Old 11-10-2014, 05:25 PM   #26
dunce79
Re: Dunce's 59 Fleetside build
Thats the plan. Get some ventilation going and hang new drop cloth inside after a good cleaning.
Originally Posted by Kim57 View Post
Nice job on the repairs.
With the right ventilation you could use it as a paint booth also.
Kim
dunce79 is offline   Reply With Quote
Old 11-10-2014, 07:01 PM   #27
Advanced Design
Advanced Design's Avatar
Awesome metal repairs! Way to hang in there. Thank you for sharing and looking forward to next updates.
Advanced Design is offline   Reply With Quote
Old 11-11-2014, 11:29 AM   #28
dunce79
Took out the windshield and back glass last night. Got some work to do to repair the rear window channel on top. Anyone have any tips on that? Luckily the front brow is in good shape.
Old 11-18-2014, 04:02 PM   #29
dunce79
After doing some media blasting and discovering a few more areas to fix I needed a boost to morale so I decided to fit the bed for the first time and get a good look at the truck as a whole. Going to be replacing the entire rear cab panel after working on the doors, hinge pockets toe boards and rockers.
Old 11-18-2014, 05:32 PM   #30
RockinKees
RockinKees's Avatar
Hang in there Dunce!!
You're doing a fabulous job on the repairs.
It's a lot of work, but you will manage that!!
Don't forget, a lot of guys, including me, are learning a lot of your repair work!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-18-2014, 06:26 PM   #31
Kim57
Kim57's Avatar
It's going to look real nice when done.
Don't get too discouraged at the work to be done.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-21-2014, 12:10 PM   #32
dunce79
Gettin some more work done...
stripped the doors and better set of fenders I picked up at auction. Then began the repairs on one of the fenders.
Old 11-21-2014, 01:34 PM   #33
daveshilling
daveshilling's Avatar
Seeing all of your hard work is super motivating!!! I have unfortunate amounts of rust to tackle at some point, and no welding experience to date.
daveshilling is offline   Reply With Quote
Old 11-21-2014, 02:46 PM   #34
dunce79
Thanks.. I didn't either. I'm an IT guy during the day. I started small with practice stuff.. Cut up some scrap or junk fender and try to put it back together. Slowly I've worked up confidence to try more work on body panels. Check out metalmeet.com. Amazing group of talented people there.
Old 11-21-2014, 04:17 PM   #35
Kim57
Kim57's Avatar
Nice job on the repair.
Kim
My build thread
Old 12-02-2014, 11:55 AM   #36
dunce79
-Finished welding in the patch panel on the passenger fender.
-Fixed a rusty spot on top of the pass fender.
-Fixed a couple holes in the driver fender behind the grille
-put a patch in the lower rear section of the driver fender
-Headlight mounting points were missing from the fenders I picked up at auction so I drilled out the spotwelds on the ones attached to my original fenders, blasted them and welded them into my good fenders. Put on a little self etch primer on them for now.
Next up I need to put a fender brace replacement section in the passenger fender and then remove the front clip and begin work on the hinge pockets/doors etc.
Old 12-02-2014, 12:12 PM   #37
ricott
Man your bodywork is looking so good. Keep up the great work, and please keep posting pictures.
Ricky
ricott is offline   Reply With Quote
Old 12-02-2014, 01:09 PM   #38
Kim57
Kim57's Avatar
You're doing a great job on the repairs.
Kim
My build thread
Old 12-02-2014, 04:40 PM   #39
oldman3
oldman3's Avatar
Super metal working, looks great...Jim
oldman3 is offline   Reply With Quote
Old 12-08-2014, 01:29 PM   #40
dunce79
Took off the front clip and did some more media blasting. No new surprises but revealed the extent of the repairs needed on the lower cowl sections, lower passenger hinge pocket and floor. The lower fender mounts from Hollister fit great.
Currently in the middle of doing the floor pan replacement and then I'll do the rocker/step.
Old 12-08-2014, 04:11 PM   #41
Kim57
Kim57's Avatar
Very nice job on the repairs.
Kim
My build thread
Old 12-08-2014, 05:05 PM   #42
RockinKees
RockinKees's Avatar
I'm with Kim57!!
Great tutorial! (I have to do the same...)
Cheers!! Kees.
Kool Guyz CC
Old 12-08-2014, 07:54 PM   #43
oldman3
oldman3's Avatar
Yes, very nice repair job...Jim
Old 12-09-2014, 12:39 AM   #44
Wingnut1
Wingnut1's Avatar
Great work and pictures. Curious how well the indoor blasting is working and if you are finding dust or media outside off your "walls"?
Wingnut1 is offline   Reply With Quote
Old 12-09-2014, 10:48 AM   #45
dunce79
Finished the cowl repair last night and threw down some primer. On to the floor and rocker next : ). Not exactly a factory looking appearance with the repair but I don't care, just need it fixed. Could have bought the repair panel section and done it perfect but that panel is kind of expensive from what I've seen so I figured why not just make a patch and get it close.
Old 12-09-2014, 10:51 AM   #46
dunce79
The indoor blasting works ok. The key for me has been to place a pretty high cfm box fan at the end close to the big door on the shop and I created a tunnel with carboard boxes to flow the dusty air outside through the door. Otherwise it gets ridiculous in there quickly. Since the blasting "room" isn't sealed, clean air sneaks in all around and the bad air goes outside. Not perfect but it beats doing it outside in the snow and/or at 20 degrees. Without air flow you can blast and keep the dust in the room but it gets so bad quickly that you can't see anything.
Old 12-09-2014, 02:27 PM   #47
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
The cowl patch work looks good, but the factory left it open at the bottom so water and debris had a way to get out. It didn't work so well as stuff would clog the opening and cause it to rust out as yours did.
ChuckDriver is offline   Reply With Quote
Old 12-09-2014, 03:53 PM   #48
dunce79
Its hard to see but I did leave enough gap at the bottom for water to get out. I plan on either sealing up the cowl vent on top or putting in a screen -not sure yet. BUT.. anyone have a pic of how the bottom of the cowl should look so I know how much to open it up? thx
Old 12-09-2014, 05:33 PM   #49
Kim57
Kim57's Avatar
The patch looks good.
I had to do one of mine also and just did a home patch as it's never going to be seen.
I smoothed the cowl piece on mine so I'm not worried about debris clogging it up.
Kim
My build thread
Old 12-10-2014, 10:10 AM   #50
dunce79
Got the passenger floor patch fit and welded in last night. Now its on to the step/rocker before repeating everything on the driver side : ).
