Old 08-24-2017, 10:10 AM   #26
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Repost here: lq4 turbo'ed swap
Originally Posted by indymachinist View Post
That cam will tame down a bit on the bigger engine. It will still be lumpy obviously.
Sloppy mechanics is pretty much the go to group for low budget ls turbo set ups. If you can weed through all the "send it" "hit it with your purse" etc etc stupid comments there is a lot to be learned.
If your gonna watch "Send it" videos, then Larry Enticer is the ONLY answer!!
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-24-2017, 09:44 PM   #27
Slowguy
Originally Posted by aggie91 View Post
That engine is stock down to the head bolts, gen 3 rods, ring gap and even the lifters. I you go to that same channel on you tube, he has like 14 videos of what all was done to that truck with the 4.8. The long block only has the cam and springs done, nothing else.
I would believe that cam would work well in your 6.0 and might not require as much boost to hit that same power level because of the increased displacement.
So I started watching his videos and use them as a sort of guideline, would that be a mistake since I'm using the 6.0?
Slowguy is offline   Reply With Quote
Old 08-24-2017, 10:36 PM   #28
Heavymetl
6.0, 5.3, 4.8....I'm not sure it even matters. The turbo is doing all the work!
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 08-25-2017, 09:18 AM   #29
aggie91
I'm just glad to be here!
aggie91's Avatar
No, not at all.
He had a 6.0 in that Colorado before the 4.8 with a different cam and turbo that put down just over 1000 rwhp.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-25-2017, 03:15 PM   #30
tinydb84
tinydb84's Avatar
I think its hard to recommend a cam without the turbo size. I am surprised neither of them asked for it.
I am in the process of doing my turbo build just commenting to see what other people have to say. Oh and pictures because everyone likes those.
David
Instagram: myfabguy
Old 08-25-2017, 06:49 PM   #31
Slowguy
I think I'll go with the 76mm turbo
Old 08-27-2017, 08:57 PM   #32
tinydb84
tinydb84's Avatar
Seems like a good size for street use. You going to get the larger hotside right?
David
Instagram: myfabguy
Old 08-28-2017, 08:47 AM   #33
Slowguy
Looks like their size shows the 78 as a 75 hotside? All things considered seem like this would be a good option for room to grow and an ok spool time considering the 6.0 displacement.
Old 08-29-2017, 08:09 AM   #34
Slowguy
I've read a ton of stuff on cleaning. It appears I can clean th exterior of the block with oven cleaner. I'll pressure wash after that. My concern is getting oven cleaner on ant internal bearing surfaces. I'd oil right after cleaning to prevent flash rust but can oven cleaner possibly damage or microscopically pit any of these detrimental surfaces? I will try to avoid them but if I clean all the carbon out of the inside of the block, inevitably some of the cleaner will contact the bearing surfaces. Same goes for the crank.
The Pistons I thing I'll chem dip and clean the ring landings with an old ring.
Pretty happy with the way the intake turned out. I was told o could use a set of ctsv 55lb injectors and they'll swap right over. If this ends up being the case it seem like a good option
Old 09-13-2017, 10:42 PM   #35
Money_pit
Money_pit's Avatar
Any updates?
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 09-14-2017, 02:45 AM   #36
Slowguy
Still moving forward little by little. Decided to do cam bearings but having an issue with the clocking of the oil holes in the first bearing. Just need verification. I'll get that figured out soon.
Block clean as a whistle. Started to prime and paint. All valves lapped and waiting for pac springs to arrive. Going with the Elgin cam mentioned earlier. It'll be here soon. Got a 320 grit 4.0" flex hone to match with new rings. Think the consensus is to gap both first and second ring right at .032?
I'll get some pics real soon. It's looking good.
Old 09-14-2017, 10:11 PM   #37
66 C10 383
Originally Posted by mongocanfly View Post
here's the specs for the btr stage3 turbo cam....Cam specs are 230/235 .609"/.610" 114+4 and comes a 3 bolt timing gear pattern.
even bigger than texas speed...
I know you said you just ordered a cam, but the above isn't the cam Brian speced. The BTR TRUCK STAGE III CAM is listed here:
https://www.briantooleyracing.com/tr...e-iii-cam.html
Specs are 218/224 .553/.553 113+3
I'm looking at the BTR Truck Stage IV cam for my NA 5.3 and thought the above specs were a little big for the truck stage III cam.
Also, have you read the Hot Rod magazine article where they turbo'd an LS motor? Very good insight I think...
http://www.hotrod.com/articles/hrdp-...g-bang-theory/
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
