08-08-2014, 01:08 PM | #26 |
Re: Mustang II spindles on stock control arms
How is the steering linkage going to hook up, from top like factory for our trucks or bottom?
Stupid me, I just re-read your first post. I can't wait to see how it all comes out. |
08-17-2014, 01:20 PM | #27 |
Well, the spindle and brake are on
Preliminary testing of the motion makes me think this is going to work just fine. Things I need to do to complete the swap: 1) Massage the lower control arm a little more as the rotor still hits but only when fully turned. 2) Make another spacer for the upper ball joint (between nut and spindle), similar to the one you can see on the picture. 3) Massage the upper Ball joint to fit the upper control arm from the bottom side like my other was. The upper control arm comes in contact with the spindle before the shock is maxed, when this happens it limits upward travel. 3) Drill the hole for the tie rod so it is square. 4) Get it aligned
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 08-17-2014 at 01:40 PM. |
08-17-2014, 02:47 PM | #28 |
Here is how I modded the ball joint. Just shaved a bit off the rounded outside edge. It now sits in from the bottom of the control arm vs the top.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
08-18-2014, 01:10 AM | #29 |
At the body shop.
The rotor looks like it's very close to the A arm? How much material did you remove??
" That didnt make it any newer " " Dont antique the equipment " |
08-18-2014, 10:50 AM | #30 |
I actually took more off the LCA than needed. There was roughly a 1" lip that I removed. As you can see from the pic, I have plenty of room now.
Here is a straight on shot with no changes to the control arm. The rotor currently contacts the back side and front side at full turn. I will be taking a pinch more off to fix that.
08-18-2014, 12:11 PM | #31 |
Are you concerned taking that much off the end of the LCA?
In terms of weight savings wouldn't tubular control arms be lighter?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
08-18-2014, 12:26 PM | #32 |
Of the shelf tubular arms are actually heavier.
I am not to worried about What I took off. I will keep an eye on things but the lower ball joint still had a ton of material around it.
08-18-2014, 11:45 PM | #33 |
Quick update. I think I am going to drill the steering portion of the spindle, weld in a sleeve then have it reemed to accept my stock tie rod.
After some time I will be going to a rack and pinion. I think this option well help me with rack selection simply do to width.
08-19-2014, 01:04 AM | #34 |
Those are the same front brakes as I'm running, looked at the full race but the weight rating was way too low so figured for the extra 3lbs each I'd go with more stopping power.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
08-26-2014, 05:30 PM | #35 |
Ok, all done!!
As mentioned I used QA1 Upper and lower ball joints: 1210-101 = Standard height Press in housing for our arms 1210-510 Ball Joint for lower MII that fits that housing is 9029-229 You can see from the pictures in this post that the lower required a space and the upper I just used a hardend washer and put a slight taper on the in side. I decided to ream the spindle to accept part number ES409RT outer tie rod end. My drag link uses inner tie rod ES409LT These tie rod ends fit a 1982 Chevy pick up Brakes are Wilwood 140-11017-D. This is the biggest disk Wilwood recommended with a 15" wheel. Keep in mind, I do limited street driving. I wanted to go with 140-10440 but Wilwood was not convinced they would fit a 15" wheel. I had to massage the lower control arm with a cut off and flapper wheel around the ball joint so it did not hit the rotor. I am guessing total weight savings is about 80-90lbs as I forgot to actually weigh the new complete set up before installing it.
08-26-2014, 05:32 PM | #36 |
I will add that I am pretty sure this will put the truck spindle center line back to near stock. Once I have my new front wheels mounted, I will put it on the ground and see how it effected ride height as I had a 2" drop spindle.
08-31-2014, 05:03 PM | #37 |
I've been considering mustang 2 spindles on my 67 simply because I wanted to run the 11" wilwoods inside buick finned aluminum drums.
now that I see it works i'll start gathering parts
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
01-20-2015, 01:02 AM | #38 |
Got things figured out with the mii spindle.
Went with a high misalignment rod end instead of a tire rod. Moved the upper ball joint in 1/2" Through rise there is additional toe in but not much. Also still have my 7" upward of travel.
01-20-2015, 09:46 AM | #39 |
Registered Truck Offender
So many concentrate on the GO FAST,, it's refreshing to see someone with some sense looking at control and stopping. I spent years in the 9's with a single pot master cylinder and stock Chevy-II drum brakes. It took a failed parachute to wake my ass up that the other end is WAY more important than just cutting hundredths out of the 60' time.
Nice work Shaun
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
01-20-2015, 11:04 AM | #40 |
mini truck racer
Funny how these things work out here . I just found this . Think it is a good read .
http://www.onallcylinders.com/2015/0...el-alignments/
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
09-03-2016, 09:05 PM | #41 |
Active Member
Super73 you have inspired me to do the same. As for I am on a budget and don't thousands of dollars for aftermarket stuff. Do you remember the part number for the MII spindles you used? Thanks been following your posts and giving me great knowledge.
Posted via Mobile Device |
09-03-2016, 11:30 PM | #42 | |
I bought the spindles used. I am now thinking about buying a 2" drop version.
09-04-2016, 12:43 PM | #43 |
Active Member
If you plan on selling them I'll take them off your hands
1972 GMC C2500 Tow Rig project 1972 C10 Air Bag project 1967 C10 Drag Truck project 1967 GMC Patina Special project 1968 C10 I have no clue what to do with project 1969 GMC C6500 I wish I had more money project 1986 K10 I have too many damn projects |
