Old 09-03-2014, 01:24 PM   #26
Billy81
Billy81's Avatar
Re: 1977 K10 Silverado Longbox
I would guess they were trying to add a drain plug to the pan but kept messing it up.
Billy81 is offline   Reply With Quote
Old 09-16-2014, 09:41 AM   #27
77K10Silverado
77K10Silverado's Avatar
Finally got a new radiator. Did I say finally? I went with the 4 core which my original one was a 3 core so the top support brace and shroud doesn't exactly fit. I plan to go by the j yard today to find the parts from a 4 core setup. Also took her up to the store yesterday. First drive in 2 months! Quite refreshing! Back in the saddle again boys.
77K10Silverado is offline   Reply With Quote
Old 09-24-2014, 09:55 PM   #28
77K10Silverado
Scored some donar muffs today. Hooker Aero Cambers. Cleaned them up and painted with high heat rattle. Should have than zipped up in a day or two.
Old 09-24-2014, 10:54 PM   #29
twangismythang
twangismythang's Avatar
Trucks lookin good!
Victory will only be achieved through superior firepower and trusting in the Lord.
SOLD 68 C-10. http://67-72chevytrucks.com/vboard/s...d.php?t=560975
SOLD 2000 Silverado...http://67-72chevytrucks.com/vboard/s...=1#post6492671
87 V-10 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=643898
twangismythang is offline   Reply With Quote
Old 09-25-2014, 08:35 AM   #30
77K10Silverado
Thanks man. ...straight pic of the muffs.
Old 09-26-2014, 09:17 AM   #31
77K10Silverado
Started working on the door panel and all the old broken plastic. Did a little fix on the handle trim ring. Sanded off the broken plastic knobs, drilled a pilot hole, and Gorilla Glued in some threaded rod!
Old 09-26-2014, 04:28 PM   #32
rusty76
rusty76's Avatar
Great idea on fixing those.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-03-2014, 11:02 AM   #33
77K10Silverado
Drove the truck up to the gas station up the street and got a few shots of my inspiration. The owner 'Satch" bought his K10 new. It says 76 on the plate in the door jam but he swears its a 77. Also he has 79 front trim on her. 400ci and Cheyenne package. Pretty sweet! Ill be doing some work on mine this weekend so ill have some build pics next week.
Old 10-22-2014, 09:14 AM   #34
77K10Silverado
Changed out the cab and radiator mounts this past weekend. Ill say its a bit firmer on the ride and leveled the truck out better. Wasn't too much of a pain to do either. I bought a small tub of lithium grease to help with the install. Ill post some pics of them installed 2morrow. Here are the old ones which were wasted and how I did it. Tranny mount are next as you can see!
Old 10-22-2014, 09:15 AM   #35
77K10Silverado
Old 10-22-2014, 09:18 AM   #36
77K10Silverado
The bottom rocker was slightly bent before as you can see from past pics. I wasn't from the jacking. Didn't want to scare anyone although it is Halloween!
Before..
After....
Old 10-24-2014, 08:28 AM   #37
77K10Silverado
Dropped the rear drive shaft to replace the U-joints. Man they were shot. Went with Moog Super Strength 280 greasable.
Old 10-24-2014, 10:36 AM   #38
77K10Silverado
Old 10-24-2014, 12:02 PM   #39
y5mgisi
Second Chance Program
y5mgisi's Avatar
Nice work!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-27-2014, 11:07 AM   #40
77K10Silverado
Finished up the drive shaft with some clean up and paint. Also replaced the rear pinion seal and pumpkin oil.
Old 10-27-2014, 11:10 AM   #41
77K10Silverado
Ill get some shots of the shaft back in this evening. I'll also hit the rear end with some paint as I degreased it with a wire brush and it needed to dry.
Old 11-03-2014, 12:39 PM   #42
77K10Silverado
Well I put some new shoes on her this weekend. I pulled the black painted wheels. Had them blasted then I primed, painted, and clear coated. Also here's a shot of the drive shaft back in.
Old 11-03-2014, 12:59 PM   #43
73Super8
73Super8's Avatar
Dude you knocked it out of the park painting those OE gray! Looks awesome!
73Super8 is offline   Reply With Quote
Old 11-03-2014, 02:49 PM   #44
JGood
JGood's Avatar
Those new rubber mounts sure straightened out the body lines nice! And the wheels! Bang up job lookin good!
1986 Chevy Silverado LWB (project)
1967 Chevy SBSS (future project)
2003 Chevy Tahoe (wifes daily)
2004 GMC 2500 Duramax (company truck)
1986 GMC Wrangler LWB (newly acquired beater)
JGood is offline   Reply With Quote
Old 11-03-2014, 02:51 PM   #45
77K10Silverado
I also broke another tooth on my original grill so luckily scored this orig grill from a 77 in the local yard for $30. Cleaned painted and badge Boom! Also found a spare tire thingy ma bob and blasted and painted.
Old 11-03-2014, 11:52 PM   #46
y5mgisi
y5mgisi's Avatar
Looks great!
Old 11-11-2014, 02:52 PM   #47
77K10Silverado
Got a little done this past weekend. Replaced the rear axle brake lines and the rear flex line. Also cleaned, sanded, and painted the rear axle and drums. Brakes look good for now. Ill come back to do a rebuild later. Pecking order here!
Old 11-12-2014, 03:48 AM   #48
y5mgisi
y5mgisi's Avatar
Good lookin truck.
Old 11-12-2014, 09:37 AM   #49
Greenlee
Greenlee's Avatar
Nice work! What size are your new BFG's? I think that's one of the few tires you can still get in a 32x11.00x15. I would like to get some for my truck.
In your first set of pictures is your gauge bezel faded or scratched up? The reason I ask is I have a pretty decent one hanging in my garage that I have no use for. I no longer have the truck I was going to put it in.
Greenlee is offline   Reply With Quote
Old 11-12-2014, 11:43 AM   #50
73Super8
73Super8's Avatar
Multi-Mile: Wild Country MTX 32x11.50x15 are nice $143 each
