Old 01-19-2016, 04:18 PM   #26
Rod Run
Rod Run's Avatar
Re: I'm this far in now....
I'm kind of confused how that rear swaybar is going to work effectively at such a high angle.
One thing I'm not confused about though, is that those rear shocks are laid out way to much, to be of any real benefit. They should be mounted much more up and down than that
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 01-19-2016, 05:38 PM   #27
bs46488
Its starting to look good.
What's the paint color/code?
bs46488 is offline   Reply With Quote
Old 01-19-2016, 06:12 PM   #28
swamp rat
swamp rat's Avatar
Humm, The springs carry the load, the shocks dampen movement, I'm not too convinced that its going to matter.
Now a shock spring combination like on an early dual shock dirt bike the angle would change the spring rate and make the compression softer early in the stroke and progressively stiffer later in the stroke, that's why the shift in manufactures and even hard core racers before that to move the top mounts forward to increase angle. but i don't think that would apply in this case.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-19-2016, 09:13 PM   #29
GMC Canuck
In the early pictures the shocks were laid back more. I have moved them.
On closer inspection I'm wondering if I have the sway bar in upside down.....
GMC Canuck is offline   Reply With Quote
Old 03-08-2016, 01:44 AM   #30
crakarjax
crakarjax's Avatar
I think you probably do have the bar upside down... did the sway bar come with the angle brackets on the side of the frame? Why not just mount the bushings directly to the frame itself?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
