Old 12-29-2015, 11:28 PM   #26
64nlo
64nlo's Avatar
Re: 22" Gm Transport wheels
what size tires are you running on there? what kind of bag setup are you running?
64nlo is offline   Reply With Quote
Old 12-30-2015, 12:11 AM   #27
Ghernandez66
Ghernandez66's Avatar
245/30R22 and what do you mean by kind of bag setup up?
Ghernandez66 is offline   Reply With Quote
Old 12-30-2015, 12:35 AM   #28
four door
I went with 265/35/r22 - little more common but taller set up than ghernandez
four door is offline   Reply With Quote
Old 01-12-2016, 09:49 AM   #29
4mulaSvaliant
4mulaSvaliant's Avatar
Just to chime in here with spacer and tire sizing...
Just finished making it possible to fit these on my 64.
Tires: 285-40-22 (all 4)
Static drop:
Front: 2.5" drop spindles / 2" drop springs
Rear: 5" drop springs / 2" drop blocks
Front mounting:
Disc brake conversion up front: Has the correct size hub dia. for these wheels
(Orig front drum "centric hub" on the drum is too large for these wheels and either a spacer is needed or opening up the bore on the wheel is needed)
Rear mounting:
I was given some 1-1/2" spacers for the rear. SO I used them of course.
(I would suggest a 1" or even a 1-1/4" at the most ****STEP SIDE BED*****)
Now all of that said... I love the look of filled out wheel wells. (width wise as well as diameter wise)
Its because of this and the fact that my spacers were given to me, that I ran the 1-1/2" spacers in the rear. I have roughly 5/8" between the inside of my tire (285-40-22) and the bed side (STEP SIDE BED).
I had to make adjustable fender struts to push the fenders off of the outer edge of the tire. I needed roughly a 1/4" to get off the tire, but adjusted it out about a half inch total, leaving a very tight 1/4" gap.
The front tires with the mentioned static drop will turn lock to lock with no clearance issues. The closest item to touching is the manual steering gear box. I also have a CPP sway bar and it clears that just fine as well.
Where I am closest and have rubbed (under full compression from large bump in the road) is to the floor board at nearly full lock at either side. The other place it is very close is at full lock in the center of the fender opening (fender lip). At full lock I can barely get my pinky finger between the tire and fender. This just causes me to enter driveways a lot slower, but hasn't been a major issue.
Here are a few pictures.
I have always had a "muscle truck vibe with my truck and wanted to keep it. Hence my tire choice. I feel I manged to keep the "tough" look I like.
Front fender clearance (wheels straight) Disc brakes..... so no spacers
This is all the room I have when turned to "full lock" under the fender lip
Closest spot to touch: Floor board at nearly full lock
This is the clearance to the bed side. Looking forward from rear of truck.
Adjustable fender struts (1 in front of the tire, and 1 behind the tire) This is the passenger side looking from the back of the truck.
Hope this helps a few of you! I love em!!!!!
64 LWB to SWB Step build. Daily driven!
http://67-72chevytrucks.com/vboard/s...d.php?t=647168
4mulaSvaliant is offline   Reply With Quote
Old 01-12-2016, 12:59 PM   #30
60chevyjim
60chevyjim's Avatar
nice truck , like the wheels too.
and I like the adjustable fender strut idea too
60chevyjim is offline   Reply With Quote
Old 01-12-2016, 06:37 PM   #31
Juice63
If it isnt my pal Donnie. Thats a great looking truck pal. I cant wait till I can also complete that project. You are always so helpful and full of knowledge. thanks for the post pal.
Juice63 is offline   Reply With Quote
Old 03-21-2016, 09:28 PM   #32
Dutch Checkers
How did you pull off the Hun caps?
Dutch Checkers is offline   Reply With Quote
Old 03-21-2016, 09:30 PM   #33
Dutch Checkers
Hubcaps. Sorry. I've been looking at options but can't figure out way to make cap work.
Old 03-21-2016, 09:32 PM   #34
Ghernandez66
There's a guy in instagram that's selling clip kits so you can install hubcaps on transit wheels they seem to have great positive feedback I got a set but haven't installed it yet.
My 1st build 1966 C10 Swb ..http://67-72chevytrucks.com/vboard/s...d.php?t=668147
Old 03-21-2016, 09:40 PM   #35
Dutch Checkers
How can I find him on Instagram? Not real familiar with that
Old 03-21-2016, 09:42 PM   #36
Ghernandez66
His username is STRUGGLE_55 hope that helps I can ask him for email if you need it DM me
Old 03-23-2016, 06:27 AM   #37
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
struggle_55 **IMPORTANT ANNOUNCEMENT ** Due to increased shipping and material costs the #capclips kit pricing is changing. Starting today kits will cost $90 shipped in the U.S. And $100 to Canada, shipping included. Kit includes clips, template, fasteners, drill bit, and tap.
Old 03-23-2016, 06:33 AM   #38
aerotruk63
aerotruk63's Avatar
struggle_55 @fab.pro If you're in the U.S. Just send $90 to my PayPal quickier2@hotmail.com and leave your Instagram name and shipping info in the comments area. $100 for Canadian orders. 5d
Old 06-20-2016, 11:35 PM   #39
Dutch Checkers
Got them fitted now.
1 1/4" spacers to clear factory drums.
Still need to paint and add caps, but it's driving.
Old 06-21-2016, 06:07 AM   #40
aerotruk63
aerotruk63's Avatar
Did you find a loss in braking power?
Old 06-21-2016, 06:56 AM   #41
Dutch Checkers
Honestly couldn't tell you. Truck still has drums for now. Been a slow project. Can't remember.
Old 06-21-2016, 11:53 AM   #42
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by Conrad63 View Post
Has this been discussed in another thread somewhere? My searches came up with nothing. If it was discussed somewhere, would someone be so kind as to direct me to the thread? Thanks
IDK if this has been mentioned, but i didnt read. It says right on the rim that its not meant for road use.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 06-21-2016, 12:33 PM   #43
lolife99
67-72 parts collector,…
lolife99's Avatar
They are stamped DOT,... but I don't know if that's good enough for everyone.
Look at this thread:
http://www.gmfullsize.com/threads/22...wheels.293015/
Keith
Convert to disc brakes.
Old 11-13-2016, 03:38 AM   #44
Paulo
Thumbs up Re: 22" Gm Transport wheels
Originally Posted by Ghernandez66 View Post
Buy 1" spacers. 1/4 inch might be too small for rear and 1/2 might be too big to make em work with the stock studs at least that was my situation last week so I ended up going with one inch spacers from summit here check it out!
Attachment 1462777
What's up man! Let ask you I just bought the 22" gm transport wheels, I have 65 c10, and the thing the wheels won't feet the fronts the center of the wheels is to small and I don't know if fitz on the back, so what you did on yours to fit weel like that ? Can you please explain to me what you did on yours ?
Paulo is offline   Reply With Quote
Old 11-13-2016, 03:45 AM   #45
Paulo
Hello, hey man how did make it to fit on ur truck, I have a 65 c10 and I just got the 22" gm transport wheels but the wheels won't feet on the front, the center hole on the rims is to small for the hub and I don't know about the back. So can you explain to me how you did to make it fit ? Thanks man!!
Old 11-13-2016, 04:11 AM   #46
Ghernandez66
I did a disc brake conversion in the front and used the spacers mentioned and for the rear you will need the rear tubs out for this and if your bagged also the front inners..
Old 11-13-2016, 06:29 PM   #47
Dutch Checkers
I used spacers for rear. I also had to take out the stepside inner fender support rods and flare the fender out a little. Old school wooden baseball bat rolled style. Will post spacer pic.
Old 11-14-2016, 01:03 AM   #48
mr57
mr57's Avatar
I inquired at our local GM dealer and the parts manager told me these wheels were required to be made unusable by orders from GM, something to do about a pending lawsuit?? Once removed from the vehicle being transported they had to be drilled or cut up and disposed of.
1957 Chevy swb
1964 Chevy swb panel
mr57 is offline   Reply With Quote
Old 02-25-2018, 12:22 PM   #49
LowCST
I know this is an older thread but my hope is by now some more people have done this and some clarification can be had. I have a 1970 C10 long bed fleetside with a static 3/5 drop (so not super low) I have a set of these transports waiting to go on but I wanted to get the research side done before I tried anything. I have power drums front and rear. My questions are has anyone run this setup on the 67-72 trucks (the earlier posts just addressed earlier models) and what was needed to accomplish this setup if you do have them on your 67-72? Secondly with just the 3/5 drop will I have to eliminate front inner fenders? Wheel tubs in the rear? Thanks for any help here
LowCST is offline   Reply With Quote
Old 02-25-2018, 08:13 PM   #50
hewittca
hewittca's Avatar
I am running these on my '68 with a 4/7 drop. First of all you have to have the centers of the wheels bored to fit over the hubs on the 4 wheel drums. For the fronts, I am running 265/35s and have not had to do any clearancing (stock fenders and inners). I have not bottomed out or rubbed at all, but if I were to go any lower (which I plan to) I will have to do some modifications for clearance. In the rear, you can't run the stock transit because it has too much backspacing. You can either run a 1.25" to 1.5" adapter spacer like everyone above had to do, or flip the center of the wheel and change the backspacing. I changed the backspacing on mine to 4" but it did require a bit of clearancing to make it work. A more conservative backspacing would be 4.25", and with a 5" drop you should be fine and require no modifications.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
