12-23-2015, 05:50 PM | #26 |
Re: 250 to 5.3 swap
I cut the ends of the fuel sender lines so that compression fittings could be installed, then I used an assortment of Dorman Products fuel line repair parts, Dorman nylon fuel line (3/8, and 5/16) for my delivery and return lines. Using AN fittings and stainless sheathed fuel lines was too much for my fixed income (I'm retired). The most expensive part of the fuel system is the tool for inserting the fittings into the lines, but worth every penny for quick and correct assembly. It also helped having a hydraulic flaring tool with the correct dies to make the connection point on the outlet side of the filter/regulator
So far, the system has been trouble free Lee Last edited by LeesTruk; 12-23-2015 at 05:59 PM. |
12-23-2015, 06:22 PM | #27 |
Re: 250 to 5.3 swap
Here's your part numbers
800-155 12" double beaded line 3/8" 800-154 12" double beaded line 5/16" (I only used one side of the line) 800-074 5/16" fuel line (10' roll) 800-075 3/8" fuel line (10' roll) 800-80 5/16" connector (2pc. box) 800-82.5 3/8" connector (5pc. box) 800-301 fuel line tool All of this can be had, at Amazon or online somewhere, but most real auto parts stores will usually carry the parts. The tool they will probably have to order Lee |
12-23-2015, 08:07 PM | #28 | |
Re: 250 to 5.3 swap
12-23-2015, 09:06 PM | #29 |
Re: 250 to 5.3 swap
On your AC compressor, where did you get those 90* fittings? I need something like those on my LSx swap too.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
12-23-2015, 11:12 PM | #30 | |
Re: 250 to 5.3 swap
https://coldhose.com/specialty-fitti...-adapters.html Search that page for "GM 5.3L Compressor Blocks" |
12-23-2015, 11:16 PM | #31 |
Re: 250 to 5.3 swap
Yep, that's where I got 'em
12-30-2015, 01:43 PM | #32 |
Re: 250 to 5.3 swap
Great thread and nice work!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-28-2016, 06:58 AM | #33 |
Re: 250 to 5.3 swap
Well, it's been a year now, since the truck has been put together, so I thought I'd give sort of a "follow up". After some initial problems, which turned out to be a faulty PCM, and the "usual" new build bugs, the truck has been a real pleasure to drive!! Start-up is immediate in any temp., acceleration is tremendous (and scary if not paying attention), easy to drive, and a surprise in fuel efficiency/economy (19-20 mpg hiway). Overall, I couldn't be happier with the swap
Lee |
12-28-2016, 11:52 AM | #34 |
Re: 250 to 5.3 swap
This was VERY helpful. i just ordered all the parts for the fuel system you used and posted here. Can you tell me what fuel pump and filter you used? My truck has a 4.8 with a return rail that I plan to use so I don't think I need a separate regulator as that system on the motor should take care of it, but I still need a pump and filter. The sending unit I bought is a Spectra Premium FG05M and I THINK the pump I need is a Spectra Premium SP1115 in tank pump. Thanks!
12-28-2016, 06:01 PM | #35 |
Re: 250 to 5.3 swap
Mr. Roberts, I gather your truck is pre-1973 so I don't know what tank you're gonna use. Concerning the fuel pump, I used an ACDelco e381 pump (in tank). You can also use a Delphi FE0114 pump (in tank) . For your filter, you can use an ACDelco GF652 (or equiv.). It has a threaded boss on each side, but you can get two of Dorman #800-170 (one for each side of the filter) and plug in the nylon fuel Lines (fuel in, fuel out) or you can use a Fram #g8219 (or equiv.) filter. It has a threaded boss on one side and a nipple on the other. In this case, you'd only need one of Dorman #800-170, then just plug in your fuel lines. For your return, just run your fuel line from the fuel rail back to the return side of your fuel bracket in your tank. BTW, the pumps and filters I've listed, are from a '97 Silverado. That should help with your conversations with whom ever you get your parts from
Lee |
12-29-2016, 06:55 PM | #36 |
Re: 250 to 5.3 swap
NICE fuel system...
12-30-2016, 08:46 PM | #37 |
Re: 250 to 5.3 swap
Thank you, sir. Sometimes simple is good
12-30-2016, 09:30 PM | #38 |
Re: 250 to 5.3 swap
This is how I modified my sending unit.
12-30-2016, 09:31 PM | #39 |
Re: 250 to 5.3 swap
Added to this. I have a 1980 GMC Sierra, C15.
12-30-2016, 09:34 PM | #40 |
Re: 250 to 5.3 swap
Good luck.
12-30-2016, 09:43 PM | #41 |
Re: 250 to 5.3 swap
This my forth LSx swap. You just can't beat them.
01-03-2017, 10:51 AM | #42 |
Re: 250 to 5.3 swap
01-03-2017, 10:41 PM | #43 |
Re: 250 to 5.3 swap
Enroberts, I had them crazed on.
03-14-2017, 08:30 PM | #44 |
Re: 250 to 5.3 swap
1967custom |
03-15-2017, 06:15 AM | #45 |
Re: 250 to 5.3 swap
You have to make it yourself. All of the stuff is from Dorman Products and should be easily obtainable from an automotive parts store or you can get the parts from an online source (Amazon, Ebay, etc.). I highly recommend getting the tool for inserting the fittings into the nylon line. It makes assembly a snap, once you figure out how to use it (no instructions come with it). I can post some pics of how to set it up, if needed. Also, make your turns gently, as the tubing will kink if the turn is too sharp! Overall, it's very cost effective and easy to use
BTW, just buy the parts as listed previously. Don't buy the whole fuel line kit from Dorman. It's way too expensive and it contains stuff you'll never ever need/use Lee |
03-15-2017, 06:45 AM | #46 |
Re: 250 to 5.3 swap
Yes please! This looks like a great solution for us 'chrome don't get ya home' guys. But the tool looks a little intimidating for an old guy like me.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
03-15-2017, 09:40 AM | #47 |
Re: 250 to 5.3 swap
I'll be watching too..Getting ready to do the fuel system soon.
Thanks. Lee |
03-15-2017, 10:10 PM | #48 |
Re: 250 to 5.3 swap
Ok, here's a quick tutorial of how to use the Dorman tool (800-301) and how to make a fuel line with coupling. I'll be using the 3/8" nylon line and fitting
The first step is setting up the tool with the clamp (similar to a tubing flaring tool) and the fitting fixture Insert your tubing into the clamp with about 1/4" protruding Use some light oil of your choice, lubricate the barbs (makes insertion easier) then install your fitting onto the pointed fixture Next, push the tool fixture and fitting into the tube opening then squeeze the tool handle until the fitting is fully inserted into the tubing The finished product. It's that easy If you check the filter/regulator picture, you'll see the input side has two nipples made into it (3/8", 5/16"). The output side has a female receiver. I made a short double ended male tube, made from the Dorman 12" steel line. This line only has one barbed end, so I used my hydraulic flaring tool and fuel fitting die to make the second male end to insert into the regulator, then just plugged the new fuel line onto it. Don't try heating the nylon tube and think you can just push a fitting into it. The nylon will not get soft and pliable. Also, it doesn't have a memory, meaning it won't just go back to what size it was, forming a tight seal. Once it's out of shape, that's the way it remains! Lee |
03-16-2017, 06:16 AM | #49 |
Re: 250 to 5.3 swap
AH, I see. You needed a male end to mate to the FFR, which you made from steel line. The other end fits the nylon fitting. Question - is the required end for the steel line to the nylon fittings a simple bubble type flare, a barb flare (like the vapor line shown in your sender unit picture), or just straight line?
BTW thank you very much for the info.
03-16-2017, 07:00 AM | #50 |
Re: 250 to 5.3 swap
If you look at a picture of Dorman double beaded line (800-155) you'll see how the lines are connected. It's neither a bubble nor barb, but a raised surface that is formed when the line is compressed on itself. The fore mentioned line is 12" in length, but I thought it would be too much leverage on the FFR. That's why I shortened it to about 2". I suppose if you anchored the output line and FFR really well, then there shouldn't be a problem
