Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 07-17-2017, 01:09 AM   #26
sirJim
Re: 62 Burb project in the making.
Thanks I think it will work out quite well. Windshield was giving us some trouble but it will get there eventually.
sirJim is offline   Reply With Quote
Old 07-17-2017, 06:02 PM   #27
65chevysub
65chevysub's Avatar
Originally Posted by sirJim View Post
Interesting to see the original tank. Mine had a curved tank to make room for the spare tire. But the shipping company butchered that one.
My original has the indentation for the spare. Now that repro sender units are available, I put my original tank back in.
65chevysub is offline   Reply With Quote
Old 07-17-2017, 06:35 PM   #28
65chevysub
65chevysub's Avatar
Here is a pic of my original tank with the "cutout" for the spare.
Old 07-26-2017, 02:54 PM   #29
sirJim
Not much to report. Had a problem with the throwout bearing I got, the Chinese made was about 5mm to long my buddy whiped it into shape on the lathe after pressing the bearing off, And of course remove and replace the trans.
Did some work on the break lines to the new master cylinder Along with one of the rear lines the shipping co squished and hooked up the break pedal.
Now we need to find a break hose for the slave cylinder set up out of something we can get here.
Slowly coming along.
Old 07-27-2017, 01:18 AM   #30
Captainfab
60-66 Nut
Progress is progress no matter how small at times.
Old 07-27-2017, 01:26 AM   #31
sirJim
That is true! It is coming along just never enough hours in the day.
Old 07-27-2017, 11:34 PM   #32
Captainfab
60-66 Nut
That is so very true.
Old 07-28-2017, 12:50 AM   #33
sirJim
Well finally found the break hoses one for the rear that is long enough and one for the clutch which we will try to get installed today. The spring on the clutch pedal is a pain to get off which is need to get the bolt thru on the clutch pedal. May end up just taking the instrument panel out to get some tug on it.
Old 08-01-2017, 08:32 AM   #34
sirJim
Brakes are all set, bled them and seem to be working great. Got the distributor in.
Have to do something to preserve the wood it is in great shape, any advice?
Old 08-03-2017, 12:50 PM   #35
sirJim
Few pictures of the last couple days work. Brake lines and hoses, Hyd. clutch lines and hoses with mount from Astro van.
Old 08-10-2017, 03:45 AM   #36
sirJim
Got the clutch pedal all in and adjusted, electric fan wiring almost done, gas tank out for the filler spout to be soldered in. getting closer all the time, need to make plug wires and should be ready to fire up soon.
Old 08-11-2017, 12:29 AM   #37
Captainfab
60-66 Nut
Be careful soldering on that gas tank
Old 08-11-2017, 01:22 AM   #38
sirJim
Dont worry it is a new tank. Just need to move the spout and plug the hole. I want to keep the baffel in the right direction and it was for a rear fill.
Old 08-17-2017, 04:41 AM   #39
sirJim
Got the plug wires made and put in.
Battery cables are on need to do the throttle linkage.
Gas tank is soldered up need to install.
Little bit at a time.
Old 08-20-2017, 01:19 PM   #40
sirJim
Cleaned out the back so I could check the fit for the middle seat (Astro van) and plan the frame, fit well enough for a beer break to try the height out.
Almost got the rear shocks on but had a problem taking out the old bushings which fit much better than the Chinese ones that came with the shocks.
Got the rubber mounted on the tank almost ready to mount it up.
Got the air cleaner on, getting close to starting it up, throttle linkage is getting there. Slowly getting there. will try to get some pictures next time.
Old 08-23-2017, 04:00 PM   #41
sirJim
Rear shocks on.
Wrap on the exhaust next to the rear shock.
Exhaust mount in the middle done with rubber mounts.
Gas tank almost got installed, rubber on every thing hoses almost all in ran into a problem with the sending unit wire, wrong size.
Getting closer to firing it up!
Old 08-30-2017, 11:25 PM   #42
sirJim
Itīs ALIVE! Got the tank in with a very successful club evening. Fired her up and broke in the cam. Runs great worth the LATE night! Little sleep now off to work. More when we get a video of her.
Old 08-30-2017, 11:40 PM   #43
Captainfab
60-66 Nut
Old 09-03-2017, 12:37 PM   #44
sirJim
Got the middle seat in with a little help from Frank. Little rust work by my buddy Tommy.
Old 09-03-2017, 05:04 PM   #45
65chevysub
65chevysub's Avatar
nice seats! What are they out of?
Old 09-03-2017, 11:04 PM   #46
sirJim
I think it is from about a 97 chevy astro van. I have 2 captains chairs waiting to go in the front from another astro van that are the same material, and trying to put a couple Chrysler folding seats in the 3rd row as well for vehicle inspection.
Old 09-09-2017, 05:05 AM   #47
sirJim
Been busy, not much time in the shop. Got a good start on the 3rd row seats, (2 Chrysler folding) pictures will follow when done.
Old 09-14-2017, 09:53 AM   #48
sirJim
Got the 3rd row seats in.
Wrapped the pipes up front.
Primed the drip ledge.
Old 09-21-2017, 01:12 PM   #49
sirJim
Thanks to Peter we got the side blinker lights (small LED) on just need the hood on and it should be ready for import tax evaluation vehicle inspection. No time to work on it. Sorry forgot to take a picture. Next time,
Old 09-24-2017, 10:13 AM   #50
sirJim
Went for the first drive up and down the road a few times today.
Small problems worked out, cracked fuel line at the pump to carb.
Replaced.
Cleaned the carb.
Tightened hoses.
Put the hood on.
Now to take it to vehicle inspection hopefully tomorrow.
Cross you fingers that they dont find anything that dosent comply.
Will post some pictures next time.
