06-21-2017, 04:28 AM | #26 |
Re: Mishimoto Electric Fans in Your 67-72 C10?
Your idle mixture screw adjustments depend on what carburetor your running. I run my original 1972 quadrajet 4mv on my 350. I had my screws at about 3/4 turn out from seated. This was way off. I chased every possibility of why I was having hotter coolant and engine temps. Like I previously posted it was due to a few things happening at once.
First off I had a big vacuum leak at the rear of my factory cast iron intake manifold. I didn't put enough silicone down to seal the intake along the rear of the engine block. That was my fault for not taking into consideration of having my engine block decked by the machine shop. I also had a leak at my carburetors base gasket. Relatively easy fixes. Also like I mentioned previously, burping my coolant system properly made an obvious improvement. I learned that most quadrajet carbs respond well to around 4-5 turns out. This may seem like a lot, but it doesn't hurt to try, you can always turn them back in. Mine are set now at about 4 3/4 turns out. Once I addressed my vacuum leaks and tuned the carb through trial and error, it straightened my temperature fluctuations right out. The engine idled smoother, responded better, and I won't say it "had more power" but it was utilizing the power it already had more efficiently. It wasn't easy, especially without a shop or a mentor, but I figured it out. That's how I'm able to hopefully provide some insight into your issue. I hope yours is a simpler and quicker issue to fix because summers just getting started, and Vegas isn't somewhere you want to have overheating issues anytime of year.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
06-22-2017, 02:15 AM | #27 |
Thanks for the ongoing replies. Still no fix. Ugh! (It was 115 degrees out in Vegas today)
- Update: I checked total timing with vacuum line off and plugged from vacuum advance. Initial was 12 degrees (BTDC) and total was 36 degrees BTDC at 3,000 RPM. That sounds about right. I have a bit of a cam but not sure how much. - All cooling system components are new. - T stat is 180 degrees. - Not bubbling over when engine is turned off. - As I drive it eventually gets deep in the red on the gauge and 230 degrees on the lower rad hose (bottom of rad to pump) using IR gun regardless if open highway driving or in town driving. Top hose is 20 degrees cooler. Sounds backwards, doesn't it. Summit claims it's the right pump. - It never pings - Water pump replaced last summer (Summit high volume pump) - Nothing blocking airflow. Installed Mishimoto's twin electric fans (2600 CFM total) and their 3-core aluminum rad, both designed specifically for 67-72 C10s. I also temp installed a pusher fan on front of A/C rad (1100 CFM), still over heats, but slower and only slightly into red area on gauge. The only other strange thing is I've started getting what sounds like belt squealing occasionally when engine is cold. It's not a belt. Torque converter maybe? Next step is to look hard for any vacuum leaks before installing a new water pump. Keep the ideas coming. They are Enormously helpful! |
06-22-2017, 05:59 AM | #28 |
Wow. That last post provided a lot of good info.
Everything in your post seems spot on with what you'd consider ideal conditions for operation. I have only a few more theories as to what's going on. After that I'm stumped. 1. Are those mishimoto electric fans installed correctly? I don't mean it as an insult, but from what I read on the jegs site it doesn't say if they are pusher/puller fans. Where is your A/C condenser mounted? If it's mounted directly in front of your radiator and has a large surface area, it could be interfering with the radiators cooling efficiency. Being in Vegas means your A/C is probably running as much as your engine is. Are your A/C components in good condition? (Compressor, Heater core, no refrigerant leaks?) 2. Your radiator hoses seemingly being opposite of what you'd expect and you stating that you are starting to hear what may be belt noises is a big red flag to what I suspect is the root of your problem. I hadn't brought it up because I forgot all about it happening to me. Before I had to rebuild my engine I had just freshened it up after it had been sitting for almost 8 years of not running and with just tap water in the block. I re-gasketed the engine,new distributor, rebuilt carb,new chrome aluminum hiflow water pump,belts,hoses,etc. Everything short of head gaskets. I got 4,000 miles out of it when it blew a head gasket. (They were 20 years old after all. Lol.) Thought a new head gasket set and about a week of work I would be back on the road.WRONG. Long story short it needed a rebuild. Block checked out good. Bored .040 over, New set of reman 882 heads, comp cam XE250H kit and I was back on the road a year and a half later. Immediately was having hi temp issues. With the hose temperatures being opposite of what you'd expect just like you stated. But was able to keep the needle right in the middle of the gauge, then after about 100 miles started hearing belt noises, replaced belts, another 100 miles, belts again. This time i spun the water pump pulley and fan without the belt on it and i could hear the pump groaning. I wasnt thrilled at the thought of replacing my chrome aluminum water pump after only 5,000 miles or so. So I slapped on a stock cast iron pump. $30 & lifetime warranty, sure why not? Just like that, my engine temperature woes were gone! Haven't had a single instance where the needle rises above 1/4 on the gauge. No heater core for assist. Stock fan, no clutch. Idling in traffic and 90 outside not a problem. That damn chrome aluminum pump was a REVERSE ROTATION WATER PUMP. There was no identifying marks on the box or the body of the pump, I had to pull the impeller cover off and check the impeller blades to confirm it. Yes, reverse rotation pumps are designed for serpentine belt driven setups. But they have the same flange and bolt spacing as standard rotation v-belt driven pumps. And just because summit says it's the right pump, doesn't make it so. I would make certain it is the correct one. Also, bad motor mounts will shorten a water pumps lifespan due to vibration and unbalanced rotation. So even if it is the correct pump, it could be bad already. A pump doesn't have to be leaking out of its weep hole to indicate it's bad. In fact, most pumps have two weep holes. I dont remember why, but you can have a very slight amount leaking from one of them and it'll get blown away by the fan, or evaporate off the block before you can find it. That was the case with my chrome pump. I guess 5,000 miles rotating in the wrong direction will eventually cause something to fail. LOL. That's all I have to offer for possible causes. I apologize for the long posts, but as someone who has experienced these things personally, and only about 2 years ago, I'd like to know I wasn't the only one to have it happen to.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad Last edited by Mike_The_Grad; 06-22-2017 at 06:03 AM. Reason: Add info. |
06-22-2017, 08:41 AM | #29 |
Reverse Rotation Water Pump.
These are made I think for the serpentine belt systems where the belt wraps around the water pump pulley in reverse ( spins the pump backwards ). Anybody know of a way to determine which direction the pump is pumping? -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
06-22-2017, 09:56 AM | #30 |
have you pulled any spark plugs to see if it is lean ? it sounds like a coolant flow or air flow problem not fuel or timing . what lb radiator cap are you using ? does it puke coolant into overflow tank? you might pull the stat and test it. keep us posted
06-22-2017, 10:11 AM | #31 |
Mike,
That's an awesome/terrible story but sure sounds similar to mine. I really appreciate the post. - To give you an idea on space, there is 2" between A/C condenser and radiator, also 2" between radiator and water pump pulley mount bolts - I put on new motor mounts about six months ago, a few months after I put on the new water pump. - I haven't pulled the rad cap and done a pressure check, great idea - I haven't pulled plugs in a while either, another good idea - It's not filling up the overflow tank. Just the opposite, it's using coolant but not a serious amount yet Tomorrow I think I'm ready to start with the water pump change. I'm putting on FlowKoolers 1671 https://www.summitracing.com/parts/BRA-1671 It might take some time to report back to y'all cause I'm going to also remove headers and clean/paint the engine bottom since I'll have everything removed. It's the matching ser# engine with the truck ('70 C10), I'd like to keep it! Once again, can't say thanks enough for all the ideas. |
06-24-2017, 04:19 PM | #32 |
I pulled the pump off and the back plate.
So, here's the million dollar question. From the view of the camera (engine side), which direction do you all think the impellers should turn to draw coolant FROM the large inlet? CW or CCW? |
06-24-2017, 06:01 PM | #33 |
It appears that you have the correct pump for your application. The coolant actually gets "flung" off the "backside" of the impeller blades. So yours looks to be correct.
Did you notice any signs of coolant leaks under the pumps shaft on the out side of the engine block? It would show up as dried white spots on aluminum parts and isn't easily wiped off. If you don't have any coolant leaks, then you may have air trapped in your cooling system. A trick I learned is to drill a 3/32" hole in the thermostat. It allows the air to be purged out while filling up the system. Also check the pump for any sounds while you spin it by hand. Spin it both directions. It should spin smoothly and freely in both directions. Check the end play of the shaft by pulling/pushing In on the shaft with your hand, there shouldn't be any noticeable movement back and forth. Which coolant are you running? I know that you can't run the old green type coolant with an aluminum radiator or cylinder heads. You need dex-cool or some other aftermarket coolant because of the dissimilar metals. If you already have the new pump, slap it on there and run it. Burp your system real good. You can leave you rad cap off and warm up your engine to help any air bubbles escape. Is your radiator cap the correct type to allow use of a reservoir? Some don't, they just "pop" to relieve pressure.
06-25-2017, 03:46 PM | #34 |
Ha! I stumbled across this pic I took a while back of a page from "Classic Industries" catalogue for 1947-present Chevy and GMC trucks. I completely forgot that I had taken this pic, but I remember the reason I took it was because it was the most definitive way for checking my water pump at the time. Hope it helps you in some way.
( sorry it came out sideways.)
08-12-2017, 06:48 PM | #35 |
I put on a FlowKooler pump that draws into the inlet regardless of rotation direction just to be safe. Adjusted my idle way down so 1200 in park and 550 in gear at a stop. Still too much drop but I don't get into temp needle red, just short of it.
No vacuum leak at all, mixture screws 1 1/2 turns. Mishimoto, Edelbrock, Summit, and two local motor shops have all reached the same conclusion at this point: I need more airflow. The Mishimoto 2600 total CFM on these two fans is just not enough for me, probably cause of the cam. I have 2 Derale 2100 each CFM fans (4200 total) coming along with their PWM adjustable fan controller. I'll let you know if that fixes my overheating. Anybody interested in the Mishimoto fans? : >) |
08-13-2017, 10:30 AM | #36 |
Just my .02 cents, the new fans will fix your overheating problem. A BB engine needs at least 3000 if not 3200cfm to not overheat. I went through everything you're going through with mine about 5 years ago, learned the hard way that Griffin radiators are epoxied not welded so they break down and leak. Their fan kit is top notch and I don't run hot with it installed on my stock 4 row radiator. Troubleshooting overheating problems ranks right up there with colonoscopies and can be just as expensive!
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
08-13-2017, 11:16 PM | #37 |
Ok, I just got to say that the last post from engineer_gregh was priceless. Lol!!
08-13-2017, 11:21 PM | #38 |
Glad you still have your sense of humor:-) Sometimes these trucks can be frustrating.
08-14-2017, 11:14 AM | #39 |
08-17-2017, 01:31 AM | #40 |
So here is the conclusion to this thread story. Thread summary - I changed every component in the cooling system. Tried 3-core alum rad, hoses, two temp sensors, 2 gauges, 2 water pumps, 2 thermostats. Checked timing, carb mix screws, etc etc. A really annoying overheating problem all year here in Las Vegas.
Mishimoto's twin fans (2600 CFM total) couldn't keep my '70 C10 402 from overheating at slow speeds/idle. https://www.mishimoto.com/chevrolet-...oud-67-72.html Their fan controller did work well though. https://www.mishimoto.com/adjustable...oller-kit.html So, those of you who said I just needed more airflow were dead ... right!! I just put in two Derale 14" fans (2100 CFM each, 4200 total) and wow, those little hurricanes have no problem keeping the engine cool. Finally!! I also installed Derale's PWM fan controller which automatically adjusts fan speed to match temp I set and also has a soft start ability. And yes, they run after ignition off but only for 1-2 mins at very low RPM, no problem to the battery. So worth the $150 more for the Derales fans and controller than what I paid to Mishimoto. Perhaps other Chevy big blocks cool down well with the Mishimoto fans, but mine sure didn't. I guess I now know why there are no Mishimoto reviews on Summit or Amazon for the fans I got . They don't do the job. So I tip my favorite hat to all you who helped me on this post, great team effort (and sense of humor). I'm a happy C10 man. http://derale.com/products/electric-...fitting-detail http://derale.com/products/electric-...n-probe-detail |
08-17-2017, 06:00 AM | #41 |
Old member
Nice setup and now you can enjoy the ride! Which it's all about in the end.
Another small detail that will help is make sure you seal off the fan shourds around the edges to force the air through and not around the radiator. Really any place air can go around the whole system needs to be blocked off if possible.
08-17-2017, 10:38 AM | #42 |
Glad to hear it is fixed . Thanks for the follow up solution. nice fans by the way!
08-19-2017, 12:51 PM | #43 |
I'm happy you got it worked out. Nice setup by the way. I just picked up a derale 18" heavy duty stainless steel flex fan + 2" fan spacer for the sbc350 in my '72 c10. I'm sold on Derale.
10-10-2019, 10:45 AM | #44 |
Resurrecting this post as I have nearly the identical setup and nearly an identical problem.
I’m basically running the same engine (except I’m a 468) and cam as you are. I’m even running about the same amount of timing. Same issue, it just slowly climbs at idle. An 80 degree day, I’m reading about 205° in the head, so I’m worried about when I’m in traffic on a 100° day. Before I go and buy a 4th set of fans to try to cool it, I was hoping I could ask some questions. I had installed 2 Spal fans that were 1700cfm each rated at 22amps or so each. While they moved a ton of air, I dropped to 11vdc at idle. I’m running a 140a tuff stuff 10si alternator with a 3:1 pulley setup and all the heavy wiring to back it. I thought it could handle it, but between fuel injection, a vacuum pump, and the fans, I’m close to 60amps at idle. I found that the Spal fans draw about 25amps a piece when I put a current clamp on them. Does your charging system handle both Derale fans no problem? What alternator are you running? The Derales are listed at 22amps a piece so that makes me nervous. Are you running a shroud on those fans or did you just use the zip tie mounts to attach each one? I have read the more shroud the better, so I’m curious about your setup. I can’t quite tell from the pictures. Any help would be appreciated, I’m pulling my hair out with this one! |
10-11-2019, 10:06 AM | #45 | |
My fans kick in when the head temp is around 210° and drop fast to 190° I can and have sat at idle in traffic in 90 plus heat never overheated . If you take the actual water temp it will be much lower.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 10-11-2019 at 10:12 AM. |
10-11-2019, 10:38 AM | #46 |
Thanks for the reply. I agree that 205° isn’t bad at all for a head water temp. What concerns me is it was only maintaining that temperature in the head with my flex-a-lite shrouded 2500cfm fans full tilt and 80° ambient. It wouldn’t drop at all. The Spal fans I bought only add up to 3400, but they are cages only, no shroud. I didn’t bother setting up a shroud because my charging system can’t keep up at idle despite it being 140amp. At this point,
I’m about ready to upgrade to a cs144 alternator for better idle output, and buy one of these Derale’s. https://derale.com/product-footer/el...s/16826-detail My only concern is that this won’t fit. It’s overall 4”, but that’s to the rear of the motors. I only have 3” from the WP snout to the core. You wouldn’t happen to have any pictures or at least details of your fan setup would you? Any help is much appreciated! I’m looking for anything I can get. I want this thing to get to a point where it can idle and the fans cycle on and off on a warm day. I know that’s possible because others have done it. Thanks. |
10-11-2019, 12:02 PM | #47 |
Mine are shrowded. That makes a big difference in the fans cooling ability.
Mine isn't in my truck it's my Chevelle bit all the principles are the same . I dont think I have any of it set up . My car has the short water pump. I'll look for some pictures of my set up
10-11-2019, 12:27 PM | #48 | |
If you look at the specs, most fan systems give measurements at the fan motor and along the chassis as well so you can determine fitment. Hth, -klb
10-11-2019, 12:56 PM | #49 |
Thanks for the information.
Yes, I have AC as well, but have not been running it. I can only imagine what would happed if I did. It’s amazing, if I add up all the numbers, between 50a of fans (if I upgrade fans), fuel injection, vacuum pump, ignition, fuel pump, etc, I am easily at 100a at idle. Not many alternators out there that idle at that current. Guess I have to up my alternator. It’s 140a, but because its a 10si, I know idle is nowhere near 100a at idle even at 3:1. I think I’m going to get the Derale setup. Worse case, I can modify the shroud to fit. I am running a short water pump, but still only have 3” core to snout. These trucks are so tight in front with a BB. Thanks again. |
10-11-2019, 01:20 PM | #50 |
Recently went through voltage issues with the addition of fans to my system. Ended up using a bus bar to consolidate all the accessories power leads ( every positive cable feeding stuff like fan relays, light relays, horn relays, main fuse power panel, fuel pump relay, fuel injection, ignition box, etc... ) to a single point. Then that single point got the 6awg lead from my 140amp single wire alt and it also got the positive terminal from the battery. Then I grounded the alt with a big 6 awg cable to the frame and made sure the fans had solid ground to the frame too. So my battery has only the big lead to the starter and the big lead to the bus bar on the positive terminal and the big lead to the frame and a smaller lead to the core support on the negative terminal. I also made sure to secure the grounds from engine block to frame, cab to frame and bed to frame. With all that, when all accessories on at idle ( fans full blast, headlights, radio, engine running, A/C on fan blowing high ) I see about 13.5 volts at the bus bar. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 10-11-2019 at 01:36 PM. |
