Old 08-25-2017, 11:21 PM   #26
Black_Sheep
Black_Sheep's Avatar
Re: Brother's keeper - '58 Stepside build
Sanding, sanding and more sanding. I took a break from the dust tonight and put together some new plug wires. If you want them to look good you have to make them yourself. Hopefully a little acetone will take the lettering off the wires.
Black_Sheep is offline   Reply With Quote
Old 08-25-2017, 11:30 PM   #27
Black_Sheep
Also planning how to extend the floor in to the footwell so the floor is flat from door to door...
Old 08-26-2017, 08:13 PM   #28
Black_Sheep
Got the frames built for the floor extensions, all that's left is to cut some 18 gauge steel for the tops and weld it to the frames...
Old 08-26-2017, 08:29 PM   #29
Black_Sheep
The FatMat RattleTrap I ordered showed up, so I finally got some sound deadener on the flat trans cover. The upper firewall, kick panels and floor exrensions will get the same treatment...
Old 09-02-2017, 01:58 AM   #30
Black_Sheep
It's been a busy week but I did manage to finish up the floor extensions and fit them to the cab, turns out the stepwell was 1/2" different from side to side (all original sheetmetal}
Now the floor will be flat from door to door...
My goal for this weekend is to finish up minor bodywork on the cab, final prep the exterior and jambs, epoxy the bare spots and give it a coat or two of slicksand. Hopefully I can pull it off.
Old 09-02-2017, 10:52 AM   #31
_Ogre
_Ogre's Avatar
nice 4 eyed build
i'm sure your brother would like it
i believe we have a lot of black sheep on this forum
welcome to the crowd
shop air compressor timer
Old 09-02-2017, 12:52 PM   #32
Russell Ashley
Russell Ashley's Avatar
Started out nice but will be a lot nicer when you finish. Yes, I think your brother would approve of what you are doing.
Russell Ashley is offline   Reply With Quote
Old 09-10-2017, 10:33 PM   #33
Black_Sheep
Been plugging away with no visible progress, until today. I was hoping to have the cab in primer last weekend but it just wasn't quite ready. I kept picking away during the week and put in a long day on Saturday.
Old 09-10-2017, 10:37 PM   #34
Black_Sheep
Today I built a "paint booth" and shot the cab with a coat of epoxy primer and a couple rounds of sanding primer.
Old 09-10-2017, 10:41 PM   #35
Black_Sheep
I'm pleased with the result and the bodywork looks good despite a couple of minor issues that became apparent with some paint on it. There's still a lot of blocking and priming to come but I'm feeling pretty good about it...
Old 09-15-2017, 07:43 PM   #36
Black_Sheep
More sanding, only 306 louvers left to go...
The first round of blocking on the cab is about half done, I should be able to finish that up this weekend.
Old 09-15-2017, 08:24 PM   #37
Dan in Pasadena
Dan in Pasadena's Avatar
Black Sheep, Everything's looking really good. I wish I'd thoght of the floor extension idea - I like it. I bet in a few years guys will be doing, "The Black Sheep floor thing".
If/when I machine some L brackets for the carpet edge I plan to include an oval recess for the "Body by Fisher" coach emblems the cars had. Maybe you could add that to yours if you like the idea. Keep the pic's coming. If I missed it, what's the main body color going to be? I read your comment about metalflake white roof - cool.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-15-2017, 08:36 PM   #38
Black_Sheep
I am planning to a 90 degree brushed aluminum strip to finish the edge. I've always thought the "Body by Fisher" logo was cool, adding one would be a neat little detail.
This is the color I am leaning towards...
http://us.vibrancecollection.com/get...-Metallic.aspx
Old 09-17-2017, 04:26 PM   #39
Black_Sheep
I needed a break from sanding and dust today so I took care of some loose ends that would be easier to do before the cab goes back on. I eliminated the hydraulic brake light switch when the brake system was re-plumbed so I fabbed up a bracket to correctly position the new mechanical stop light switch.
I also finished installing the Lokar neutral safety switch, a required item to pass the MSRA safety inspection...
Old 09-17-2017, 04:35 PM   #40
Dan in Pasadena
Cool color. Looks kinda pearlescent. Big thumbs up!
Old 09-17-2017, 04:59 PM   #41
Black_Sheep
Thanks Dan! It's fine metallic and I think it will give really nice highlights and shadows to complement the beautiful contours on a TF truck. The white metal flake roof will give it a little flair, the look I'm going for is my concept of what a sport / muscle truck might look like if Chevrolet built one back in the day...
Old 09-23-2017, 01:31 PM   #42
Black_Sheep
Put some heat wrap on the head pipes this morning, will be block sanding after lunch...
Old 09-23-2017, 02:41 PM   #43
Dan in Pasadena
I'm thinking of doing Jet Hot coat on my exhaust manifolds then switch to wrap after that on the mufflers. Will you be wrapping your H pipe? I ask because it crosses under the transmission tailstock.
Old 09-23-2017, 07:04 PM   #44
Black_Sheep
My main concern was that the drivers side pipe which passes beneath the master cylinder and booster, I need to get more wrap for the crossover and the tailpipes. It's probably overkill but the tailpipes are close to the sides of the fuel tank and having heat wrap on them will make me feel better.
Old 09-24-2017, 08:11 PM   #45
Black_Sheep
Another productive weekend, blocking the cab with 180 is almost done. Just a little left on the driver's door jamb and rocker. Next up, some 2K primer and another round of sanding, this time with 400. It should be easier to block out because the bodywork is now very straight and smooth...
Old 09-24-2017, 11:55 PM   #46
oldman3
oldman3's Avatar
Looking good...Jim
oldman3 is offline   Reply With Quote
Old 10-01-2017, 09:40 PM   #47
Black_Sheep
I got what should be the final round of primer on the cab and the first round of 2K on the hood. There's a lot more work left but things are moving in the right direction...
Old 10-01-2017, 09:58 PM   #48
Dan in Pasadena
Looks really good!
Old 10-01-2017, 11:11 PM   #49
oldman3
oldman3's Avatar
Looks sweet...Jim
Old 10-07-2017, 12:05 AM   #50
Black_Sheep
The stainless tail light housings showed up so I got them all put together, the studs still need to be trimmed so I can use stainless acorn nuts to attach them to the brackets.
The plan for tomorrow is to paint my lower dash, steering column and column drop pieces Ford HP White, followed up with white micro flake and a couple coats of clear.
The remainder of the interior will be painted '63 Chevy Laurel Green...
