
#48 |
Truck is hold now all the money I had to finish it is going to have to buy me another daily driver dang:buh I'm gonna miss that dang Jimmy the inside is almost brand new
#49 |
Yea just wash it off with soapy water. I havent used it on the satin finish before so try it on a small area first.
#50 |
Well for some reason I can only post 1 picture at a time so this is 1 of 2 wraps I installed this weekend, this the before and the nice part about this install, was I did it in the kitchen so I could watch tv at the same time
