Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-30-2016, 09:59 PM   #26
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Suburban Rear Bumper
Yet another mystery.
Old 03-30-2016, 10:18 PM   #27
aerotruk63
aerotruk63's Avatar
Took a look in the TECHNICAL SERVICE DEPARTMENT manual for 1963.
The specs are the same as the front bumper.
CK 1405, 06, 16 C3605
Material: High Tensile Steel
Gauge, nominal: .147
Width, maximum: 78.54
Height, maximum: 6.67
Availability: Standard Painted
RPO V37 Chrome
There's no notes mentioning a cutout.
Old 03-30-2016, 10:31 PM   #28
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Originally Posted by VictoriaHardware View Post
Yes it is centered and symmetric. It was not cut with a saw or grinder. It was sheared off from the outside toward the inside. There is a consistent "burr" all along the inside edge that happens with a shear, particularly with a dull one. I can't imagine anyone other than the factory going to the trouble to make a stamping tool to do that. By factory I mean either the bumper manufacturer or the vehicle assembly plant.
Why some have it and others don't is the question. I am confident it is the original bumper to my truck. My truck is a late '66 Fremont-built 2WD with 15" wheels.
my 65 is a Fremont truck, but I think my 64 is a Janesville, I will get some pics and info tomorrow. both were 1/2 ton 2wd, and both had a spare tire cutout in the gas tank. ( did all subs come with a underneath spare?)
Old 03-30-2016, 10:51 PM   #29
padresag
RPO V37 Chrome
perhaps it came with certain larger tires?
ron
padresag is offline   Reply With Quote
Old 03-31-2016, 05:19 AM   #30
aerotruk63
aerotruk63's Avatar
That was my thinking as well. You would usually find a different part number if anything changed in the design. GM would have stated if there was a different part number for optioned wheel changes.
Old 03-31-2016, 06:29 PM   #31
jonzcustomshop
1961 crewcab
here are my pics, both of mine are Fremont 'burbs
Old 03-31-2016, 06:33 PM   #32
jonzcustomshop
1961 crewcab
the other one, and a front and rear together:
Old 04-09-2016, 09:12 PM   #33
DPowers
DPowers's Avatar
The panel truck rear bumper I have also has that cutout.
DPowers is offline   Reply With Quote
Old 04-09-2016, 10:51 PM   #34
sofilofi
Junior Member
My 63 GMC Suburban has the notch also.
sofilofi is offline   Reply With Quote
Old 04-15-2016, 09:10 PM   #35
VictoriaHardware
VictoriaHardware's Avatar
Thanks jonzcustomshop for all the side-by-side comparison photos.
This is the only vehicle I know of that uses the essentially the same bumper front & rear. And neither looks out of place- like it was forced to work. Really a great design and great example of re-using parts to save money. Anyone know of another car/truck that can claim this?
Now I say a great design but at the same time it was lousy in the sense that it provided no step which would have been useful on the barn door trucks. On the tailgate 'burbs it was not necessary.
VictoriaHardware is offline   Reply With Quote
Old 04-15-2016, 09:15 PM   #36
VictoriaHardware
I always assumed all C10 Subs & Panels came with the underneath spare. I'm not aware of a spare tire delete option nor any interior spare tire mount option like later Blazers.
Old 06-09-2016, 10:45 PM   #37
Ehud
Does anybody have some input on the rubber flashing between the rear bumper and back of the suburban. Is it neccesary? Is this part reproduced?
Ehud is offline   Reply With Quote
Old 06-10-2016, 06:38 PM   #38
65chevysub
65chevysub's Avatar
I don't think that seal is reproduced. I took a piece of it to a local A/C/Heating shop and told them what I needed and they made me one from aluminum. I had to cut the ends of where it curves around the body, but the main piece is there and is mounted using the original screws. I then paint it to match the body. I will post a picture of it here shortly so you can see it.
65chevysub is offline   Reply With Quote
Old 06-10-2016, 06:49 PM   #39
65chevysub
65chevysub's Avatar
Here are some pics of the metal shield I had made. It's real hard to see being painted black, but when I re primer the back door, I will get a better shot. There is also a pic from underneath, and the piece of pipe tape, is for a short seal I am trying to make from some sponge-rubber I got at an old job.
Old 06-17-2016, 01:30 AM   #40
Ehud
Yeah it's kind of hard to see in the pictures. Thanks for the help.
QUOTE=65chevysub;7621160]Here are some pics of the metal shield I had made. It's real hard to see being painted black, but when I re primer the back door, I will get a better shot. There is also a pic from underneath, and the piece of pipe tape, is for a short seal I am trying to make from some sponge-rubber I got at an old job.[/QUOTE]
Old 06-17-2016, 07:35 PM   #41
65chevysub
65chevysub's Avatar
sorry. I'm going to be primering the rear door Sunday so will take the bumper off and get a better pic then from the top and the end.
Old 06-18-2016, 11:25 PM   #42
65chevysub
65chevysub's Avatar
here are some better shots of my rear bumper to body seal that I had made. Couple of pics on my Sub, and some off.
Old 06-19-2016, 06:14 PM   #43
Ehud
Much better! Mine is pretty much gone and rotten. I see how you can have one made now.
Thanks again
Old 06-19-2016, 06:39 PM   #44
65chevysub
65chevysub's Avatar
Your Welcome. I just cleaned and put it in gray primer. I am definately going to put some sealer between it and the body, as it collects dirt in the seam and I don't want any rust.
