Old 01-04-2015, 08:41 PM   #26
HemiChallenger71
HemiChallenger71's Avatar
Re: 67 c30 cummins swap
Stay away!
I would purchase NEW bosch 215 injectors. Factory 215's will get you close to 500hp with other mods.
HemiChallenger71 is offline   Reply With Quote
Old 01-04-2015, 08:43 PM   #27
Kobush
Would like to go with something a little bigger than stock. Will be adding a turbo and bigger pump at some point.
Kobush is offline   Reply With Quote
Old 01-04-2015, 09:16 PM   #28
HemiChallenger71
You dont need to. That 215hp engine will support more power than the trans and chassis will handle.
500hp @ the wheels is barley leaning on it. A factory turbo w/mods will support 500hp.
Old 01-04-2015, 09:17 PM   #29
HemiChallenger71
whoops
Old 01-04-2015, 09:24 PM   #30
Kobush
I've got 4k gov springs to put in, grind the fuel plate, and add some timing. Other than pump, turbo, and injectors what mods are there?
Old 01-04-2015, 09:38 PM   #31
HemiChallenger71
You have to have the valve springs to.
Modded hx35 or modded he351cw 35-40lbs. boost, bump the timing and playing with the plate and screws and your near 500hp.
Old 01-04-2015, 11:36 PM   #32
63c102013
63c102013's Avatar
It depends on how crazy you want to get. On mine I'm having the intake plantium machined off and a runner style intake also larger valves from Hamilton cams. You can put a cam in it. If you have a pump some delivery valves also a pump cam. There are a lot of things you can do it just depends on how crazy you want it
63 c10 5.9 cummins
63c102013 is offline   Reply With Quote
Old 01-06-2015, 10:36 AM   #33
burnin oil
Yes it will get close to 500HP but it is really hot and turbo life is not the best. A turbo upgrade is a very smart idea around 350HP. I will bet that there will be a lot of vertical scratches in the rear cylinders from ring scuff without a turbo increase. If you start out with a 215 pump don't mess with the DVs. You already have 181's which are pretty good. Most larger DVs run hot and smoke because the fuel timing gets messed up. You want your fuel injected quick and early. This gives more power than late entry fuel along with cooler EGTs. If you want way more fuel than the turbo can use it takes about $200. Buy a good 4k GSK with valve springs and grind the fuel plate to a 100 profile. You will never ever clear it up with a stock turbo. I ran this setup on 362/475 twin setup and still had plenty of fuel. For injectors spend the money. You want quality parts here. Period! Always buy injectors bigger than you need and use the AFC and fuel plate to limit fueling. Power is easy to build and you will want more in short order!
burnin oil is offline   Reply With Quote
Old 01-26-2015, 12:08 AM   #34
Kobush
Starting go go back in.
Attachment 1354740
Old 01-26-2015, 08:49 AM   #35
Kobush
Old 01-26-2015, 08:50 AM   #36
Kobush
Trans crossmember
Old 01-26-2015, 11:28 AM   #37
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It's looking really nice.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-26-2015, 05:35 PM   #38
brimc
brimc's Avatar
That engine looks really good sitting in there. Can't wait to see more.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 01-26-2015, 10:01 PM   #39
GMC-YA68
GMC-YA68's Avatar
so awesome!!!!
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 01-27-2015, 09:21 PM   #40
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hahah man I don't know the last time I saw a Cummins that grime-free. Usually I see about 1/2" of soot and oil.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-27-2015, 10:23 PM   #41
HemiChallenger71
Thats what happens to 20 year old work trucks. Remember 1998 was the last year of the 12v. Mine just turned 20 this yr. Wish I had a pic of the engine just to show how clean it is. I've never cleaned it. I doubt the previous owner did either.
Cant wait to see this swap completed!
Old 02-02-2015, 12:00 PM   #42
BigBlockBurris
BigBlockBurris's Avatar
Kobush-What motor mounts did you use? Did you fab them?
Do you have any better pics of them?
You swap is looking awesome, and I am fixin' to start the exact same swap on a 72 one-ton myself.
I just wish my motor was a 215 motor.
BBB
BigBlockBurris is offline   Reply With Quote
Old 02-23-2015, 11:08 AM   #43
72smoker
72smoker's Avatar
good looking build.
1972 c/20 cummins
1948 3800
72smoker is offline   Reply With Quote
Old 02-27-2015, 11:48 PM   #44
shopteacher
Those engine mounts look like the same ones I got at Auto World out of Great Falls MT!
shopteacher is offline   Reply With Quote
Old 03-22-2015, 09:43 PM   #45
Kobush
Thanks guys.
Yes they are Auto World mounts. Fitment was great with them.
Old 03-29-2015, 06:55 PM   #46
Kobush
Had to cut a small hole in the core support
Old 04-14-2015, 07:50 AM   #47
Kobush
Got most of the metal work finished up on the core support last night. Getting motivated to get this thing on the road.
Old 06-07-2015, 10:48 PM   #48
chrapladm
WOW....amazed how well this setup fits. Looks like it was OEM.
chrapladm is offline   Reply With Quote
Old 07-22-2015, 05:40 PM   #49
steppside69
steppside69's Avatar
Great build!!! Any updates?
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 05-06-2018, 07:07 PM   #50
Kobush
Finally got back to work on the truck after a little break from it. Ended up having to pull the cab to make a few changes to the crossmembers and do some clearancing on the firewall for the down tube. The truck is put together now and working on the finishing touches to get it on the road. Planning to get some pics up soon.
