Old 07-05-2015, 03:03 PM   #26
MusicMan70
MusicMan70's Avatar
Re: #$%@! Bent Push Rods
Anyone have a torque spec on the rocker arm bar bolts?
My manual says 20-25ftlbs for the rocker arm shaft bracket bolts.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 07-05-2015, 08:21 PM   #27
1976gmc20
I don't remember the heads on my 305 v6 being that terrible heavy, but I was a lot younger back then and pretty damn strong (worked in the timber every day!). Also, I had pulled the head on my old 4-cylinder Cat and that thing was really heavy!
Neither do I remember torque specs or order. I suspect that I just guessed back then, and the engine ran fine for years afterward, pulling heavy loads of logs. Those v6 GMC engines are pretty simple and tough, so as long as you don't do anything too stupid then you can't really hurt them. Too much rpm can be bad news, though.
Did you pull the distributor to remove the heads ??? You don't have to, you know I never did.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 07-05-2015, 09:12 PM   #28
wcstory
wcstory's Avatar
That is one of the few times I've guessed correctly. I did 25 as a educated guess.
Thank you MM
1966 GMC 1 Ton 305 V6 SM420 4 speed - retired Fire Dept Support Truck from Little Falls, NJ
My GMC Photos
wcstory is offline   Reply With Quote
Old 07-05-2015, 09:22 PM   #29
wcstory
wcstory's Avatar
Last night I spray bombed the heads.
Made some good progress today.
Clean the head and deck surfaces, cleaned the gasket surfaces, Re-assembled the heads, cleaned & painted the galley cover, installed galley cover, heads in & torqued, rocker bar in & torqued.
That bolt on the firewall side of the passenger side head was a SOB to access with the torque wrench. Had to use the old bend bar torque wrench for that one.
As it got dark I painted the intake and water neck housing.
My GMC Photos
Old 07-05-2015, 09:25 PM   #30
wcstory
wcstory's Avatar
Originally Posted by wcstory View Post
What's not to love about a motor that you can put a quart can into the cylinder.
forgot to add picture
My GMC Photos
Old 07-06-2015, 06:48 PM   #31
wcstory
wcstory's Avatar
Found it!!
My GMC Photos
Old 07-06-2015, 09:41 PM   #32
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Cool stuff! Hey, the 478 had a 5.125 bore. lol!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-13-2015, 09:34 PM   #33
wcstory
wcstory's Avatar
Got the rest of the top end assembled.
I pulled the spark plugs out and put marvel mystery oil in the cylinders before turning the engine to install new push rods and set the cold lash to .020.
A little gas in the carb and she fired up. Let her idle as I added the rest of the coolant and tightened leaks.
After she got good and hot I set the lash to .012 on intake and ,018 on exhaust valves. I need to grab a timing light and set the distributor properly. She still spits and sputters under load.
Wondering if I should just drop in the new HEI, kind of wanted to address one issue at a time.
My GMC Photos
Old 07-13-2015, 11:15 PM   #34
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
How was it? lol I disassembled and reassembled the top end of my 305 in one day....whew what a Loooooong day. lol Least your heads and covers don't have grease marks all over them like mine do! Spitting and sputtering under load sounds like a carb, timing, or vacuum problem.
Old 07-14-2015, 03:50 AM   #35
wcstory
wcstory's Avatar
If I wasn't trying to clean, wire brush and paint everything it would of taken a heck of a lot less time
Mechanically she seems fine, I think it's the carb and ignition I have to battle with next.
https://www.youtube.com/watch?v=PBLQRVSzU2U
My GMC Photos
Old 07-14-2015, 10:39 AM   #36
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
It won't let me see the video.
Old 07-14-2015, 09:58 PM   #37
wcstory
wcstory's Avatar
Tried to embed video with no luck
My GMC Photos
Old 07-17-2015, 08:22 PM   #38
wcstory
wcstory's Avatar
Well after all that work she still wasn't running worth a hoot above idle.
Started re-checking everything. Valves lashed properly, checked the carb for vacuum leaks checked the distributor cap & wires for good connections, checked the spark plug wires twice to make sure they were in the correct spot (I marked them where they came from) - see a flaw in my thinking
Yes folks I didn't check to see if the plug wires were in the RIGHT order before marking. 1 & 2 were flipped. DOH!!! Stupid human tricks again.
She still wouldn't stay running for more than a few seconds. Start tapping the gas tank....hollow, hollow, hollow.... You have to be kidding! Empty 5 gallon mower gas can into tank. WooHoo!! I twisted the distributor till it sounded decent and tightened it down. Hell with the timing light I was going for a ride!
It's amazing how much better they do when you use the factory firing order.
A few laps around the development weren't enough so I got adventurous and grabbed my wallet and cell phone. Drove all the way to the local gas station to put 10 gallons in and then back home....2.5 miles round trip, maybe 3 if you count the neighborhood victory lap, but it still felt good , damn good.
Manual steering, bias ply tires and 4 something gears definitely made her feel like a truck.
Now I'm even more impressed! Cylinders 1, 3 and 4 had stuck valves or popped push rods - 0 compression. Cylinder 2 had the wrong plug wire. So she was running on 2.5 cylinders. That's impressive.
My GMC Photos
Old 07-17-2015, 09:53 PM   #39
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Don't underestimate a GMC V6. lol
Old 07-18-2015, 12:15 AM   #40
wcstory
wcstory's Avatar
And don't underestimate the online community.
Thank you
My GMC Photos
