12-23-2015, 01:37 AM | #26 |
Re: Opinion's wanted
That is good to know. Even with the power of my stock 5.3 it doesn't need to be running 2500 rpm or more on the interstate just cruising.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
12-23-2015, 07:44 AM | #27 | |
Old member
this is going to make the decision a lot easier for me. The 3:42 looks like the best for all round driving. I think the 3:08 would be a little off the mark. I run 10% ethnol. My motor combo came out of a 2003 H/D 2500! The motor had 89,000 miles on it so he said when installed. I haven't done nothing but plugs and new Knock senor's when installed. Oh and new water pump. Ok now I've pretty much decided on the 3:42 how about positraction units!
12-23-2015, 08:50 AM | #28 |
andy, with the ease of driving that you do, you will see the best MPG pick up ditching the 80!! Have someone build you a good 60 and change your harness out and see what that nets you. The simple fact that its a 6.0 means its not going to get great fuel numbers but it will make great HP and TQ numbers. LIke someone stated before, 6.0/4l60 combo will get in the upper teens.
As for Posi units, I put a Detroit Tru Trac in my step side truck and liked it a lot. Its all gears and no clutches so it will last much longer and had great smooth engagement. Just my .02 |
12-23-2015, 12:03 PM | #29 | |
Old member
As far as the posi units I don't know. I'm going to be looking over the holidays and seeing what I can find.
12-23-2015, 09:35 PM | #30 | |
The final gear (overdrive) difference between the 4L60E (.70) and 4L80E (.75) is only .05. This equates to less than 200 RPM reduction at 80 mph with your 4:10 gear ratio. I think you're on the right track by changing your gears to 3:42.
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project |
12-23-2015, 09:49 PM | #31 | |
Old member
12-23-2015, 10:15 PM | #32 |
this is what i went with
http://www.summitracing.com/parts/et...-010/overview/ dont forget you will want a series 3 carrier for the 3.42 combo |
12-23-2015, 10:21 PM | #33 |
Out West these guys are pretty well known in the business. They know their stuff on Dana.
http://www.sixstates.com/products/products.jsp p.s. I do not work there, or am employed by them in any way. |
12-23-2015, 10:21 PM | #34 | |
Do you have a local speed shop in your area that sells parts at a fair price?
12-23-2015, 10:25 PM | #35 | |
12-23-2015, 10:27 PM | #36 |
Old member
I have a buddy who has his own shop. I plan to go by tomorrow and talk to him since I'll let him do the install anyway!
He was taught by the best Mechanic I have ever known and that would be my dad. My dad was the GM training center Chevy head instructor in Charlotte NC for several years and my friend went through his classes on all the stuff he taught back in the late 70's early 80's.
12-23-2015, 10:31 PM | #37 | |
Old member
12-24-2015, 02:47 AM | #38 |
yeah ring and pinion is separate and you'll need an install kit (bearings/shims/seals)
12-24-2015, 02:50 AM | #39 |
here is mine
12-24-2015, 09:28 AM | #40 |
Old member
Cool! Thanks. I'll be checking prices over the next few weeks and buying one I hope.
This is a complete kit with everything. http://www.ebay.com/itm/GM-8-875-CHE...FUvTv6&vxp=mtr
12-24-2015, 04:18 PM | #41 |
Hey Andy,
I see Eaton doesn't make a True Trac in the 3:42 and higher gear ratios. They only build them for 3:73 and lower in our trucks. Walker is using the Eaton Posi which is a very good unit also. I have used this system in a 69 Camaro with a big block that truly made over 500hp, pulled over 7000 rpm and power shifted the heck out of it with absolutely no problems. Sure wished I still owned that Camaro. Mike
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project Last edited by redbaron; 12-24-2015 at 06:06 PM. |
12-24-2015, 04:27 PM | #42 |
You -might- be able to get away with a True Trac and a spacer in the lower numerically range.
I too have the Detroit Locker True Trac - haven't driven it enough yet to know much about it. Seems pretty tight at the moment, I'll have to do some circles. But I have one in my Camaro as well and have never had a problem.
