Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-12-2014, 01:13 PM   #26
richeilers
richeilers's Avatar
Re: 71 Blazer 2WD project
Hatch shocks are on! Works great. Didn't go all as planned but made it work. Lift Supports Depot was great helping me get what I needed. Lou himself even emailed me a time or two to make sure I got what I needed. Once I figured out that I couldn't get a ball stud to work on the bottom, they offered to put a different end on it so I could use a bolt. I used the following shock. http://www.liftsupportsdepot.com/lif...pot-4185e32-w/ I based that selection on measurements I had done on the old hatch support slider I had. I get the correct height on the hatch but the shock doesn't compress all the way, which actually works since I noticed the shock barrel dips down a little on the rod as I open the hatch, so some space is needed. I also wasn't able to bolt in the top ball stud brackets as planned so I used rivets instead. If I were to do it over I'd get a different bracket than shown, that slot is not as big as I thought it would be and I'd feel better using a larger rivet. Seems to be holding well now though. Hope the pictures add in the correct order.
Rich
1971 Blazer 2wd CST 454 http://67-72chevytrucks.com/vboard/s...d.php?t=641414
richeilers is offline   Reply With Quote
Old 09-12-2014, 01:17 PM   #27
richeilers
richeilers's Avatar
Hatch pics continued......
Rich
Old 09-29-2014, 09:32 PM   #28
richeilers
richeilers's Avatar
Latest task - clean up the tailgate area somewhat. The plates that hold the tailgate to body molding were corroded and bent a little. Had a guy media blast and straighten them. Got a piece of polished stainless to replace the floor, chrome, molding hold down piece. Mine was much too bent and rotted. Now, you'll see in the after pics that I don't have the molding in, I have it, but when they're in place the tailgate wouldn't close. Turns out there's molding affixed to the tailgate. It's on there real well and I'm not sure if I want to scrape it off just yet. Probably will sooner or later since I like the look of the molding in the plate where it belongs. But overall, it all came out ok, not that professional or even a great amateur job but it looks better than it did before. Not yet happy with the way the side panels are attached, maybe will just do all new black screws.
Rich
Old 09-29-2014, 09:35 PM   #29
richeilers
richeilers's Avatar
After pics
Rich
Old 10-02-2014, 11:50 AM   #30
richeilers
richeilers's Avatar
This week's project: Bed Rail Covers......Since I finally got my top off for the first time and plan to keep it off until it snows, I figured I needed to cover the 35 or so drilled holes in my bed rail. Thought about a couple of ways to do it and came up with a relatively easy and cheap way to do it. Supplies: 13 feet of 1/4 x 2 1/4 in wood trim wood (Home Depot), 1" foam to cover said wood (Hobby Lobby), 2 1/2 yards of black vinyl (Hobby Lobby and only 6.99 a yard on sale), 6 double ended screws # 8 x 1 1/2 - machine on one end, wood on the other (Home Depot) and wife's glue gun. Rail Prep: drill 3 holes in the rail for the two ended screws to snugly fit in to. I put the screws most of the way in and then laid the wood on in the position I wanted and gently pushed down to make a mark on the wood for where to screw the screws in later. Steps: 1. cut the wood to correct length 2. lay that strip on the foam and use a sharpie line on each side and cut to fit the wood 3. glue foam to wood 4. cut the vinyl to length and width - go a little wide and trim it down after gluing it to the wood 5. method we used was to tack the vinyl to the wood about every 4 inches without compressing the foam, then fill in between, do one whole side first, then the other (don't cover your rail screw marks) 6. found the vinyl doesn't glue to vinyl so we stapled the ends/corners. 7. Drill a pilot hole in the 3 marked spots from the Rail Prep step, be careful to not go too far through and nick your vinyl 8. Insert screws to barely come through the wood 9. Install 'em! Might have to do a little drilling out to get a good fit but mine are snug enough that I'm not worried about them flying off while I drive. I may add some super magnets to the bottom of the wood strips just in case.
Rich
Old 10-07-2014, 09:24 PM   #31
bk04z66
Like the bed rail idea. Your driver side seat belt retractor mounts to the bolt hole in the floor. The passenger-side bolts to the rear bulkhead.
bk04z66 is offline   Reply With Quote
Old 10-08-2014, 10:38 AM   #32
richeilers
richeilers's Avatar
Thanks bk. Actually, the passenger sides I have bolted to the seat frame, keeps them out of the way when the seat is tilted forward for people to get in the back. And neither side uses retractors.
Rich
Old 01-27-2015, 07:06 PM   #33
Beach Burb
Rich,
Blazer is looking good! Thanks for posting your gas hatch shock solution. I'm having issues with my old manual hold open brackets, they are getting stuck all the time. I think I will order a pair for my '71 Suburban with the additional mount that you got.
Mark
1971 Chev Suburban
1951 Chev 3100 Pickup
1953 Harley 165 ST
Beach Burb is offline   Reply With Quote
Old 01-27-2015, 07:09 PM   #34
Beach Burb
Just read your post again on the mounting bracket. Are you saying their bracket was too small or the bracket slots too narrow to fit a larger bolt?
1971 Chev Suburban
1953 Harley 165 ST
Old 01-27-2015, 08:58 PM   #35
richeilers
richeilers's Avatar
The slots are too narrow. I had to use a smaller diameter rivet than I'd wanted to. My original plan had been to use a 1/4 inch bolt but I probably wouldn't have been able to get in there for the nuts anyway.
Rich
Old 01-28-2015, 07:44 AM   #36
Beach Burb
What do you think about using the largest diameter sheet metal screw instead of the rivet? I know there may be a good amount of stress on that bracket. I'm thinking about placing 2 screws at the end of each slot for a total of 4 screws on each bracket?
1971 Chev Suburban
1953 Harley 165 ST
Old 01-28-2015, 12:06 PM   #37
richeilers
richeilers's Avatar
Screws might work but they are going into fiberglass...... 4 screws might work, there should be enough distance between them to not weaken the area too much......maybe?
Rich
Old 01-28-2015, 12:46 PM   #38
Beach Burb
Didn't realize that your gate was fiberglass. On the Burb it's metal so I think I'll be good. Thanks again for the help!
1971 Chev Suburban
1953 Harley 165 ST
Old 01-28-2015, 12:54 PM   #39
richeilers
richeilers's Avatar
Oh yeah, a Burb, duh....stupid me. Might want to consider the weight diffs then and go for a heavier duty shock.......that company has or can make anything I believe. Post a pic here when you're done! Good luck.
Rich
Old 01-28-2015, 12:59 PM   #40
Beach Burb
I did think about the weight difference. I'll have to get up with Lou and tell him what I'm up to!
1971 Chev Suburban
1953 Harley 165 ST
Old 04-16-2016, 01:48 PM   #41
BabyBlue
The Peacemaker
BabyBlue's Avatar
updates??
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 04-16-2016, 10:36 PM   #42
Ta12sec
Bed rails are super cool
Ta12sec is offline   Reply With Quote
