02-27-2014, 01:04 PM | #26 |
Re: Bought my grandpa's 72 C10
Love it !!! I have my Great Grandfathers '59 GMC 100 and its been in the Schrum family for 3 Generations so far
1971 GMC Sierra 1959 GMC 100 |
02-27-2014, 02:11 PM | #27 |
8 vehicles only 4 that run
First goal is to get her running again. I have ordered a new fuel tank, sending unit, and fuel pump. I don't feel like trying to clean varnish and crap out of the fuel system. Cleaning the carb was like playing in black pine sap. I will spray and blow out the metal lines. I also have new plugs, a cap, rotor and coil coming.
95 2500 350 w/ 3.73 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
02-27-2014, 02:23 PM | #28 |
Florida Edition
This is going to be a great truck, congrats!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
02-27-2014, 10:16 PM | #29 |
Old member
I have my old tank still. I don't know what it looks like now on the inside since it's been sitting under the house for 15 years, but it was working fine when I removed it. You would have been welcome to have it if you needed it.
02-28-2014, 01:45 AM | #30 |
Thanks for the offer! I didn't mind splurging on a new tank. I think the old gals earned a new one. I figure if the truck has 143k miles and got 12mpg, then that's 11,900 gallons of fuel that's been through the system! You working right now? We are on days, I may stop in upstairs this morning a say hi if so.
02-28-2014, 01:47 AM | #31 |
Old member
Yep I'm here.
04-14-2014, 05:11 PM | #32 |
Well in the last two weeks, I changed the rear wheel cylinders, hard lines, brake hose, shoes, hardware and master cylinder. I replaced the front calipers, pads, hoses and repaired a hardline.
I replaced the fuel tank, sending unit, and hoses with all new. I had to get a cap for a 68, because the 72 one wouldn't fit (new EEC tank from RockAuto). The old tank had already sent about 2 tablespoons of rust to the fuel filter with only 10-20 minutes of running. I also installed a new fuel filler grommet. New filter after 20 minutes on old tank..... I removed the carpet while the seat was out along with the seatbelts and gave them a brief cleaning. I por15'd the bare floor to slow the rust. The bottom groove of the floor was rotted away down the drivers side gasket channel and the wires were visible and exposed to the rear of the cab. I put some convoluted tubing/wire loom around those wires and it sat perfectly down in the portions of channel that were still there and protected the wires a little better. I am currently going to rock the half torn highlander seat cover as is for a while. I am currently chasing a high idle problem on the qjet. When I rebuilt the carb, I lost one of the 43B needles and put a set in out of a random qjet, so that may be causing the high idle. When I force the throttle lever toward closed, the idle drops. I have replacement 43B needles on the way. I am also going to make sure the choke is working right. I installed a Grant wood steering wheel. I removed the hideous camper cover.
04-21-2014, 06:16 AM | #33 |
Did a quick and dirty needle repaint, lens cleaning and replaced bulbs with LED's.
On a different note, it really sucks when you start your truck up at 4:45AM to go to work and your Grant steering wheel horn cover blows off, instantly grounding your horn plate out for all the neighbors enjoyment......
04-21-2014, 12:06 PM | #34 |
Had the horn pop off on my truck 3 different times in the middle of the night before i gave up on it being right, even with a new horn kit.. My neighbors weren't too happy ether.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-21-2014, 12:54 PM | #35 |
Love the truck man, makes me miss my Pawpaws '71 Gmc Sierra..still looking for it
But I have his '59 Gmc 100 that I am working on, trying to get it running correctly
04-24-2014, 04:14 AM | #36 |
Guess what happened at 330am this morning? I got to do the tighty-whitey sprint outside from a nice dead sleep. I've read some threads on fixing the problem by removing the spring and using foam pads behind the fiber plate. We'll see.
04-24-2014, 08:38 AM | #37 |
Nice score man, look forward to seeing you get it going good (without having to do the 0330 tighty-whitey sprint). Really digging the seat covers, that's the one thing that my truck lacks, is a proper colored seat. I'm running an oxblood red bench from a 90 GMC in my blue truck.
One big heads up, when it comes time, order your carpet from RockAuto. They carry ACC carpets, and the top of the line carpet kit for my truck was around 140. From ACC it was arouund 350. Can't beat the deal, and the part numbers were the same! Oh yeah, GO GAMECOCKS!
1955 Chevy 3100 Task Force Pro Street - Sold! 1957 Chevy 3100 Task Force "Rat Rod" a.k.a. SLOTH - Sold! 1971 C10 Longbed factory A/C all stock 350/350 1979 Jeep CJ7 - Build date on the day I was born! -Keeper 2004 Expedition - Family Hauler 2007 Accord - Wife's around towner; I have more but not enough lines to post them! |
04-24-2014, 08:52 AM | #38 | |
Go Tigers! The wife and I are both 2004 grads.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-26-2014, 07:02 AM | #39 |
Looks like I will be installing those wheel bearings and seals I bought over a month ago. I put it off when I did the brakes a couple of weeks ago. I'm pretty sure I've been hearing some bearing noise when coasting, but this confirms it. Grease is heating up and oozing out of the bearing cap and getting slung onto the wheel.
