Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 10-05-2014, 01:59 PM   #1
GMCNUT
GMCNUT's Avatar
1957 GMC 4 speed trans and V8 bellhousing
I really do not want to sell this, but its wasting space when someone could really use it. This is a very hard to find 1957 GMC 4 speed trans and Pontiac V8 flywheel / bellhousing & clutch assembly out of a 100 series pickup truck. Not only is this super hard to find, this one only has 53,000 original miles and was working perfectly when removed.
Still nice and greasy and bolted to the engine except the trans itself which was separated to make it easier to move around. Everything is in the best possible shape you could ever hope to find - should be correct for 55-59 GMC models w/ Pontiac 288, 316, 347 & 336 engines.
So, this has to be picked up in Arab AL unless you send a shipper after it - not sure what the weight is, but can weigh it if you are sending a truck. Zip is 35016 where its located. First 400.00 dollars takes it - probably worth 600 or more in its condition, but I do need the space so my loss your gain
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
