08-26-2016, 02:25 PM | #26 |
Re: harness routing
cru_zn. thats what iu like to see.. nothin... lol
I like that idea. running everything under the dash. i take youi installed the fuse box after you ran the wires thru the firewall?
1967custom |
08-26-2016, 09:41 PM | #27 |
Re: harness routing
Yes
08-28-2016, 12:01 AM | #28 |
Re: harness routing
My computer is mounted behind the gauge cluster and the harness goes through the firewall below the intake so it's barely visible. The fuse box will be under the dash as well.
08-28-2016, 09:36 AM | #29 | |
Re: harness routing
What is the rubber wire flex-conduit from? |
08-29-2016, 04:38 PM | #30 |
Re: harness routing
I mounted the ECM under the dash mounted to the brake pedal bracket. I used the hole that was for the clutch linkage for the wiring harness. It is the factory length harness.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
08-29-2016, 06:45 PM | #31 |
Re: harness routing
jjhjimmy. that is clean man. I really like that. thank you!!
1967custom |
08-30-2016, 03:50 PM | #32 |
Re: harness routing
08-30-2016, 03:51 PM | #33 |
Re: harness routing
08-30-2016, 04:32 PM | #34 |
Re: harness routing
08-30-2016, 10:06 PM | #35 |
Re: harness routing
My Blazer has a factory 67-72 auxiliary battery tray, but I have cut the right side ones apart and rewelded them back together the opposite way to fit the other side before. The auxiliary tray is easier if you can find one though.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-31-2016, 01:06 AM | #36 |
Re: harness routing
JJH Jimmy......what grommet is that from for the firewall harness pass-thru
08-31-2016, 03:13 PM | #37 | |
Re: harness routing
I cut my original apart and swapped the sides. Thanks for the idea!
