Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-26-2021, 04:07 PM   #26
scottmitchellrose
Re: Questions about primers, prep and such, for parts
ahhhh- now I see- they are hanging from the blue cord/rope! Missed that. Looked like they were lined up against the wall.
scottmitchellrose is offline   Reply With Quote
Old 05-31-2021, 10:24 AM   #27
lupo
The main purpose of a primer is to prevent corrosion. The most corrosion-resistant primer is the MCU aluminum pigmented permanent rust sealer/ surfacer. When doing bare metal metal prep is used first then followed by two coats sealer/ surfacer. followed by urethane or epoxy surfacing primer on body panels. On brackets, frame components two coats of silver one coat of color. Here is a comparison according to the DP 40 product data sheet two coats of DP40 , 5 coats of color and two coats of clear will pass a 500 hours of 5% salt Fog testing. The Three Coat Polyurethane system ,14000 hours of salt fog testing. With A EPOXY you need 65 degrees or above to use it. MCU NON LEAFING from 34 degrees up to 90. This is the most anti-corrosive primer used in the industry
lupo is offline   Reply With Quote
Old 06-19-2021, 05:04 PM   #28
lupo
I spent several years testing different coatings because trying to separate fact from fiction can be very difficult. Here is a simple test you can do at home for $15. You can test whatever paints you decide use For your restoration. Good luck with your projects The video is 31 day rust salt fog test https://www.youtube.com/watch?v=AhW3...ature=emb_logo
