05-01-2014, 02:15 AM | #26 |
Re: 20" wheels in a 47-54 chevy truck
05-01-2014, 02:35 PM | #27 |
Thank you for this info. I also plan to run 255/35/20 tires and did not want to tub the bed. You just made my anxiety vanish!
1949 Five Window, 1973 Step Side, 2000 Z71 |
05-01-2014, 03:01 PM | #28 |
05-01-2014, 03:59 PM | #29 |
Looks like your truck is coming along nicely.
05-01-2014, 10:55 PM | #30 |
Few more pictures of my 20's.
05-01-2014, 11:17 PM | #31 |
Seriously you suck!!! Rubbing that in our faces! What rear axle do you have? I'm in the process of buying one and yours looks like something that I would like on my '52.
05-02-2014, 12:03 AM | #32 | |
I'm using a late 60's early 70's Ford 9" someone told me it may be out of a Grand Torino.(The 9" came with the truck and I did not know anything when I installed it to my pickup). It's really to short. It's 60" hub to hub, but I'm using 1 1/4" spacers because the rear end is not wide enough. Try to find something a little wider. I think stock width is around 65 hub to hub. This way you have the room to get a deep offset. Most wheels have a deep offset. I could not have a deep offset so I had to go with a truck wheel and I was limited for choices. I ended up getting lucky and finding what I was looking for, but with a wider rear end you will have more choices for wheels. |
05-02-2014, 10:00 AM | #33 |
Correct me if I am wrong, but isn't the stock width of the rear axle on 47-54 / 60" wide from hub/mounting surface to hub/mounting surface. I seem to remember telling the guys who built my Ford 9" that it was 60".
I do know my rear mounting surface is 8 1/2" out from the frame rail. When taking measurements for wheels, I thought the 60" was a good length and placed the mounting surface right where I needed it. |
05-02-2014, 10:34 AM | #34 | |
05-02-2014, 03:06 PM | #35 | |
http://www.crankshaftcoalition.com/w...rements#GM_car http://www.teufert.net/other/rear%20...dimensions.htm I have a 74 Nova rear in mine (about 60") - basically the same as stock. I suppose if you were to use some modern wheels (like off some contemporary trucks) that have 6'" or greater backspace, a wider axle could work - depends what your program is... |
05-02-2014, 06:26 PM | #36 | |
08-02-2014, 09:57 AM | #37 | |
If anyone else has or is running this combination I would appreciate any info. Thanks |
08-02-2014, 11:01 AM | #38 |
Look around there are not as many options for wheels with 20's and the offset that will work. Took me a while but I found them
08-02-2014, 11:17 AM | #39 |
Thanks for the reply, It seems like the only option is the Fuel Offroad wheels especially for the price. I also am leaning towards the Fuel Dune wheels. You say your control arms are 5/8 shorter? What mustang ll are you running? Did the 20x9 wheels work? How much room between the front tire and fender lip?
08-02-2014, 12:14 PM | #40 | |
08-18-2014, 09:32 PM | #41 |
08-18-2014, 09:48 PM | #42 |
That's sharp looking but I'm really looking for the pro street look with a 20 x 12 -44 offset rear with a 345/35/20 wheel. Those $500 each...ouch. The front are 20 x 9 +20 offset with a 245/35/20.
Just ordered the wheels so in about 6-8 weeks I should be able to mock it up to get the Ford 9 inch narrowed. Another 2 weeks for that too. A big waiting game. I'll post a pic of the mock up so you can see. |
01-30-2019, 03:55 PM | #43 |
01-30-2019, 03:56 PM | #44 |
01-30-2019, 04:46 PM | #45 |
s10 frame, stock s10 rearend. lowered 4/4. 20x8 4" backspace 245/45/20 and 20x9 3.5" backspace 275/45/20. they ride great, not stiff at all. they have a fair amount of road noise but its getting less the more I drive it.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
01-31-2019, 12:00 PM | #46 |
Ricos54,
So, what did your backspace turn out to be? Redraider |
01-31-2019, 02:02 PM | #47 |
I found this link the other day. It's from Art Morrison. With a 57.75" WMS and a 9.5 rim, they recommend a 5.5 backspace. With an 8 " rim they recommend a 4 inch backspace.
With a 57 WMS, they recommend 5 for 9.5 rim and 3.5 for 8 inch rim. Of course they are using Wilwood Pro-Touring spindles and Wilwood brakes. If you move up to the 13&14" brakes, more backspace is required. http://artmorrison.com/instructions/...structions.pdf |
01-31-2019, 03:01 PM | #48 |
anybody have a pic showing the wheels turned to lock both ways? do they rub over a bump with wheels turned? looks like they would but pics can be deceiving.
01-31-2019, 03:33 PM | #49 |
Joedoh's wheels set in quite a ways in the front and shouldn't have turning issues.
I'm still not a fan of the big wheel fad but he nailed it on that red truck. When you scroll to the truck your eye just sees a complete truck with not one item on the truck overpowering the whole truck. Even if he finished it out to a big car show main room feature finish as long as he didn't alter the basic look it all works. By gum I actually have a truck with 20's that looks right, the wheels turn lock to lock without hitting and it doesn't ride too bad. Can't lay frame though.
01-31-2019, 05:07 PM | #50 |
yeah, mr48, thats cool, but you may want to rethink the rear bumper placement.....
