Old 03-06-2015, 01:03 PM   #26
JJH Jimmy
JJH Jimmy's Avatar
Re: 4x4 LS cross member
Not the greatest pictures but here are a couple more.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 03-06-2015, 01:09 PM   #27
First c10
First c10's Avatar
Jimmy they look good. I am not sure I could make them look that good with the tools and equipment I have access to. Was it 100% fabricated? How did you bend the tubing?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-06-2015, 01:38 PM   #28
JJH Jimmy
JJH Jimmy's Avatar
It is 100% fabricated. I used 2" schedule 80 pipe and two 90 weld fittings. I mitered the fittings to about 60* and welded it up. I then smoothed the welds down, blasted and painted it. For the mount point i took a small piece of 2" DOM tubing and welded it inside the 2" pipe and found a poly bushing to go inside the DOM.
1985 Chevy K20
1994 GMC Yukon
Old 03-06-2015, 03:45 PM   #29
First c10
First c10's Avatar
WOW they look great!!! I have a $20 bill with your name on it if you can send me one???
ok so where can I find the pre-bent 90's??? because that is probably the hardest part to locate i would think as the rest of the metal you can get from the local metal/welding shop.
Looks great Jimmy!
GO GO!!!
Old 03-06-2015, 05:43 PM   #30
JJH Jimmy
JJH Jimmy's Avatar
Looks great Jimmy!
You can get the 90's at any pipe supply house. Tell them you want 2" carbon steel butt weld 90's. They are probably not $10.00 a piece.
1985 Chevy K20
1994 GMC Yukon
Old 03-09-2015, 01:20 AM   #31
First c10
First c10's Avatar
Jimmy that is something I may try. Even if I can't make it work I will be out little money and some time.
Has anyone tried this? It's not for an LS but was wondering if it would be close.
Diy4x crossmember......not for LS
GO GO!!!
Old 03-09-2015, 08:06 PM   #32
DWilbur
Looking at Jimmy's pictures his engine sits higher than mine with the Dirty Dingo mount. should make header selection easier.
DWilbur is offline   Reply With Quote
Old 03-09-2015, 11:58 PM   #33
First c10
First c10's Avatar
Will that help out with the A/C compressor in the stock location or hurt?
GO GO!!!
Old 03-10-2015, 12:02 AM   #34
GMC-YA68
GMC-YA68's Avatar
Hmmmm. It is higher. I wonder how high? That would keep someone from putting a lift on to get the clearance. (Thinking out loud)
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 03-10-2015, 02:49 AM   #35
DWilbur
The stock LS AC compressor will not work with the older AC system. It is a 2 speed pump. you will have to change it out to work. vintage air has the compressor and brackets needed. Guessing his engine sits about 1.5" higher than mine. I noticed that Ruff Stuff Specialties has an LS engine mount.
Old 03-10-2015, 04:56 PM   #36
Nitis
Nitis's Avatar
Well I was talking to a guy yesterday who swears he knows of a 72 k20 LS swap that didn't have a crossmember done I'm trying to put my hands on it to see
One would assume if it does sit higher some how the bit could work but what are the downfalls?
Nitis is offline   Reply With Quote
Old 03-10-2015, 06:30 PM   #37
JJH Jimmy
JJH Jimmy's Avatar
The elevation of my engine was determined by the transfer case elevation and 5 degrees of pitch. I have Trail blazer SS manifolds and the flange just clears the frame on the passenger side.
There is no way the stock compressor would work with my set up. The cross member is in the way and I am sure it would still be into the frame.
1985 Chevy K20
1994 GMC Yukon
Old 03-10-2015, 08:47 PM   #38
First c10
First c10's Avatar
Hey DW, in my 70 with a 2011 5.3 I cleaned the original Denso compressor that came with the motor flushed it out change the oil etc. and connected it to the R12 system and it works great.
GO GO!!!
Old 03-10-2015, 08:50 PM   #39
First c10
First c10's Avatar
I was thinking that it could be done but you would have to raise the motor so the pan would not hit the crossmember. Or cut the pan possibly
GO GO!!!
Old 03-10-2015, 08:55 PM   #40
Nitis
Nitis's Avatar
I am not a mechanic so this may sound dumb
Raising the engine would require the transmission to be raised as well so is there enough clearance for that?
And typically from what I have seen or recall its actually the block that's too wide for the existing crossmember oil pans aren't a hindrance. But replacemnt crossmembers then get in the way of the front punkin not the oil pan
Old 03-10-2015, 10:23 PM   #41
GMC-YA68
GMC-YA68's Avatar
No that sounds right. What I was getting at is that if the engine sits 1.5/2" higher than a DD or PacFab mount then it would deter from people adding a 2" lift to clear the pumpkin. This all of course would be great in a perfect world if the tranny and tcase would still fit. Obviously JH's did....
-Keegan-
Old 03-10-2015, 10:45 PM   #42
Nitis
Nitis's Avatar
So educate the idiot.
A. Is it feasible for say a stock th350 or 4l60e to sit that high
B. how would one accomplish this?
I am intrigued
Old 03-10-2015, 10:46 PM   #43
First c10
First c10's Avatar
Nitis I would agree with what you said. I have seen the crossmembers hit the block or the oil pan depending on how far forward or back the motor was.
GO GO!!!
Old 03-10-2015, 10:53 PM   #44
Nitis
Nitis's Avatar
Ok let's back up a tick
For the sake of argument lets just say one could raise the engine 2" with the stock crossmember this would eliminate the need for a lift.
Is that in anyway shape or form possible and is it enough for the block to clear the stock crossmember?
The reason for lifts is the crossmember a installed to accommodate the LS engine. Jimmy built a new crossmember
Old 03-10-2015, 11:06 PM   #45
GMC-YA68
GMC-YA68's Avatar
Anxiously awaiting a detailed response!
-Keegan-
Old 03-10-2015, 11:20 PM   #46
Nitis
Nitis's Avatar
I know there are pictures showing an LS hitting a stock crossmember. So how high does it need to be to clear and is there enough room for the transmission to be moved that far.
I find it tough to believe no one has executed this if its possible by now and also leads me to believe it's also why more than one outfit is producing a specific crossmember for these trucks.
Yes I'm skeptical yet optimistic
Old 03-10-2015, 11:32 PM   #47
DWilbur
Vintage Air said they will work for a while but the pressure they make will cause leaks in an older system that is normally lower pressure. the compressor does fit with the DD mount but hooking up the lines is the issue do to the truck mounting brackets for the compressor. The brackets from a car Camero or Vet might work.
Old 03-10-2015, 11:44 PM   #48
71chevystep4x4
71chevystep4x4's Avatar
I used my stock crossmember, but had to modify it of course. The passenger side is the one that the pan hit, so I cut out the rounded elbow, and squared it up so it would clear. Now, where the biggest modification took place was at the mount perches. The LS adapter plates were so thick, so it was too wide to fall into the cradle far enough to line up the mount holes, plus it was too narrow. What I did was cut out the bottoms of the perches so they'd clear the pan, then I had to elongate the holes a great deal in order to slide the perches down far enough till the mount holes lined up. As well as remove a few pointless tabs from the side of the oil pan, and one from the block. It's a tight fit, but I wasn't about to spend $450 on an alternative.
71chevystep4x4 is offline   Reply With Quote
Old 03-10-2015, 11:48 PM   #49
71chevystep4x4
CORRECTION: Slid the perches UP to widen the cradle, and I cut a bit off the top lip so they'd go further, otherwise they stop at the inside of the frame. The holes weren't elongated in the picture yet.
Old 03-11-2015, 12:11 AM   #50
First c10
First c10's Avatar
Hey D, that does make sense if I were running R134a. The pressures are considerably higher then on old R12 system. I am not sure about the two speed compressors. I just took the two wires from the stock AC system and plugged it into the 2011 compressor of coarse I have a bottle of R 12 hidden away so I was able to do this. I did have to install a trinary switch to turn on the cooling fans and shut the compressor off if the pressure is too high.
Okay back to the crossmember
I want to thank everyone that has chimed in regarding this crossmember issue. When I started this thread I could not find this information in one spot. I am going to attempt to build or modify the stock crossmember and keep the AC compressor in the stock location. I figure if I can keep the stock compressor in the stock location on my C 10 why not the K 10.
GO GO!!!
