Re: Project "Moonshiner" Bagged & Z Frame 63
If you are going to modify the lower, then why not the upper as well? You could correct the heavy angle on the ball joint. It'll take a bit of work to get the geometry correct, but hell, if your up for the task... Why not give her a shot?
![]() Edited!!!! Hahahaha Scratch that! I see you are well ahead of my thoughts here!!!! LOL
64 LWB to SWB Step build. Daily driven! ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=647168 |
#2 | |
____________________________________________ My build thread: Project Moonshiner Bagged & Z Frame 63 http://67-72chevytrucks.com/vboard/s...d.php?t=659205 "I love the smell of grinding metal" |
![]() Join Date: Mar 2005
Popcorn, you're a maniac! I haven't seen someone build a stepped a-arm in a long time. You already know this, but gusset the crap out of it, and box it where ever you can.
If you want to gain a bunch of caster, check out my caster thread, where I devised a very simple way to gain a bunch of caster for essentially no money. http://67-72chevytrucks.com/vboard/s...d.php?t=501241 I love what you're doing, keep it up. Maximum effect, with high quality work being done on the cheap. You're talking my language!!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#4 | |
![]() I know I may get flamed for this ![]() It looks like I'll have plenty of room for some substantial gussets that can run the outer edges of the arms with no problems. And thanks for the caster idea. I'm subscribing to that thread to save it.
Weird camera angles kinda make it look like a longbed but it's a short bed.
Any updates on this beast?
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
It sees sunlight!
looking good Popcorn!
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
Nice.
it looks good , I like it !!
im leaving drum brakes on mine too, im gonna pancake my front crossmember instead of dropped spindles. |
