Old 01-15-2016, 04:29 PM   #26
badseed
Re: LS oil pan and laying frame
Originally Posted by TwinsSpeedShop View Post
Well after mounting motor in drop member, the f body pan really doesn't fit. It is short enough but the sump is really to far forward. By the numbers the Holley pan is the best choice. I'm going to take some more measurements in the morning and order pan. If anyone needs an f body pan.... I got one !!
I have a truck pan on my c10 now. looking to possibly bag it with the stock cross member. Will this F Body pan work for it? The one now hangs below the cross member quite a bit. Out of town or I'd go measure how much.
If it will work, let me know how much and if it comes with everything I'd need to hook it up. I may be interested!
badseed is offline   Reply With Quote
Old 01-16-2016, 09:54 PM   #27
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
found an image of the specs on the Chevy Performance Parts Road race pan....
pan
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-27-2016, 11:45 AM   #28
bmfm64
bmfm64's Avatar
Which Holley pan did you end up with? I'm installing my DMs and need to swap pans as well. Did you do the 302-1 or the 302-2?
bmfm64 is offline   Reply With Quote
Old 01-27-2016, 12:03 PM   #29
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I used the Holley 302-2 pan. Check out my posts beginning with #35. I posted several pictures and comparisons. http://67-72chevytrucks.com/vboard/s...=685258&page=2
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-27-2016, 01:15 PM   #30
bmfm64
bmfm64's Avatar
Thanks Dan, that is great info in your link. My real question though was which pan would work better with the specific cross member hes running. I'm kind of leaning towards the 302-1 as it has 2 more inches of room for the cross member front to back but I'm still on the fence.
Thanks for your insight though!
Buddy
Old 01-27-2016, 07:13 PM   #31
boostedc10
boostedc10's Avatar
Running the 302-2 here with Nates dropmember. Plenty of room.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 01-27-2016, 07:58 PM   #32
bmfm64
bmfm64's Avatar
Anyway I could get you to post a pic or shoot me a text with a pic? 206227SixSix three. Thanks!
Old 01-27-2016, 09:16 PM   #33
Cobalt964ruf
Cobalt964ruf's Avatar
pan
yep, i posted that info on post 20 22 and 23 as well. its the shortest pan i have found.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 01-27-2016, 09:58 PM   #34
enduroride
enduroride's Avatar
"F" Body pan here also ! We are running a Porterbuilt Level 2 front and rear with bags. Frame sits on the ground ..... No pan issues here
2016 Silverado2005 GMC Sierra
2002 Chevy Slverado Extra Cab (youngest sons)
2009 GMC Denali (oldest sons)
2015 Lexus 250i (wifes)
1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY"
http://www.louisianaclassictruckclub.com
enduroride is offline   Reply With Quote
Old 01-28-2016, 12:54 AM   #35
boostedc10
boostedc10's Avatar
My frame in these pics is about an inch off the ground. Only due to my hitch safety rings hitting the ground first.
As you can see there is plenty of clearance with the pan both up front and in the rear.
Let me know if you have any additional questions on this pan.
This also shows that the fbody pan works fine too, as others have stated.
Brandon
Instagram: DRVFSTR
Old 01-30-2016, 10:15 PM   #36
TwinsSpeedShop
Pan has sold locally
TwinsSpeedShop is offline   Reply With Quote
Old 03-01-2016, 07:57 PM   #37
88k5jimmy
From your pics it looks like you're running a GSI front suspension. Scott @ GSI told me to use the Holley 302-1 pan. Did you end up using that pan? I've heard you have to slightly modify the windage tray. Did you have to do that?
88k5jimmy is offline   Reply With Quote
