11-05-2015, 10:51 PM | #26 |
Re: Best starter heat shield
old topic sorry. My starter in my 64 c10 is giving out. Its a v8 305 from an 80 chevy. Would that 98 tahoe starter work in mine? I found this one on rock auto.
http://www.rockauto.com/catalog/more...nid=503&jpid=8
Stovebolt-It is painted |
11-06-2015, 08:24 AM | #27 |
100% agree, I love those mini starters.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
11-06-2015, 08:58 AM | #28 |
I wish I would have known about this when I bought my last starter! I haven't had any problems, but I do have headers and the starter is kind of close.
11-07-2015, 01:43 PM | #29 |
So happy with my new starter. Thanks for the heads up. I just took my old one to the parts store and asked to replace it with a mini and they matched one and bam Didnt even realize it was a delco remy till i got home. I paid more though $171. Found same one this moring for only $60 plus shipping. here is mine and a link to a cheaper one but same parts number. This is in my 64 c10 with an 80-83 chevy v8 305.http://www.carid.com/quality-built/r...pn-6449ms.html
11-08-2015, 10:51 AM | #30 |
I had hot start issues on my old blazer to the point I hated to drive it anywhere. I had replaced all the cables with larger cables, put a ford solenoid on the fender, replaced starter, checked timing, and tried a heat shield. Still slow starting when hot.
Finally I put one of the tahoe starters on this spring and it cranks like crazy. Drove it more this summer than I had in the last 10 years, and it always started fast. I should have done this years ago. The small starters have permanent magnets instead of wound coils on the outside (stator) and a planetary gear reduction, (some places call them pmgr starters) so they generate more torque while pulling less amperage. Goog luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
11-08-2015, 12:06 PM | #31 | |
11-08-2015, 12:22 PM | #32 |
Did you have headers? I'm pretty sure the headers caused all the problems I had.
Rg
11-08-2015, 12:32 PM | #33 |
It has some shorty headers on it, they don't wrap around the starter, so I don't think they would add as much heat as long tubes.
11-08-2015, 02:23 PM | #34 |
Collector of Projects
I want to run some ram horn manifolds and this will definitely help with clearance... I just got a factory replacement from the local parts store. I need to see if they'll exchange it for me...
12-23-2015, 07:25 PM | #35 |
12-23-2015, 09:59 PM | #36 |
Dan, now that you mention it I remember I bought new bolts at Autozone due to the same issue. They had 2 different length bolts in the "HELP" section.
Good luck, Rg
12-24-2015, 01:33 AM | #37 |
on my 66 GTO which had bad heat soak I used header heat wrap on the starter and it worked like a charm. Yours looks easier though.
1971 Cheyenne Big Block Longhorn |
12-28-2015, 05:00 AM | #38 |
Correct bolts for the OE mini starter.
GM part number 12338064 which is 3/8-16 at 4.33 in length. |
12-29-2015, 09:50 AM | #39 |
Camaro Club
So these old engines dont tear up that 98 starter? When I first bought my 86 camaro it had a bad starter gear and flywheel. I had my stepdad pick up the new parts and he got them for an 86 because thats what year the car was. The engine was a early 70s 350. After about a week it had ruined the starter gear again. Got another starter and tryed playing with shims. A few days later needed another flexplate and starter. Put it backtogether with no shims. Lasted about a month and started grinding again. Starter gear was worn out again with some wear on flexplate also. Took the starter back and decided to see if we could figure out what was going on. Thats when we realized the starter was for an 86. Had the parts guy look up a starter for a 70 camaro. The starter looked exactly the same but had a different part number. I bought that starter and bolted it on and its been on there for the last 10 years.
06-05-2021, 11:44 PM | #40 | |
Rg
06-07-2021, 09:34 AM | #41 |
I got one of those 98 tahoe starters... and, its still in the box in the garage, put it in, checked pinion extension, and it only engages about 1/8" of the flywheel. Original starter a generous 1/4" of engagement with the flywheel.
So those of you who are running the tahoe starter, did you manually extend the pinion gear and check how much of your flywheel is being engaged? How much did you observe? And yes, that little washer retainer at the end of the nose is properly seated. |
