01-06-2017, 11:52 AM | #26 |
Re: Identify a 1949 truck with no cab plate
I totally want to haul stuff and tow. I'm actually curious about these weight ratings. I understand that the 4600lbs is based on the weight of the towing vehicle, not on how much it can pull. The reason I ask is that many of you are boxing frames, adding cross members, and better brakes. It would seem they could tow more than the stock '49 would especially with a Chevy 350 in them. Is there even a way to change that tow rating?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
01-06-2017, 01:59 PM | #27 |
Different load ratings correspond to frame specs, spring specs, and axles. The link in my signature lands you on the Factory design specs for a TF, scroll down to year index and pick 1949. then look at the index for frame info. There is a chart that lists the frame size, metal guage, spring specs and axles for each class of truck.
That said a "half-ton" truck will haul a lot more. I drug mine around the mountains with a full loaded slide on camper that probably weighed 850+ pounds. After I converted over to 4wd I once rolled across the dump scales with a bed full of concrete and rock at 6500#, the bed was almost dragging and springs flat. Key is to get a good frame mounted hitch, I used a Class 3, that will allow for a reasonable tongue weight. Then you need to make sure your trailer meets the same specs. Trailer should not exceed 75% of your tow vehicle weight or it will be pushing the truck around on hills and corners, not a good thing. I set mine up so I can add an electric trailer brake set up too.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
01-20-2017, 03:25 PM | #28 | |
Iv'e been through this on EVERY vehicle I have owned (It SUCKS) Even the tag and title services walk out to the parking lot and look at the vin plates.
Desert |
01-20-2017, 03:51 PM | #29 |
It actually turned out to be pretty easy to follow the official way to handle PA. I used AAA because they knew the nuances of PA laws. Oddly enough, the classic title plate requests are still a manual process as opposed to the more automated process of submitting a standard car. I added to this complication by having an out of state title to transfer and a title that had no load information.
The solution: 1. Get an independent mechanic to verify the vin plate and fill out the form for VIN/load verification (MV-41 I think) 2. Get the same guy to validate the cab plate is the same as the title and fill out a second VIN/load verification form 3. Get insurance. Hagerty worked for me. 4. Fill out form MV-11 Took about 3 weeks and that was over Christmas holidays! Not bad.
01-20-2017, 06:15 PM | #30 |
Cool beans, I think that the big problem for a lot of guys is that they want instant gratification and aren't willing to do the leg work or go step by step by the numbers.
01-21-2017, 06:30 AM | #31 | |
maybe I will hire you to get mine next time, LOL. I will try your suggestions next time, I do appreciate the details.
Desert |
