Old 02-19-2018, 09:17 PM   #26
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Project 66: LS and Frame on the Ground
sweet looking old 66.....did you replace the headbolts? those are one time use torque to yield....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-19-2018, 09:40 PM   #27
Jferrante
Jferrante's Avatar
yea all new bolts.
Jferrante is offline   Reply With Quote
Old 02-19-2018, 11:17 PM   #28
Duncan K
That motor cleaned up nicely, paint look great. Can't wait to get mine looking like that!!
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 02-21-2018, 10:41 PM   #29
Jferrante
Jferrante's Avatar
Thanks I think it looks really good even if it does get some dings in it and such.
Old 02-25-2018, 05:39 PM   #30
Jferrante
Jferrante's Avatar
Got some Por-15 on the front part of the frame..most of the rear comes out with the choppin block kit. Will paint once it is all together.
Old 02-28-2018, 09:24 PM   #31
Jferrante
Jferrante's Avatar
CB kit came yesterday in a bunch of boxes. I didn't have time last night to go through it so tonight after work I started the unwrapping and began on the front end.
The dropmember uses the factory holes but the bolts are a tad larger so you need to run a step drill bit and you are good to go. From there you add the inner frame support, upper bag mount and engine mounts. The engine mounts will go on the motor before dropping it in to ease that process.
Once the drop member is in its just a process of installing your ball joints and bushings and then installing them on the drop member. Really not too much.
The hardest part is making sure you have the parts on the correct side of the truck.
I still need to install the lower ball joints and the shock relocation brackets and then I am moving on to the rear.
Christmas in Feb
Dropmember and inner frame supports in
Closer look at inner frame mounts
Motor mounts in their place
Upper bag and control arm mount
and most of it in
until tomorrow
and another present for myself...
Old 03-01-2018, 12:37 AM   #32
Captainfab
60-66 Nut
Very nice!
Old 03-01-2018, 09:01 AM   #33
Bennett68C10
Bennett68C10's Avatar
Looking good! Makes me miss my choppin block front crossmember
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-02-2018, 09:22 PM   #34
Jferrante
Jferrante's Avatar
Frame cut and cross member out - took a few cut off wheels and created a ton of dust but we are almost ready for final mockup, paint and assembly of the frame. Weather is ****ty but hoping its dry this weekend so I can get a bunch of these parts painted.
If anyone needs a crossmember let me know
Old 03-03-2018, 03:00 PM   #35
84blaze
Nice build. Looking forward to more progress!
84blaze is offline   Reply With Quote
Old 03-03-2018, 05:28 PM   #36
Jferrante
Jferrante's Avatar
Thanks - did some quick primer and first paint on the frame bits so I will start assembly tomorrow.
Old 03-03-2018, 05:29 PM   #37
Jferrante
Jferrante's Avatar
Really nice kit I am impressed. They need some instructions or at least better visuals. Other than that top quality parts.
My goal is to be done and ready for E-Town swap meet are you going?
Old 03-03-2018, 06:59 PM   #38
mongocanfly
Post Whore
some good looking parts you got.....nice welder to...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-04-2018, 12:36 PM   #39
Bennett68C10
I’ll be there in my daily but not the Suburban! I don’t have enough time or cash to get it done by the spring swap meet Hoping to have it on the road by mid summer so it should definitely be at the fall swap meet.
Keith
66 Suburban
IG: bennett68c10
Old 03-04-2018, 06:24 PM   #40
Jferrante
Jferrante's Avatar
Haha - I set ridiculous goals like getting my truck done by then and just hope I do it...
Today was another busy day. I got most of the items a brief coat of paint yesterday so today's goal was to get the puzzle together. I am going to have to clean up some of the paint at some point but it looks fine for now.
Nothing real hard here just a lot of drilling.
Next up is welding the trailing arm brackets to the rear axle and then I plan on getting the wheels back on and engine back in the frame
Old 03-04-2018, 07:33 PM   #41
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
You got me watchin' closely!
Modges'66 is offline   Reply With Quote
Old 03-15-2018, 05:08 PM   #42
Jferrante
Jferrante's Avatar
Nothing dramatic has changed we got a lot of snow and I lost power for 2 days and I am traveling for work so I didnt get much work done this past weekend. Regardless I am making slow and steady progress.
I got the 4 link brackets welded to the rear axles which was a nice accomplishment. It is an awkward welding angle for someone new to the craft but I got it done. Added the rear bags as well.
Up front the holes for the ball joints in the spindles werent wide enough so I had to drill them out to the right sizing without over enlarging the hole.
I then got the shocks mounted, steering rack in and my front wheels mounted up as well as my airbags.
Next up is running some air lines and my trans mounts and hopefully getting the air all powered up and ready for the engine.
Old 03-16-2018, 08:04 PM   #43
Jferrante
Jferrante's Avatar
Tackled a few more odds and ends today including mounting the air tank and putting the motor in to check how it all sits. It isn't laying low as it can in the front so I am ordering an F Body Oil Pan kit and hoping that does it.
Old 03-17-2018, 10:51 AM   #44
Notch1988
Notch1988's Avatar
Looks like some great progress. Are you doing a one piece drive shaft?
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 03-17-2018, 10:54 AM   #45
Jferrante
Jferrante's Avatar
Yes I have it already
Old 03-17-2018, 05:55 PM   #46
Notch1988
Notch1988's Avatar
You notching out the back of the cab? A one piece shaft will hit the back of the cab before laying out.
Link to my build:
My GMC Project
Old 03-17-2018, 06:56 PM   #47
Jferrante
Jferrante's Avatar
I'll see when I put the cab on
Old 03-19-2018, 02:25 AM   #48
InvalidConflict
Nice build so far!
InvalidConflict is offline   Reply With Quote
Old 03-20-2018, 08:59 PM   #49
Jferrante
Jferrante's Avatar
Originally Posted by InvalidConflict View Post
Nice build so far!
Thanks, fourth nor Easter in 3 weeks coming in tomorrow I was hoping more would be done. Hoping to have brake lines, air management and fuel ran by this weekend
Old 03-20-2018, 10:27 PM   #50
w00dst0ck
w00dst0ck's Avatar
Always a bummer seeing swb frames get cut for choppin block rear kits. You should have bought a longbed frame for cheap, and sold the swb frame and recouped $5-800.
w00dst0ck is offline   Reply With Quote
