07-02-2015, 10:38 PM | #26 |
Re: Donz '72 LWB Shop Truck...
That looks great.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
07-03-2015, 03:18 AM | #27 |
That is a amazing looking tattoo you did Don.
Scott |
07-08-2015, 07:20 AM | #28 |
X3........... the design and the artwork are truly amazing
Getting old sucks.............but it sure beats the alternative |
07-08-2015, 08:00 AM | #29 |
Thanks Guyz!
Although I can't take credit for the design.
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
07-08-2015, 09:52 AM | #30 |
Hi Don,
How's the plastidip holding up on the rims? Color matches my truck perfect and I'm looking for a different direction than paint. Thank for the Help. Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears |
07-08-2015, 10:13 AM | #31 |
It seems to be doing fine, although I don't drive it every day. A friend of mine has a custom shop and sprayed plastidip on his personal vehicle, he had it on there for awhile. I will call him and get his input...
07-08-2015, 10:23 AM | #32 |
Sounds great, thanks for the info. Good looking truck, I'm along for the ride.
Roger
07-08-2015, 03:57 PM | #33 |
I talked to my bud and he said that if you clean everything real well you shouldn't have any problems, and the good thing is, if there is a problem area, you can peel it off and buy the same color in a rattle can and touch it up...
07-13-2015, 10:15 PM | #34 |
I decided to do a bit of cleaning and painting before the oppressive heat of our typical Arkansas summer made it's entrance...
Here are the door panels after removal and prior to cleaning… IMG_4336 by Donald Olivo, on Flickr IMG_4337 by Donald Olivo, on Flickr The PO decided to add screws instead of new clips to secure the panels… So those were filled prior to painting... After cleaning and prior to the new color… IMG_4341 by Donald Olivo, on Flickr IMG_4342 by Donald Olivo, on Flickr I used Dupli-Color Dk Grey for vinyl and upholstery paint… IMG_4348 by Donald Olivo, on Flickr IMG_4349 by Donald Olivo, on Flickr Still need to order armrests...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 07-13-2015 at 10:18 PM. Reason: add comment |
07-14-2015, 05:26 AM | #35 |
Those came out looking real good!
07-14-2015, 01:22 PM | #36 |
X2 They look mint
07-15-2015, 10:18 AM | #37 |
Thanks Guyz...
Here they are installed, gotta get new armrests ordered… Untitled by Donald Olivo, on Flickr by Donald Olivo, on Flickr
07-15-2015, 04:18 PM | #38 |
That looks great! I'm going to add this one to the low buck build threads...today.
07-15-2015, 04:33 PM | #39 |
Two trucks at the same time you must be mad but I admire your dedication.
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
07-22-2015, 09:39 AM | #40 | |
Thanks mate!
07-22-2015, 09:43 AM | #41 |
Not much to report, other than it's HOT here in Arkansas so my motivation equals POOL!
On a somber note, my Mother-in-Law passed away this past Saturday so my focus has been on my lovely wife. I did get my new transmission cooler in this past Friday and am now finally getting around to posting a pic… Fittings are still wrapped up in the packing material… IMG_4495 by Donald Olivo, on Flickr
08-08-2015, 09:25 AM | #42 |
Nice trans cooler, I made a simple aluminium bracket for mine and mounted it out in front of the radiator so it would get plenty of cold air (not that getting cold air is much of an issue in north east england ).
I ran a couple of PTFE hoses from the original hard lines and routed them through the side of the radiator shroud. Turned out OK
08-08-2015, 10:10 AM | #43 |
New parts!
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
08-08-2015, 11:27 AM | #44 | |
08-08-2015, 02:13 PM | #45 |
Thanx Guyz… Diggin' the setup you used Ian...
Hit the Pick-N-Pull this morning and scored a P/S box for this one... Forgot my Pulley puller... so on my return trip to return the Brake Booster I grabbed, I will grab a P/S pump and pulley for this… Thanx to dwcardfan, I am going to get a 72 booster... Here's the donor of the P/S box IMG_4706 by Donald Olivo, on Flickr IMG_4707 by Donald Olivo, on Flickr Laterz...
08-08-2015, 06:18 PM | #46 |
Progress and parts in one day.
Not bad. Ian Brown, again a mod you did that I may have to copy, oils cooler.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
08-08-2015, 10:48 PM | #47 |
I'm in ! Keep the pics coming !
84 step side 87 swb |
08-08-2015, 11:13 PM | #48 | |
Thanks...
08-08-2015, 11:20 PM | #49 |
Although I bought a Brake booster as well, it will be returned as Donnie, aka dwcardfan, offered me a '72 booster he has lying around...
I'll use the credit from the booster to help cover the cost of the P/S Pump I need to go back for… Seems someone forgot their Pulley removal tool this morning so the pump is on hold for a couple of days…
08-08-2015, 11:49 PM | #50 |
nice work, truck and tattoo...
