Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-27-2014, 07:40 PM   #26
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Re: Attempting my first build 72 K5
I'm so jealous of the underside of your Blazer. If I did that to mine I would probably see the inside. One day maybe....
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
Old 05-27-2014, 07:57 PM   #27
sockalaminski
If you're not going to paint or undercoat until next year, You should epoxy or etch prime and seal that underside. The raw steel will have a nice layer of surface rust on it otherwise.
sockalaminski is offline   Reply With Quote
Old 05-27-2014, 09:21 PM   #28
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
@Dutchmanz - haha.. I definitely lucked out on this K5. Before this one, I had a 70 K5 that was rusted from the back of the truck bed to front and also above the windshield. I had it in high school and then when I went off to college, my junior year, my younger brother just got his license and within 2 weeks of driving he totaled my blazer. He crashed into a light pole and pretty much destroyed the whole front chassis to where it was un-repairable.
I managed to get 8K from the insurance and the truck back for $300. I parted it out for another 4K. After I graduated, I wanted to get another K5 and I found this one.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 05-27-2014, 09:27 PM   #29
72K5CSTDarkOlive
That's a good idea. So I have a question... Has anyone ever used a Air Needle Scaler?
I'm going to be painting my axles using Master Series AG111. I want to get it to bare metal, but I don't have the option of using a sand blaster.
Old 05-28-2014, 11:31 PM   #30
sockalaminski
That's how I cleaned the underside of my '71. Also why I was jealous to see the result of steam cleaning. I spent a good 40 hours under the cab before I got it all off. The needles will leave little impressions if you use too much pressure but should give a good result.
Old 05-29-2014, 01:35 PM   #31
72K5CSTDarkOlive
Re: removing the rear drag link?
I'm really struggling to remove the rear drag link from the axle. I was able to remove the long steering rod (not sure if that's the correct name) with no problems.
Is there a special tool for removing this? I tried the BFH and the socket over the nut, but it wont budge.. I'm trying to remove each individual piece from axle so I can prep them for paint.
Old 06-01-2014, 03:56 PM   #32
72K5CSTDarkOlive
Re: Updating here
ok, so I was able to remove the rear drag link from the pitman arm.. I went to Carquest and rented a Spindle Nut removal tool, for FREE! All you have to do is put a deposit down and when you return it they refund your money.. pretty cool, oh and I can use for up to 30 days..
So I removed everything on the axle except for the ball joint knuckles. I was kind of over removing ball joints at that point. It did make it a little more challenging for sanding but I think I was able to hand sand in and around those tight areas..
When I was at Carquest, I picked up about 7 different size steel wheel wires for an electric drill. It worked pretty good, but next time i will haul the axle somewhere and pay someone to sandblast it.. I think I spent a total of 16 hours prepping this axle.. It had a ton of grease, rust, corrosion.
Here's a pic before the first coat of primer and one with the first coat of primer. I'm going to put one more silver primer coat and then finish with a top coat of chassis black gloss.. I used MasterCoat .
Old 06-02-2014, 10:21 PM   #33
72K5CSTDarkOlive
Got home from work and painted the front axle.. The paint has a foul odor... Good thing my neighbors didn't come outside while I was painting. I didn't noticed the smell until I removed my respirator.
Old 06-06-2014, 02:07 AM   #34
72K5CSTDarkOlive
I used a bench vice to remove the center bolt from the leaf springs. I'm taking them down to the same place that's doing a lot of my powder coating to have them sand blast, along with my drive shafts, skid plate bar, steering rod, drag links, etc..
Old 06-06-2014, 02:08 AM   #35
72K5CSTDarkOlive
I dont know why my picture keeping posting sideways. I certainly didn't save them to my computer like that.
Old 06-10-2014, 02:44 AM   #36
72K5CSTDarkOlive
Went to work on the front part of the frame
So this weekend I stepped it up and used the angle grinder with a 6 in wire wheel and just went to town on the frame.. The got it down to bare medal as best I could. Then I used this Medal prep from Master Coatings which then leaves this zinc phosphate coating. I let that sit for a couple hours and then I did 2 coats of the silver rust preventive primer followed by 1 top coat of the gloss black. Pics are from before and after with each step.
Old 06-10-2014, 02:48 AM   #37
72K5CSTDarkOlive
Hopefully these pics show right side up this time
Old 06-20-2014, 12:13 PM   #38
72K5CSTDarkOlive
Doing an update here with lot's pictures.. I've been busy cleaning, sanding, and painting. The Master Coat series http://www.masterseriescoatings.com/index/
is a long process. After all the parts are cleaned you start with the metal prep that they provide in their kit.. you can wipe or brush it on. After you do a couple coats of that you let sit for 2-3 hours. This leaves a zinc phosphate coating and cleans the parts really well.
The next step is to apply the silver rust preventive primer..requires 2 coats with 3 hours minimum between each coat. The final coat is the gloss black top coat.. I used a brush for everything. I think if I had a spray gun it would be much faster and easier to apply, but I think the results came out pretty good. I'm satisfied with it.
Old 06-20-2014, 12:15 PM   #39
72K5CSTDarkOlive
Updating with more pics
Old 06-20-2014, 12:17 PM   #40
72K5CSTDarkOlive
Zinc Phosphate coating
Old 06-20-2014, 12:18 PM   #41
72K5CSTDarkOlive
First coat of Silver primer
Old 06-20-2014, 12:20 PM   #42
72K5CSTDarkOlive
Black top coast
Old 06-20-2014, 12:22 PM   #43
72K5CSTDarkOlive
I took a bunch of parts to be powder coated. I used BR+F Spray in Santa Clara. I'm really happy with how they turned out.
Old 06-20-2014, 12:24 PM   #44
72K5CSTDarkOlive
Had the Transmission rebuilt. I cleaned it up and painted it using spray can aluminum paint.. I put a couple coats of primer on first.
Old 06-20-2014, 12:26 PM   #45
72K5CSTDarkOlive
Cleaned up the hubs
Old 06-20-2014, 12:28 PM   #46
72K5CSTDarkOlive
Engine arrived from MotorWerks . I went with their Stage 2 350. The crate it came in was wrapped up really nice and they delivered it directly to my house.
Old 06-20-2014, 11:02 PM   #47
mx289
mx289's Avatar
Truck looks great.
Making good progress.
(Side note.)
How do you like the ktm ?
I have really been considering one.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 06-22-2014, 11:29 PM   #48
72K5CSTDarkOlive
Originally Posted by mx289 View Post
Truck looks great.
(Side note.)
Thanks, mx289.. I love the new KTM 2 strokes. What kind of riding do you do?
I've ridden Yamaha's and Honda's prior to switching to the Orange side. If you ride mostly trails I'd go with the XC model, but if you're like me and ride mostly track than the SX is the way to go. My only complaint and it's not really that bad, but the first thing I would change on my KTM is having the suspension re-valved and sprung for your correct weight. I haven't done mine yet, but it my first upgrade I will do. In stock form it beats the crap out of me sometimes.. Through the woop sections is feels very march mellow, like.
Old 06-23-2014, 09:26 AM   #49
sockalaminski
You're making great progress. Keep up the steam, because once you slow down, it's hard to kick back into high gear. You'll be driving in no time.
Old 06-23-2014, 01:53 PM   #50
72blaz
72blaz's Avatar
Following along.. really nice!!!
1972 Chevy Blazer
Check out my build:
http://67-72chevytrucks.com/vboard/s...d.php?t=560741
72blaz is offline   Reply With Quote
