Old 08-09-2014, 07:45 PM   #26
tinydb84
tinydb84's Avatar
Re: Used Parts Build
Got the top half of my 2x4's welded in. I was having a hell of a time with some porosity in my welds. I almost said **** it, no one will see them. Then I took a moment and regrouped. Jacked the truck up higher, made sure I was in a comfortable position, grinded out the old welds, and did them over. I am very happy I did:
Finished my body drop:
David
Instagram: myfabguy
Old 08-09-2014, 07:46 PM   #27
tinydb84
tinydb84's Avatar
Found some cheap steel:
Finished up my notches.
David
Instagram: myfabguy
Old 08-09-2014, 07:46 PM   #28
tinydb84
tinydb84's Avatar
Pulled my front clip. Had I known how easy it was I would have done it last year.
Cracked and busted radiator mount
Leveled. Front lines all drawn out. Need to layout the back lines.
David
Instagram: myfabguy
Old 08-09-2014, 07:47 PM   #29
tinydb84
tinydb84's Avatar
Braces added
Lines laid out
And chop!
Tacked
Front bit done
Weld shot
Getting kinda irritated with my welding. The first bead always sucks. Even if I lay a practice bead first. So I ground out the welds and read did a few beads. The first ones would have held but didnt look good enough for me. I dont want to hide or grind any of my welds.
David
Instagram: myfabguy
Old 08-09-2014, 07:48 PM   #30
tinydb84
tinydb84's Avatar
I really dont know how you all get so much done so quickly. Anyway, spent a bit of time tonight reinforcing the front of my Z:
David
Instagram: myfabguy
Old 08-09-2014, 07:49 PM   #31
tinydb84
tinydb84's Avatar
Front is finished. My inverted welds are looking a bit better.
David
Instagram: myfabguy
Old 08-09-2014, 07:49 PM   #32
tinydb84
tinydb84's Avatar
Started on the back side:
Had one boogery weld
Everything was square within less that 1/16 of an inch. Pretty happy about it. It was hell lining everything up with one person and only one jack. Still need to plate all the inside.
Made some filler plates
David
Instagram: myfabguy
Old 08-09-2014, 07:50 PM   #33
tinydb84
tinydb84's Avatar
Got the outside pretty much done:
Sideshot
David
Instagram: myfabguy
Old 08-09-2014, 07:51 PM   #34
tinydb84
tinydb84's Avatar
Some of the **** I heard doesnt come natural to anyone...Anyway Z is done!
Bumper:
Crossmember:
It should come down another 3/4-1 inch though. I need to flip the bolts on the upper bag plates.
I shorted my LCA 7/8'' of an inch hoping I wouldnt have to shorten the uppers...damn I was wrong. Probably shorten those 1/2'' to be safe.
David
Instagram: myfabguy
Old 08-09-2014, 07:52 PM   #35
tinydb84
tinydb84's Avatar
Got my 4 link
Ordered directly from Custom Connection. They supply Grant Kustoms. They were running a 20% off link sale and 40% off tab/gusset/etc sale.
Got everything (links/bag mounts/shock mounts/panhard/bushings) for $570 delivered to my door.
David
Instagram: myfabguy
Old 08-09-2014, 07:53 PM   #36
tinydb84
tinydb84's Avatar
[IMG]http://i20.photobucket.com/albums/b248/Tinydb84/Mobile%20Uploads/20140618_232333.jpg
Started putting my steering back together.
then realized I welded a plate blocking when I need to put my steering bolts...
David
Instagram: myfabguy
Old 08-09-2014, 07:53 PM   #37
tinydb84
tinydb84's Avatar
Replaced my cab bushings:
You have to reuse and cut down the original sleeves that are inside the bushings (yes I had to do everything twice...
Now my cab is at the right height and my trim is way off (Bed on left):
Oh and btw Camper Special trucks have a bracket that runs from the cab through the bed. You have to remove them to get the cab high enough to replace the bushings:
David
Instagram: myfabguy
Old 08-09-2014, 07:54 PM   #38
tinydb84
tinydb84's Avatar
When I was standing up I used the front frame horn to stand up and it had some lateral flex. I welded in a crossmember to help brace it.
David
Instagram: myfabguy
Old 08-09-2014, 07:54 PM   #39
tinydb84
tinydb84's Avatar
Tied the underside of the front of the Z together:
So my Z is complete. I got my steer parts but I am going to shorten my control arms first to get it all back together and make sure everything clears.
So I started to finish my SFBD instead:
David
Instagram: myfabguy
Old 08-09-2014, 07:55 PM   #40
tinydb84
tinydb84's Avatar
Tacked my final filler plates in:
The wind picked up and I could actually feel air flowing through the frame. Had to do this one section of weld a few times before I blocked the tube ends.
Finished welded up:
David
Instagram: myfabguy
Old 08-09-2014, 07:56 PM   #41
tinydb84
tinydb84's Avatar
Shortened my upper control arms:
David
Instagram: myfabguy
Old 08-09-2014, 07:58 PM   #42
tinydb84
tinydb84's Avatar
That is about where I am at now. Now all my updates will take forever hahaha.
David
Instagram: myfabguy
Old 08-09-2014, 08:58 PM   #43
y5mgisi
Second Chance Program
y5mgisi's Avatar
Its crazy to me with how smart and skilled you seem, that you would ever choose to paint anything in that green color that looks 10 years old the moment its sprayed on to any part. Aside from the green paint, i really like all of it.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 08-10-2014, 11:17 PM   #44
tinydb84
tinydb84's Avatar
Haha thanks? I think? I am back and forth with the green. Half the time I love it, the other half I want to paint it all black.
Started mocking up the steering:
I also started working on a bracket for the heim joint. You think this will be strong enough? 1/8 inch steel. I sm going to weld one side to the motor mount and bolt the other side to the top of the frame. I can box the top to the sides too.
Gratuitous laid out shot:
David
Instagram: myfabguy
Old 08-13-2014, 10:46 PM   #45
chevyboy73
chevyboy73's Avatar
wow thats crazy! i love it!
2011 Silverado ECSB LT
2000 Silverado RCSB 2WD
super bad habit of not owning a vehicle for a long time
chevyboy73 is offline   Reply With Quote
Old 08-24-2014, 03:00 AM   #46
tinydb84
tinydb84's Avatar
I did some work on my steering tonight:
David
Instagram: myfabguy
Old 08-24-2014, 03:01 AM   #47
tinydb84
tinydb84's Avatar
Ended up routing the brake lines over the steering instead of under it:
David
Instagram: myfabguy
Old 10-26-2014, 03:34 AM   #48
FLchevygrl
Active Member
Nice job. Where did you get the steering pieces from? I'm adding power steering as well.
I have everything but shaft. They just need cleaning and fresh paint.
Nice skulls.
My truck is a 69 c 20.
Betty
FLchevygrl is offline   Reply With Quote
Old 10-26-2014, 03:59 PM   #49
tinydb84
tinydb84's Avatar
I got the steering set up from Travis at AZProperformance. The stuff isn't cheep but solid. I'm converting to 5 lug so I have a lot of stuff to clean and paint.
David
Instagram: myfabguy
Old 10-26-2014, 06:50 PM   #50
bohmankid
bohmankid's Avatar
Cool build, man. Thanks for sharing. I'll stick around to see where it goes.
bohmankid is offline   Reply With Quote
