Old 11-09-2015, 09:25 AM   #26
solidaxel
solidaxel's Avatar
Re: Accessory drive brakcets with L99 water pump
Originally Posted by aod92 View Post
I used the ls simple bracket on my motor and I love it. It came all assembled too so it's really easy to install.
Thanks I guess I do not know what I am looking at!
Maybe I am seeing a idler pulley and not a PS pump
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-09-2015, 06:31 PM   #27
FarmerSid
FarmerSid's Avatar
Solid, Go to the LS Simple web site and look under the the truck kits. there you will see with or without PWR steering pump.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 11-09-2015, 06:45 PM   #28
aod92
aod92's Avatar
Correct it's an idler pulley. No ps pump on my motor. Call ls simple and the owner will let you know exactly what you'll need. He's very helpful and has great customer service!
aod92 is offline   Reply With Quote
Old 11-09-2015, 09:35 PM   #29
67chevy1series
67chevy1series's Avatar
Aod92 does your water pump work with the truck crank pulley? Meaning does the belt line up from the water pump pulley to the truck crank pulley? (That is assuming you crank pulley is from a truck)
67chevy1series is offline   Reply With Quote
Old 11-09-2015, 09:39 PM   #30
aod92
aod92's Avatar
Yes it does. I'm using a truck crank pulley with a f-body water pump. The water pump has spacers behind it that ls simple also supplied. The spacers even have a threaded port for the steam vent tubes.
Old 11-10-2015, 02:54 AM   #31
izzy_Britton
izzy_Britton's Avatar
Thanks for the tip, just checked out there website and I really like this kit!
I am unable to locate this kit on the lssimple website. what is the price you found? i like that!
TIA
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 11-10-2015, 06:22 PM   #32
67chevy1series
I liked that kit until something was brought to my attention, the belt doesn't have much wrap on the crank pulley and power steering, could shorten the life of the belt and make a mess
Old 11-11-2015, 02:30 PM   #33
roushinator
roushinator's Avatar
this is what i used.... I have a 2014 L99
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 11-13-2015, 10:22 AM   #34
Hart_Rod
Hart_Rod's Avatar
Holley setup on a LS1 and a LS3
Hart_Rod is offline   Reply With Quote
Old 11-13-2015, 10:53 AM   #35
FarmerSid
FarmerSid's Avatar
Very nice setups. I don't get why the A/C compressor and ALT are so wide compared to the high dollar Vintage Air, Billet Specialties or March Performance setups. Holley and Dingo make some nice, affordable stuff but wish they would tuck things in much closer.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-13-2015, 11:00 AM   #36
izzy_Britton
EXACTLY!
I have not got my engine out of the donor yet, but I am wondering what sort of modifications can be made to keep everything tight still use the a/c pump.
-Izzy
Old 11-13-2015, 11:15 AM   #37
Hart_Rod
Hart_Rod's Avatar
Originally Posted by izzy_Britton View Post
EXACTLY!
-Izzy
The Holley/Dirty Dingo/Allan grove brackets are all designed for simple and somewhat cheaper installation using mostly factory components. You can piece it together and pick and choose whether you want AC or PS, kind of a modular design with an economical price.
Vintage Air/BS and March to a degree started building brackets for early year high end streetrods (20s/30s/40s) that required a compact design and some one-off components. They weren't made with economy of price in mind. You pretty much have to buy their whole kit and you can't just run down to the parts store to buy replacement parts.
Just my $.02, .
Old 11-13-2015, 11:50 AM   #38
FarmerSid
FarmerSid's Avatar
I just called March Performance and talked to a very helpful guy. Seems that the reason they can tuck the ALT and A/C in nice and close is that everything is spaced out from the block more. A/C compressor would hit the passenger head set at Vette or F body spacing. He said that there is 8" from the water pump mounting surface on the block to the pulley. I assume that is the outside face of the pulley. You have to run their water pump also. They press on a different pulley he said. Not fussy on that having to go to them for a new pump if mine fails. Brackets are compatible with a Vintage air A/C compressor but the ALT bracket uses a GM ALT but not a truck or F body ALT. That's how I understood him.
I know I need all the space I can get between the accessories and the rad in my build.
Food for thought.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-13-2015, 06:33 PM   #39
solidaxel
solidaxel's Avatar
Have you looked at Kwick something?
We had to use one of there A/C brackets and a B S hard line from the compressor but it cleared the inner fender
The Alt P/S bracket is truck and truck water pump
LS 3 4L70E
Old 11-14-2015, 04:46 PM   #40
donandal
I used Kwik performance brackets on my AD project.
The routing tag was made by my brother at the shop
he works at.
donandal is offline   Reply With Quote
Old 11-14-2015, 07:35 PM   #41
aod92
aod92's Avatar
he works at.
That routing tag is really cool
Old 11-14-2015, 07:39 PM   #42
FarmerSid
FarmerSid's Avatar
Haven't seen that setup donandal. Gonna have to pick your head as I'm using C4 stuff too.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-14-2015, 09:46 PM   #43
donandal
Yeah,
He's a tool and die maker, and can make some cool things on
their CNC machines that I can't do in my shop.
Plus, he comes up with some cool ideas.
My shop is all old school milling, sawing and lathe equipment.
Old 11-14-2015, 11:44 PM   #44
solidaxel
solidaxel's Avatar
he works at.
Kwick must have different brackets for the A/C pump
LS 3 4L70E
Old 11-15-2015, 12:28 AM   #45
ls1nova71
ls1nova71's Avatar
he works at.
I like the routing tag too, thats a nice detail! But on that set up, will you have to pull the radiator hose to get the belt on? That would be a little inconvenient.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-15-2015, 11:39 PM   #46
67chevy1series
Routing tag is very cool! I felt like making what appears to be a original sticker for 67 showing the routing for the belts
Old 11-15-2015, 11:42 PM   #47
67chevy1series
Went to Pleasanton Goodguys show this weekend and seen this LS3 on a stand I like the accesory drive for the alternator and power steering bracket set up but cant seem to find a part number for the brackets alone. This is the E-Rod motor.
Old 11-16-2015, 12:29 AM   #48
67chevy1series
Alright found the part number, will a truck harmonic balancer/crank pulley like on a LM7 5.3 work with that style FEAD system?
Old 11-16-2015, 02:56 AM   #49
izzy_Britton
I have been looking into this type of stiff for my ls swap too. everything to anything.
BUT i believe the E-ROD is a whole other beast than a typical LS engine. they use their own computers, wires and components that do not seem to be the same as any of the typical production parts. yes the basics seem to be the same, block, head and maybe intake, but looks like the brackets, accessories and other stuff like as mentioned, wire harness, computer, and things like fuel rail, throttle body are all different. it LOOKS like according to the GM performance parts catalog that is. hard to say without hand in hand comparison.
i do like this belt set up but i want to keep my A/C. cool find!
Old 11-16-2015, 07:07 AM   #50
donandal
Yes,
You will have to pull the hose.
You have a good eye for this stuff.
And, it just passes above the air intake by about half an inch.
I am quite happy with the setup so far, but I haven't even run it
yet.
