08-28-2017, 01:06 PM | #26 |
Re: Clutch linkage picture request
I have the bracket that bolts to the block but it will put the pivot ball directly behind the header pipe. The biggest issue is the header, i think.
06-05-2018, 08:53 AM | #27 | |||
Great photos here, gentlemen. I have a few clarifying questions to add to the discussion, as well as another photo of what I'm looking at on my project. I hope I can learn from you as well.
Is it advised to not use the hole in the block for a V8 application? Here is what I'm looking at, and it sure looks like it will line up in the block. 71 frame with bracket as it was when I got it. 292 truck, 350 that was set up in a 4 speed '65 C10. . |
06-05-2018, 09:14 AM | #28 |
These pictures show some 6 cyl Z bars and a V8 Z bar and bracket on the bottom right also the pivot ball bracket mounted to the Small block engine , The V8 Z bar is longer and the V8 frame mount is noticeably different .
06-05-2018, 09:21 AM | #29 |
You say the frame mount is noticeably different; how so? Is it further forward? That would make sense with only one linkage length type, so all V8 applications would need both the mounting plate on the motor AND the V8 frame mount?
Looks like I need both if that is the case! More hard parts hunting ahead... |
06-05-2018, 09:30 AM | #30 |
Just find a V8 z bar and use the 6 frame mount redrill frame holes to line it up . look at the bottom right of the picture above to see the difference in the frame mounts . Classic has the part .For The block bracket I'd post a WTB (want to buy ) ad in the parts section in here After becoming a subscribing member
"I decided that a true hot rod should have 3 pedals " https://www.classicparts.com/1967-72...info/90%2D807/ Last edited by Grumpy old man; 06-05-2018 at 09:37 AM. |
06-05-2018, 09:38 AM | #31 | |
EDIT: re-read your post, sorry. I see you still said to go grab a block bracket. Makes sense given one length of linkage fits "all"... |
06-05-2018, 09:44 AM | #32 |
Here is the thread where I bought mine from the parts board .
http://67-72chevytrucks.com/vboard/s...d.php?t=764162 |
06-05-2018, 09:55 AM | #33 |
here is a pic of the V8 pedal to Z bar rod
06-05-2018, 11:06 PM | #34 |
I have a plate that bolts to the engine
04-05-2020, 08:45 AM | #35 |
Does anyone have the specs or a rough sketch with dimensions for the frame mount bracket? I have to have one fabricated and would really appreciate if someone could share that with me.
1968 Pontiac Firebird purchased in September 1980 1968 Ford F100 purchased in September 1981 1970 C10 purchased in August 2012 1984 Oldsmobile Cutlass purchased in October 1993 1989 Ford Mustang 5.0 LX purchased in 1989 1992 GMC 1500 purchased in October 2020 |
04-05-2020, 03:56 PM | #36 | |
Moderator
GM Part number is 6261879
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
12-10-2022, 11:24 AM | #37 |
I’m converting from a L6 to a 383 V8. The engine is mounted in the L6 location using the six cylinder mounts. Now the 6L Z bar and bracket line up but the bar is too close to the engine to slip over the pivot ball. Should I shorten the Z bar, slip the ball stud inside the tube and then try to thread the ball into the engine block ?
Posted via Mobile Device |
12-11-2022, 11:55 AM | #38 |
My small block is in the I6 location and its a mix of parts for the clutch. The upper rod is a the stock I6 (truck was originally a 4 speed) the bell crank is a V8 unit turned 180 to clear the headers, on the block side the ball is just screwed into the block, then the stock linkage back to the original fork. All works nice an smooth.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
12-11-2022, 08:31 PM | #39 |
You Might have some luck with these guys. I replaced all of my parts last year ordered from them and everything fit as it should, but mine was an R and R application with the exception of the pedal to Z bar link.
I upgraded to the aluminum with Heim joints which is easier, smoother, tighter and quieter. https://4speedconversions-com.3dcart...k_linkage.html |
12-12-2022, 08:32 PM | #40 |
Thanks for the advice, photos and link.
