Old 11-18-2016, 03:15 PM   #26
adzints7
Junior Member
Re: 67-72 Suburban OE seats
I recently picked up a suburban and it is missing the second row brackets for the middle seatbelts. Does anyone know if there are any aftermarket manufactures of these brackets?
adzints7 is offline   Reply With Quote
Old 11-18-2016, 03:18 PM   #27
adzints7
Junior Member
Photo is upside down, but you can see all three belts are attached on the side barckets. So the passenger side male, female and middle male are all on the same bracket and bolt. Same with the other side.
Old 11-18-2016, 04:52 PM   #28
RedRoad
RedRoad's Avatar
There are no repros but I have purchased some on this site and ebay fairly cheap.
RedRoad is offline   Reply With Quote
Old 11-18-2016, 06:09 PM   #29
Bigdav160
Bigdav160's Avatar
If it originally had four brackets (Like Redroad said - not reproduced) there should be holes in the floor under the carpet. That's where my seat belts were bolted. Through the floor.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-18-2016, 06:34 PM   #30
adzints7
Junior Member
Like these? There are holes, or I can redrill.
Old 11-18-2016, 09:17 PM   #31
Bigdav160
Bigdav160's Avatar
Those brackets are just like the OE used. My '73 Camaro has identical ones.
I'd have to look under my Suburban but I think there is a crossmember with the nuts attached already for the second seat.
The third seat, IIRC added another crossmember.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 11-20-2016, 05:47 PM   #32
adzints7
Junior Member
Great, thanks for the help!
Old 11-22-2016, 03:42 PM   #33
Bigdav160
Bigdav160's Avatar
Under your carpet should be this:
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 12-10-2016, 10:09 AM   #34
iriereggaeman
iriereggaeman's Avatar
VectorIT - I recently purchased a '72 Suburban. I'm wanting to put in a 3rd row seat. 1st and 2nd row seats are from early 2000's Tahoe. While getting my brain wrapped around what my options might be, I noticed the floor behind the second row is wood. I assumed it was replaced after the original floor rusted out. I see in one of your photos wood as well. Now I'm second guessing my assumption. Is the wood something original from the factory!?
iriereggaeman is offline   Reply With Quote
Old 12-10-2016, 10:48 AM   #35
Bigdav160
Bigdav160's Avatar
The floors were originally wood. Plywood in the Suburban. I presume oak strips, in a panel.
If ordered with the third seat an extra metal reinforcement was placed under the floor between the wheel wells.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 12-10-2016, 11:20 AM   #36
WannaBe68
WannaBe68's Avatar
BigDav is on the mark...
Plywood was the factory floor - I didn't know this either when I first picked my Burb up in Cali.
WannaBe68 is offline   Reply With Quote
Old 12-10-2016, 01:25 PM   #37
iriereggaeman
you guys rock. One more mystery for this newb solved. Thanks!
Old 12-13-2016, 12:41 PM   #38
Travisarmenta
Travisarmenta's Avatar
As far as i can tell my SPID says AS3 REAR SEAT, but it has the long brackets, is this just a typo?
Travisarmenta is offline   Reply With Quote
Old 01-24-2017, 02:46 PM   #39
THI
Active Member
THI's Avatar
Originally Posted by WannaBe68 View Post
My question is - I have to mail the front and 2nd row seat covers to Cars Inc before they can make the reproduction covers. If Cars Inc makes 2 of the same covers from the one original pattern of my 2nd row seat I send them...will that extra cover fit the 3rd row? In other words - are the 3rd and 2nd row bench seats the same? My 2nd and 3rd row seats both measure about 50" wide...
I am new here and was looking for the answer to this question - did not find it. I currently do not have the third seat in my 1970 Suburban (am looking for one) but once I get one I will recover all the seats. So basically, are the covers for the narrow second seat the same as the ones for the third seat?
Thank you.
THI is offline   Reply With Quote
Old 01-24-2017, 03:02 PM   #40
Huggerorangeblood
Yes
Huggerorangeblood is offline   Reply With Quote
Old 01-24-2017, 04:45 PM   #41
THI
Active Member
THI's Avatar
Originally Posted by Huggerorangeblood View Post
Yes
Thank you, that is a lot of help!
Old 01-25-2017, 10:59 PM   #42
Jens Jimmy
The second and third row are different. The second row is shorter, to allow a passenger to get in the third (back) door and get to the rear or third seat. The third seat is longer. I hope that helps
Jens Jimmy is offline   Reply With Quote
Old 01-25-2017, 11:39 PM   #43
WannaBe68
WannaBe68's Avatar
Are you sure about this? Both my 2nd row and the 3rd row seats both measured at about 50". 2nd row is off center, but the 3rd row fits between the wheel wells- Hers's a rough drawing -
Old 01-26-2017, 03:15 AM   #44
vectorit
What?
vectorit's Avatar
The two back seats, 2nd and 3rd. Assuming that the 2nd is a "3/4" are both the same widths. The only thing different about the two are the mounting brackets. Width wise, they are the same.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-26-2017, 09:42 AM   #45
Travisarmenta
From what I read the rear seat of a suburban is identical to the rear seat of a K5 , both seat and brackets wise , there also is a metal cross member that is mounted under the plywood in order to mount the rear seat, and as far as the middle seat of the suburban's those are in it self the only brackets that are organic to said spot and I don't ge and as far as the middle seat of the suburban's those are in it self the only brackets that are organic to said spot.
Old 01-26-2017, 09:53 AM   #46
Bigdav160
Bigdav160's Avatar
Here are the three option codes and dimensions. I should add, I think on my SPID, AS3 is labeled "Rear Seat" but is actually a full width center seat.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 02-12-2017, 11:04 AM   #47
pons0030
Hi,
Since I bought a 1968 GMC C1500 Suburban. I will be here more often. I live in Amsterdam, The Netherlands. My GMC has the second bench. I have a hard time finding proper seat covers to match the front bench. Any tips? Also door panels for the rear side are not easy to find. Will the front door panel fit?
Any info will help!
pons0030 is offline   Reply With Quote
Old 05-13-2017, 11:59 PM   #48
goldenburb
goldenburb's Avatar
I bought this seat 5 years ago for $20 bucks. Is it a burb or blazer seat??
I think it's original seat cover?
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 05-14-2017, 07:42 AM   #49
Bigdav160
Bigdav160's Avatar
I am pretty sure it can be either. That is also the upgrade "all vinyl" seat. In Suburban it would have had wood door panel inserts.
5 years ago I bought it's twin (except middle position) with taller brackets.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 05-14-2017, 11:23 PM   #50
goldenburb
goldenburb's Avatar
Hey thanks. now I feel guilty for wanting to strip off the vinyl. .
67 c10 2wd sb truck
67 c10 4wd lb truck
