Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-30-2016, 07:14 PM   #26
ochre 72
Re: 72 Jimmy "Colonel Mustard"
Got the harness out today. Going to send to Speartech.
Redhead steering gear came in the mail today
Replacing the flywheel and some seals. (torque converter was loose on the donor and damaged the old flywheel.
ochre 72 is offline   Reply With Quote
Old 03-31-2016, 09:40 PM   #27
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Great build - I'm on board!
Old 04-05-2016, 01:22 PM   #28
ochre 72
Old 04-05-2016, 01:36 PM   #29
ochre 72
Old 04-05-2016, 02:41 PM   #30
flashed
Dang ,he works fast ,is he in the old Day's building ?
flashed is offline   Reply With Quote
Old 04-05-2016, 06:05 PM   #31
ochre 72
He's definitely rolling along. I caught him at the right time. It's back apart again, but he says maybe finished in two weeks.
He's in downtown Commerce, Ga. It is an old Chevy Dealership.
Old 04-08-2016, 03:22 PM   #32
ochre 72
They finished blasting the firewall. While they were welding up the holes in the firewall, I had Jim incorporate the brake pedal assembly from the donor into the firewall and prep the firewall to accept the hydro boost assembly as a direct bolt on.
Old 04-08-2016, 04:02 PM   #33
ochre 72
Had a chance to install the accessory bracket kit that I got from Dirty Dingo. Really nice kit by the way, would highly recommend it. Very well thought out.
Picked up a load from the powder coater
Old 04-08-2016, 04:05 PM   #34
ochre 72
2012-up Camaro ZL1 manifolds from Ebay. They look new. Dropped them off to have ceramic coated.
Old 05-02-2016, 10:08 AM   #35
ochre 72
Finished up the front & rear differentials. I replaced all of the bearings, seals, brake parts, u-joints, studs and a lot of the hardware. I coated everything I could with Por 15.
Old 05-02-2016, 10:26 AM   #36
ochre 72
To mate the NP205 to the 4L80E, I bought a kit from advance adapters.
One of the steps is to cut down the tailshaft
Then I prepped the trans for paint. I used an aerosol from POR. It really laid down well.
Old 05-02-2016, 11:13 AM   #37
Lieferson
Lieferson's Avatar
Great progress, everything is looking very sharp. You are doing almost the exact same build as me just 100x faster! Curious, was it just easier to find a 2wd donor than a 4x and thats why you went with the c2500? Is all thats involved with converting it cutting the tail shaft just like the older transmissions? Also where did you order the gas pedal adapter plate?
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 05-02-2016, 11:32 AM   #38
ochre 72
Thanks. I ended up with the 2wd by accident. A friend gave me the donor truck, but when reading about the advance adapter kit, a lot of the 4wd transmissions do not have the reluctor ring inside the case as would be needed for the controller to operate the transmission properly. Here's a pic of the explanation AA gives. It's in the last paragraph.
I will also be enlarging a hole in the transfer case to accept the adapter. I'm taking it to my brother's machine shop today to have that done.
The gas pedal adapter came from a member on this forum (Hart rod). He sells them in the vendor section or the LSx parts forum.
Old 05-02-2016, 01:03 PM   #39
Lieferson
Lieferson's Avatar
Awesome thank you, i guess it is a little more in-depth process than i thought. Well right on, excited to see the rest of this build!
Old 05-02-2016, 03:53 PM   #40
ochre 72
Thanks! I will try to post the rest of the process and hopefully it will help. Good luck with your build.
Old 05-02-2016, 04:10 PM   #41
ochre 72
Some progress on the rust repair being done.
Epoxy on the firewall
Test fit
test fit the top
First mock up with old fenders
Firewall had to be "adjusted" slightly.
Final weld in of the front floor. Tunnel will be cut last.
Mock up with new fenders
Beefed up the rocker area to stiffen a little.
Old 05-02-2016, 09:13 PM   #42
flashed
Wow,looking good .
Old 05-04-2016, 02:31 PM   #43
ochre 72
Wow,looking good .
Thank you. Will possibly be coming back to my shop Saturday.
Old 05-04-2016, 07:29 PM   #44
preciador6
Looking good..Hope i win the Power Ball tonight so i can start a frame off resto
preciador6 is offline   Reply With Quote
Old 05-05-2016, 05:20 PM   #45
flashed
When I get recovered enough from back surgery I will come check you out .
Old 05-05-2016, 10:36 PM   #46
Chad22873
Chad22873's Avatar
I have read a lot of different builds but it's amazing that no matter how many you read you always see something different in each one. Great job and I look forward to watching the progress.
BR549
Chad22873 is offline   Reply With Quote
Old 05-07-2016, 09:13 AM   #47
ochre 72
Thanks! The power ball is my retirement plan
Hope you get better soon. I'm here Monday-Saturday, swing by whenever you can.
Thanks. I enjoy reading all of the builds, learning and picking out things that I want to incorporate into my build.
Old 05-20-2016, 04:11 PM   #48
ochre 72
Floor is cut for the hump and blasted. Getting closer to getting it back.
Picked up the camaro manifolds from the ceramic coater
Got them torqued down with new bolts
Few more powder coated pieces
Old 05-20-2016, 04:23 PM   #49
flashed
Do you have someone close do your powder coating ? There is a good guy out near me in my community that does great work ? You dont know anyone in need of Blazer side windows and hatch window ,all with gaskets do you ?I have some that need a new home cheap as long as I dont have to ship them. Im going to come down and meet you soon ,Im back to driving now.
Old 05-20-2016, 05:22 PM   #50
IronCanine
I'm trying....
IronCanine's Avatar
Top work. Enjoying the follow.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
