Old 01-10-2016, 01:43 AM   #26
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: exhaust question
You can weld them on, the manifolds are cast steel not cast iron.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-10-2016, 02:13 AM   #27
Root2812
Root2812's Avatar
Thanks for the info. That is good to know. Maybe I will go with those instead.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 01-10-2016, 02:17 AM   #28
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Which ones did you post in that pic? They looked like they exit straight down, which wouldn't clear most of the things I've put LS motors into...but I've never put a motor in an AD.
Old 01-12-2016, 11:23 PM   #29
Root2812
Root2812's Avatar
Mine are 2002 ZO6 Corvette manifolds. They don't exit straight down but pretty close. I'd say 40 degrees from straight down, not quite 45 degrees. I had my engine in my frame for mock up and they cleared everything except one of the ears where the y-pipe flange is rubbed on my boxing plate because I boxed the frame. I already clearance the boxing plate so they clear but everything is tight in the narrow AD frame.
I was thinking that if I welded on a v-band like you suggested I could grind the factory flange ears off for even more clearance. Maybe even weld a 45 degree pipe on and then the v-band so it gets down and curves parallel to the frame rail... That's just an idea though.
My 1950 Chevy build
Old 01-13-2016, 02:26 AM   #30
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You could but you'll need to use a thicker wall tube to do so. For strength reasons on a manifold, I wouldn't go from thick cast->thin pipe->flange. The joint at the thin pipe to the casy would be a natural weak point.
If you need that departure angle, you can angle the vband flange itself off the manifold as long as you have enough shoulder for the clamp to secure without binding. Otherwise just put the flange on flat, and build the egress angle onto your downtube/midpipe on the exhaust side.
Old 01-13-2016, 10:24 AM   #31
slotard
There's a thread in forced induction on ls1tech where someone sent a manifold out and the chemical composition was indeed cast iron, with close to 4% carbon. That said, I rarely hear of problems welding them (which surprises me).
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 04-12-2016, 06:13 PM   #32
aod92
aod92's Avatar
Brew what universal x pipe is that?
aod92 is offline   Reply With Quote
Old 04-12-2016, 07:45 PM   #33
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Which one? The one on my truck now is an H pipe from summit that I put together.
