02-21-2015, 08:05 AM | #26 |
Re: Need info with a rear end swap from 88-98
not my idea, just copied from this site
02-21-2015, 08:39 AM | #27 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
02-21-2015, 12:47 PM | #28 | |
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
03-13-2015, 10:54 PM | #29 |
Hey, dredging this post back up as I just got the saddles welded on. It turned out pretty good ( my welding skills were a bit rusty though). Just to be clear I have removed a 12 bolt original from a 71' and am installing a 10 bolt from a 96'
I have some questions I need answered in order to wrap this up: 1) Will the parking brake cable assembly I have in the 12 bolt work on this rear end? It looks like they will fit, but I'll ask the question anyways. Or will the ones from a 10 bolt connect to the old system? (The ones I got with the 10 bolt were cut off.) 2) What is the U-joint I need to adapt from the 10 bolt to the original driveshaft?
03-14-2015, 01:24 PM | #30 |
TTT....anybody?
I'd like to wrap this up today, anybody done this before and have some answers? 1) Will the parking brake cable assembly I have in the 12 bolt work on this rear end? It looks like they will fit, but I'll ask the question anyways. Or will the ones from a 10 bolt connect to the old system? (The ones I got with the 10 bolt were cut off.) 2) What is the U-joint I need to adapt from the 10 bolt to the original driveshaft?
03-25-2015, 12:09 AM | #31 |
So, I found the answers to my questions.
1) Yes, the 71' style parking brake cable will attach to the new 10 bolt. I ordered 2 new ones from my local Napa parts store. 2) I found the U-joint adapter at Napa also, they had it in stock. I bolted the rear end in today, and so far everything went together perfectly. I am going to try to get all the misc stuff put together tomorrow if I have time.
04-12-2015, 11:01 PM | #32 |
Finally got everything back together. Just went for a test drive with my daughter. It changes everything, from the way it handles, accelerates, and
drives. Took it out on the back roads and lit it up! Couldn't be happier! My daughter said, "daddy it feels like a roller coaster"!
04-12-2015, 11:08 PM | #33 |
Here's the happy customer!
04-12-2015, 11:44 PM | #34 |
Cool deal. Glad it worked for ya. Others can possibly benefit if you can share the p/n's used.
04-13-2015, 12:23 AM | #35 |
Okay, what does p/n's mean?
04-13-2015, 12:38 AM | #36 |
laying low
Part numbers.
Glad to see you got er done. Lower gears really gives it more getup doesn't it? Whooooo gittyup.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-13-2015, 12:43 AM | #37 | |
Still though, I see a 383CU 400HP/400TQ engine and a 700R4 tranny in my trucks future! As far as parts, all I can say is it's a 1/2 ton rear end from a 1997 Chevy truck.
04-13-2015, 12:50 AM | #38 |
laying low
I think Scoti was referring to the conversion Ujoint and parking brake cable part numbers. I think you will like your choice of new power.
04-13-2015, 12:54 AM | #39 |
Gotcha. Ill get that info posted tomorrow as Mable is sleeping out in the garage and I don't want to wake her.
