Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-03-2014, 10:13 PM   #26
2000Limited
2000Limited's Avatar
Re: Project "Colonel"
I received my head bolts today. Second pic is the part number. I planning on building the 383 next Thursday.
2014 Dodge Charger SXT 100th Anniversary Edition
2009 Chevy Silverado Z71
1978 Chevy Scottsdale 4x4-Project "Colonel"- Build
http://67-72chevytrucks.com/vboard/s...d.php?t=632039
2000Limited is offline   Reply With Quote
Old 07-08-2014, 02:41 AM   #27
2000Limited
I received some of the last parts I need for this build.
In pic 1 from left to right
ARP Oil Pump bolt
ARP Flex plate Bolt
Mr. Gasket Harmonic Balancer Bolt
Fel pro Rear Main Seal
Competition Products Oil filter adapter
Alum finned Fuel pump block off plate
Comp Cams bolt and lock kit
Fel pro one piece oil pan gasket
In pic 2
Flowtech headers
In pic 3
Thermo stat housing and power steering pump brackets waiting to be painted
Old 07-08-2014, 03:12 AM   #28
Hankster
Hankster's Avatar
Heck yeah! Now get it together!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 07-08-2014, 03:15 AM   #29
2000Limited
I plan to put it all together Thursday morning. I hope I remember to take pics of the process
Old 07-14-2014, 12:38 AM   #30
2000Limited
Guess what everyone. The engine is together and setting in the truck, I'll post a lot of pics tomorrow night!!!!!
Old 07-14-2014, 05:06 PM   #31
Hankster
Hankster's Avatar
Sweet! Cant wait to see it!
Current Build
Old 07-15-2014, 04:49 AM   #32
2000Limited
Well here it is, the stroker is together!!! Sorry for all the posts, I can't post more then 5 pics at a time. And the order is a lil off.
Pictures are as follows:
1. Scat Crank just sitting in, we plasti gauged at this time.
2. Crank bolt in with ARP main bolt set
3. Crank and pistons bolted in
4. Pass side pistons
5. Drivers side pistons
Old 07-15-2014, 05:12 AM   #33
2000Limited
More
1. Probe pistons with Scat rods and ARP bolts
2. Cloyes timing chain- Had Comp Cams set, however it was broke when I received it.
3. Melling Oil pump, and oil pickup
4. Felpro 1 piece oil pan gasket
5. 7 qt oil pan on
Old 07-15-2014, 05:16 AM   #34
2000Limited
More
1. Vortec heads mounted
2. Heads again, just before intake, with alum timing cover on
3. Roller Rockers on
4. Roller Rockers again
Old 07-15-2014, 05:24 AM   #35
2000Limited
Here are some misc pics
1. Comp Cams timing set, look at the top part of the box, you will see the piece of the crank gear that was broke.
2. Engine dress up
3. Engine dress up 2
4. With carb on top
Old 07-15-2014, 05:32 AM   #36
2000Limited
More
1. Motor Mount brackets painted
2. Wire mock up 1
3. Wire mock up 2
4. Flowtech Headers
5. Complete and ready to be installed
Old 07-15-2014, 05:35 AM   #37
2000Limited
These last three pics are of it bolted in the truck and the engine bay painted. Next step is install the electric fuel pump, headers and the rest of the small things to be able to finally fire it up.
Old 07-17-2014, 12:45 AM   #38
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 07-27-2014, 10:46 PM   #39
CanadianK10
Active Member
CanadianK10's Avatar
Trucks looking great! I've got a charger as well 2011 Rallye, awesome cars
- Adam
1967 K10 292, SM65 Transmission & NP205 Transfer Case
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=605048
CanadianK10 is offline   Reply With Quote
Old 07-29-2014, 04:06 AM   #40
2000Limited
Hey guys, sorry its been a lil bit. I got sick and family stuff so I'm still finishing the small things so I can start the engine for the first time. I have a pic of the drivers side header on and one of the air breathers for the valve covers. In the last few days I've been wiring the fuel pump and rewiring the starter. I'll try to take pics of what I've done later today.
Old 10-28-2014, 07:25 PM   #41
Hankster
Hankster's Avatar
Hows this thing coming along?
Current Build
Old 11-13-2014, 06:03 AM   #42
2000Limited
I got it fired off, but still having problems keeping it running
Old 11-15-2014, 01:38 PM   #43
Hankster
Hankster's Avatar
uh oh! Well at least you got it fired off. I've done a good bit to mine since the last update, but since no one replies I don't update anymore.
Current Build
Old 12-10-2014, 01:22 AM   #44
2000Limited
I understand! I did a little more to the truck this past weekend. I believe my carb is causing the engine to flood really bad. Will be doing some checks to fix the problem
Old 12-11-2014, 08:28 AM   #45
ryanroo
ryanroo's Avatar
dang! i somehow i missed all the engine assembly. the engine looks nice. i lie those valve covers on the older trucks.
at least you are working on a holley. they are pretty easy to tune. at least for me. i get nervous and twitchy around the spreadbore stuff. to many little springs and rods and seats and, and, and...
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-12-2014, 07:15 PM   #46
Hankster
Hankster's Avatar
Well I hope you get it figured out if you haven't yet!
Current Build
Old 12-18-2014, 12:43 AM   #47
2000Limited
I sure did! the Holley carb I was using was flooding the engine bad. Switched carbs and it finally started idling like it should. Next is change the oil just to be on the safe side in case gas got in the oil. Then its time to finish the small things
Old 12-26-2014, 02:10 AM   #48
Hankster
Hankster's Avatar
Cool, got mine moving under ts own power this passed 2-3 days. its an animal.. still got teaking to do.. pretty sure i ruined 2 gear in my turbo 400 today.. lol whoops
Current Build
Old 12-26-2014, 04:04 PM   #49
2000Limited
Update- The carb is not my issue. My electric fuel pump is what is causing my issues. I have to get a regulator then I should be ok.
Old 12-30-2014, 05:18 AM   #50
2000Limited
Since progress with Colonel has been put on hold due to waiting on parts, Here are some pics of the truck I bought to haul Colonel around!!! Tell me what you guys think!!!!!!!!!!! Yes I know this is a Chevy Forum.
