04-05-2014, 03:51 PM | #26 |
Re: 1953 Burb build
Not sure how much clearance would be needed for the MAF and snorkel along with the fan . Had 7" decided to move the engine back but 2.5"
Perfect fit for a chevy valve pan t fit in the firewall Tired .....done for the day. So far I am really happy with how this build is going. Little hiccup with the suspension and the roll pan and some of the patch panels fought us, but if it was easy everyone would be doing it |
04-05-2014, 08:30 PM | #27 |
Re: 1953 Burb build
Everything looking sweet, nice job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
04-07-2014, 12:29 AM | #28 | |
Re: 1953 Burb build
I just read your thread. Progress is looking good.
I just installed that same TCI leaf kit in my truck this weekend. I know the truck is slightly lighter in the back compared to the burb but, like you, I was a little concerned with only 2 leafs. So far it looks good. I also put in a mustang II kit. I went with Fatman and I was pretty happy with the install of it. You are a little bit ahead of me so I hope you don't mind me asking some questions since ours set ups are similar. I have a 2000 5.3 LS and the dirty dingo street rod adjustable mounts http://dirtydingo.com/store/index.ph...=1_206_305_321 You said your mounts were DD too, were they the same ones? What LS engine accessory brackets are you running? I was looking at the accessory drive and it didn't look like f-body, corvette, or truck. If it has the same spacing as the truck I'm curious about where you put your mounts, did you have to trim the mounts, and what set of holes worked for you. You also said this Quote:
Good luck with your build. I'll be following your progress closely.
My 1950 Chevy build |
04-07-2014, 10:42 PM | #29 |
Re: 1953 Burb build
Yes they are the same mounts from DD. As far as what holes, I am not sure yet. I have not finished welding until I get my headers sometime this week I hope.
The brackets are for a truck from what I have been told by the guy who built the motor. 7" before cutting the firewall.. Now I am a little over 9.25" |
04-08-2014, 10:11 AM | #30 |
Re: 1953 Burb build
Nice work. It is better to have more than enough room up front than not enough. That space seems to get eaten up fast when to add accessories a fan as well as an air intake.
I’m still waiting on patch panels. 1 of the 3 I ordered is on back order. I have been working on my 48 fixing some things that bugged me. Keep it up. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
04-16-2014, 09:07 PM | #31 |
Re: 1953 Burb build
Thanks for chiming in on my info gathering thread and thanks for answering my questions above.
When you put in your TCI leaf kit what pinion angle did you go with. I read 3 degrees a lot and the kits called for 5 degrees in the instructions. I just went with 4 degrees but I'd like to hear that you did. Also what are you running for a fuel tank and pump?
04-17-2014, 06:25 PM | #32 |
Re: 1953 Burb build
I don't have the rear welded in yet.... But it will be 4 degrees.
Fuel tank I have is steel goes behind the rear between the rail from brothers $240 I think. Running external pump from MSD.....have the same thing on my truck and it runs great and I can't hear it |
04-22-2014, 08:32 PM | #33 |
Re: 1953 Burb build
04-22-2014, 08:33 PM | #34 |
Re: 1953 Burb build
need some help with A/C compressor....bracket and location....anyone have ideas let me know.
Thanks |
04-23-2014, 08:07 PM | #35 |
Re: 1953 Burb build
Got it on the ground...about as low as I want to go and stay away from bags. 4" off the ground. Rear needs dropped about 2" easy to do with blocks
04-23-2014, 08:13 PM | #36 |
Re: 1953 Burb build
04-23-2014, 09:29 PM | #37 |
Re: 1953 Burb build
Lookin good...
Marc
04-23-2014, 11:06 PM | #38 |
Re: 1953 Burb build
Not sure if this is what your looking for, but might help. Allan Grove bracket #142R AC for ls truck engines..Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 04-23-2014 at 11:21 PM. |
04-23-2014, 11:26 PM | #39 |
Re: 1953 Burb build
Great job. These kinds of pics are exciting! My engine goes in on Saturday barring any setbacks. How long till you plan to fire it up?
04-24-2014, 02:03 AM | #40 |
A320 Pilot/USAF Retired
Re: 1953 Burb build
Nice build!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
04-24-2014, 08:28 AM | #41 |
Re: 1953 Burb build
Oldman3, does that AC bracket clear the compressor from the frame rails?
04-24-2014, 09:44 AM | #42 |
Re: 1953 Burb build
I've never used this bracket, just something I found. On Alan Grove site it has dimensions, etc., I'm not sure which frames it would clear, sorry...Jim
04-24-2014, 09:22 PM | #43 | |
Re: 1953 Burb build
Oldman thanks... got one of these and it does not fit. Need another 1.25" Might have to go high |
04-24-2014, 09:24 PM | #44 |
Re: 1953 Burb build
Wont fire it for a while....there is ZERO wiring n it as it sits. Probably will not do any wiring or starting until after paint.
Late summer or early Fall would be my guess |
04-25-2014, 12:48 AM | #45 | |
Re: 1953 Burb build
Build Thread: "Marvin" (1953 3100) |
04-25-2014, 02:43 AM | #46 |
Re: 1953 Burb build
I don't know what your budget is but Vintage air has a front runner system that works really well it mounts every thing up and tight to the motor. But its not cheap but you get everything for the front of the motor you might check it out.
04-25-2014, 06:45 PM | #47 |
Re: 1953 Burb build
Blew my budget but I bought front runner system.
Not vintage but something similar for less than VA. Torchlight that looks good but to get what I needed with the motor being off center by 3/4" I would had to have made drastic changes to the frame and also the cross member with what I have |
04-26-2014, 01:01 PM | #48 |
Re: 1953 Burb build
nice burb build, iceburgh
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-27-2014, 10:17 PM | #49 |
Re: 1953 Burb build
So I installed my engine mounts this weekend (same as yours) and noticed that they came with 4 rubber isolators but the Dirty Dingo pics show only one between the mount halves on each side. What did you do with the other two? Did you put them on the bottom between the frame mount and the nut?
04-28-2014, 01:52 PM | #50 | |
Re: 1953 Burb build
