Old 09-26-2003, 12:22 AM   #26
Fred T
Cantankerous Geezer
Fred T's Avatar
First, do what Junkyard John suggested.
If that doesn't work, you need to spend a few dollars on a vacuum gauge. It will tell you a lot about what's going on. Go here for info http://www.centuryperformance.com/vacuum.asp
Also, I would pop the top off the carb. If there's sediment in the bowl, it needs a good cleaning.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-26-2003, 11:19 AM   #27
big blue 72
got a guy that is gonna look at the carb this weekend. he says probably has sediment too.
The bad part is, my old minivan's tranny also died this week so Big Blue is the only running vehicle right now. Guess i go the weekend with it.
And, this is the wekend that me and Dmurphy68 were gonna take the old 68 rust bucket up to his shop in Middletown and cut it apart for parts.
Oh well....................
big blue 72 is offline   Reply With Quote
Old 09-26-2003, 11:54 AM   #28
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Well, if you had that much rust and sediment in the filter then you may want to pull out the fuel tank also that could be alot of the problem. It also sounds like you may want to invest in a new carb. I run R45T's in my truck gapped at 40" and have had no problems.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
