07-02-2014, 10:11 AM | #26 | |
Re: Modified A-arms (what ya think)
Think about what's going on as you assemble this stuff a bit deeper - you have to use force to compress the spring and get the ball joint stud into the spindle. There's minimal downward pressure on the ball joint, rather the spring is constantly trying to tear it out of the control arm - the spindle/ball joint are all that's holding that spring in there and containing it's expansive force that's supporting the weight of the vehicle... You're modifying their attaching point. What happens when someone nails a pothole on the interstate, the weld fatigued control arm or gusset lets go and you lose it and wipe out a van of kids? Sorry guys, this is where you lose me. Unsafe. Spend the $ to buy the right parts designed to accomplish the task at hand.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
07-02-2014, 11:57 AM | #27 | |
This is a much better way to express your opinion/views w/o being ignored because of harshness.
07-02-2014, 12:34 PM | #28 |
yea thanks jon01 i respect that.... i do understand what your saying im not trying to put others or myself in danger i would never wont to hurt anyone the only reason for doing it this way is to save money if i can build something and save i will...i do know that this same lower arm has been on a truck around here for years he drives it piegon forge all the time never had an issue.
1978 c20 Crewcab - Current Project 1971 c20 - Backburner IG Handle: @78bigbluecrew |
07-02-2014, 01:13 PM | #29 |
The big issue I see is the ball joint plate is only welded on the outside and then ground off. Looking at the pic if the a arm showing the lower side it does not look like a good weld. All the gussets you show will not help this issue. Prime area for a crack to start and that is not good.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
07-02-2014, 04:58 PM | #30 |
We'll I don't know what to do... I don't have the funds to buy any if I did I wouldn't even have done this...Evidently I can't fix them so there just scrap now I'm not trying to kill somebody just lower my truck.... And they where only moved in 3/4 of an inch I meant to change that also I am dropping front an rear as low a I can 5.5 or 6 front not sure yet on rear..... I guess what I'm looking for is a answer to fix these things or is there any hope
07-02-2014, 05:31 PM | #31 |
I went 7/8'' of an inch thinking I could get away with not shortening the uppers. I now am shortening the uppers...Its okay I wanted to narrow my track width a bit anyway.
I would toss the arms and get a set from the junk yard. Run cut springs and save for spindles.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-02-2014, 06:08 PM | #32 |
Where at in nc are you at. I'll have an old set of original ones from a 66 c10 if they'll work for a clean slate to start with. Just come and take them off and your willing to have them. If ya need a hand doing them I can give u some pointers also.
07-02-2014, 06:19 PM | #33 |
Sectioning the crossmember can yield 1-1.5" of drop & would be much safer.
I would do odd jobs to save up & get drop spindles. Also.... try searching Craigslist or here on the site in the classifieds for someone possibly selling some used drop spindles.
07-02-2014, 06:44 PM | #34 |
What do you mean scoti about sectioning the cross member ?
07-02-2014, 06:45 PM | #35 |
I'm in mt.airy and thanks man I appreciate that ..if they will work I just may take you up on that
07-02-2014, 07:33 PM | #36 |
my 2 cents... just because you can, doesnt mean you should...
i hope to god you dont end up killing yourself or someone else over saving a few bucks.
Ed will be known as the Tiger Woods of the integration business |
07-02-2014, 07:45 PM | #37 |
if your dead set on dropped a-arms I would scrap that set and start over. you can get another set for $50 or so if you do a little searching through craigslist or the local pick a part.
then when it comes time to do them you'll need to pick up some 1/4" or 3/8" plate. I did a set about 20 years ago in an afternoon. its been a while but I think I used some 1/4" x 5" plate, it could have been 6". I cut the arm about 3/4" behind the ball joint, I also removed about 3/4" of metal but when the plate was welded in it took up 1/4" inch making them only 1/2" narrower. after the arm is cut I welded the plate to the arm then tacked the outer stub back on about 2" higher. if I did it now I would move the ball joint 1" forward. once it was tacked I cut off the excess plate then welded it all together. once that was done I made the gussets and welded them on. I think if I was to do it now I would use the original to make a jig to locate the ball joint and shaft them go all out with tubular a-arms
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
07-02-2014, 07:51 PM | #38 |
I'm in burlington which is about 30 minutes east of greensboro. Just let me know.
07-02-2014, 08:21 PM | #39 |
someone had to come up with the idea of dropping a truck without custom work we would not have anything cool on cars/trucks remember when trucks had front manual drums not safe at all but some guys still run that way building a car that does over 200 miles per hour not safe but it is still done pre 60s no seat belt in back seat not safe at all im not trying to be a ass but if someone tries to build something you shouldnt pray to god for anything besides the stress is on the ball joint itself not the a arm that is why the ball joint is pressed into the a arm the wear part is the joint
07-02-2014, 08:54 PM | #40 | |
07-02-2014, 08:58 PM | #41 |
Wow man like I said before here to learn not get bashed about trying something.....you don't have to be rude about it
07-02-2014, 09:05 PM | #42 | |
07-02-2014, 09:53 PM | #43 |
chances are that it wouldn't fail as is but I've seen way to many things fail that were just fine on so and so's car for the last 5 years.
back when drop spindles first came out me and a bunch of my friends ran out and bought them. most of use were running wide 15" rims on the front and they would not clear the lower a-arm with a drop spindle. instead of buying new narrower rims with the correct back spacing we just ground down the sides of the a-arm till they cleared the rims. all of them eventually cracked and a few of them broke in half. we even tried welding in a plate to the underside of the a-arm around the ball joint area extending back a few inches past where they were cracking to strengthen them back up. after going across several lanes of traffic sideways at 70mph through a ditch and through a wood fence backwards into a guys back yard when the a-arm broke we stopped cutting on them. I was in my early 20's then, I'd like to think I learned a few things since then
07-02-2014, 09:54 PM | #44 | |
Everyone says I'm an asshole. I say I'm direct. There are places to cheap out, suspension and brakes are not one of them. |
07-02-2014, 10:11 PM | #45 |
driving is in my blood
I knew when I asked that question I was going to end up looking stupid
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
07-02-2014, 10:27 PM | #46 |
its not a stupid question if you learn something from it
07-02-2014, 10:55 PM | #47 |
Thanks for the help fellas....I've looked up drop spindles the price isn't really that bad which brand do u guy recommend i thought they where around 300 a side looks like they come in twos if I'm reading correct I looked on performance online. Drop spindles an springs can get the front as low as possible for a static drop truck right.... I'm wanting my wheels to tuck under nice what should I do
07-02-2014, 11:00 PM | #48 |
And how do u section a cross member never heard about this before ?
07-02-2014, 11:10 PM | #49 | |
HERE IS A LINK TO IT FRENCHBLUE DID IT |
07-02-2014, 11:38 PM | #50 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=634090 Jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 Last edited by jtp67-72; 07-03-2014 at 12:01 AM. |
