Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-04-2018, 10:19 AM   #26
whitesilverado
Re: How To: Ruin a Perfectly Good 4wd
Mine in the works
whitesilverado is offline   Reply With Quote
Old 02-04-2018, 10:28 AM   #27
Bennett68C10
Bennett68C10's Avatar
I’m in for this build for sure, to answer your question on your other thread, I really like the TTII’s I have. The only problem I’m having is with the backspacing on the rear wheels and my narrow rear axle I’m running in the burb. They don’t fit at all without running a wheel spacer or adapter which I’m not a fan of. Trying to figure out what I want to do about it now.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-04-2018, 12:40 PM   #28
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by sprint_9 View Post
Awesome, Im excited to see this come together, I kind of want to do a blazer myself sometime.
If it’s anything like your truck, should be nice!
Originally Posted by whitesilverado View Post
Your going to be using very nice product. Mine coming out good.
Looking good! Any issues so far? Build thread?
Too bad you’re not closer, we could work something out. I could use a narrow axle for my truck...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-04-2018, 02:03 PM   #29
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Originally Posted by gringoloco View Post
I’ll take that as a compliment
Yep
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 02-06-2018, 10:34 AM   #30
aggie91
I'm just glad to be here!
aggie91's Avatar
In for the ride too. I have always had a spot for these blazers, especially the 2wd versions. The DEG parts look good.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-06-2018, 01:29 PM   #31
lolife99
67-72 parts collector,…
lolife99's Avatar
Great thread!
The only thing I would add to the Deadend Garage parts,... is a 2" lowering block to help keep your ride height low,... with the correct pressure in the air bags.
I'm glad to see someone document a 4x4-to-2wd conversion with Deadend Garage parts.
Keith
Convert to disc brakes.
Old 02-06-2018, 01:41 PM   #32
lolife99
lolife99's Avatar
Keith,... which Torq Thrusts did you order?
The 1-piece VN515 or the 2-piece VN405 wheels?
The 1-piece wheels are cheaper but only come in set backspaces.
20x8 (4.5"bs) and 20x10 (5.75" bs)
The 2-piece wheel comes in 20x8, 20x9.5, 20x10, 20x12, and 20x15 with a large variety of backspaces.
When I ordered mine for my blazer I specified the backspace I wanted, since they were going through the custom shop anyway.
Keith
Old 02-06-2018, 02:03 PM   #33
fatbass
fatbass's Avatar
I hope you realize that converting a 4X4 to 2WD in Utah is a felony.
J/K- I subbed now.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 02-06-2018, 02:43 PM   #34
Bennett68C10
My TTII’s are the 1-piece VN515 that I had on my 68! The backspacing worked on that truck because it laid frame and was going to have a modified bed floor and wheel wells. The 5.75” backspacing on the 1-piece 20x10’s absolutely do not work on my 66 Burb with the narrow rear I’m using without an adapter and I’m not interested in cutting into the Burb to make them fit. I also don’t want to change out my rear as I have a good amount of $ tied up into rebuilding it. After doing some thorough measuring over the weekend, I solved my problem yesterday when I ordered 2 20x10 VN405 2 piece polished TTII’s from Travis at Pro Performance. I really liked the look of the TTII’s on my Burb so I just ordered a pair with the exact backspacing I needed. They should match up close enough to the front 1-piece wheels that no one should be able to notice a difference. I’ll be putting the 2 1-piece 20x10’s up for sale after I get the new wheels.
Keith
66 Suburban
IG: bennett68c10
Old 02-06-2018, 03:06 PM   #35
lolife99
lolife99's Avatar
Good to hear. I was afraid you were going to change to a different wheel.
Those look so good on your suburban!
Sorry for hijacking your thread gringoloco.
Keith
Old 02-06-2018, 03:55 PM   #36
gringoloco
A guy with a truck
gringoloco's Avatar
They do look nice. Ready to get my hands on them
Great thread!
If I bag it, it will definitely get 2” blocks. Right now, probably going static, as I have most of the parts on hand... unless I can find another $2-3k in the budget to bag it properly.
I’ve been wanting to document a conversion for a while now; I’m personally more interested in properly locating the front crossmember for prosperity, as there seems to be lots who have done it, but no definitive guidance. The DEG parts should make the rear a snap; remains to be seen!
J/K- I subbed now.
Yes, everyone that my wife has mentioned this to at her work thinks I’m a lunatic and won’t talk to me anymore... I’ll just go over here and be crazy by myself
...I’ll be putting the 2 1-piece 20x10’s up for sale after I get the new wheels.
PM sent.
...Sorry for hijacking your thread gringoloco.
No worries, it’s part of why we do this
-Chris
Old 02-06-2018, 04:41 PM   #37
knomadd
knomadd's Avatar
Dang, a few days away and I've missed a lot of conversation. Your plan sounds great! I'll be following along.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-06-2018, 05:05 PM   #38
lolife99
lolife99's Avatar
Funny you mention that.
I've always thought about these conversions in great depth.
For me personally,... I would move the entire crossmember forward 1" to help center the wheels on low trucks.
I know this means, moving sway bar mounts, idler arm holes, and the steering box holes,... but to me it would be worth it.
Especially if you could weld and do it yourself,... which I know you can.
I remember seeing this mod years ago on a squarebody blazer converted to 2wd.
But I can't remember which magazine it was in.
Keith
Old 02-06-2018, 07:23 PM   #39
gringoloco
A guy with a truck
gringoloco's Avatar
Welcome aboard!
I think you could get away with moving the whole crossmember forward a bit, without interfering with the steering center link. Possibly combine that with the lower control arm “caster mod” for more centering. We will see how it pans out, but I will play with it a bit to see what works best.
If you think about it, moving the whole crossmember forward isn’t a whole lot different from using 1” forward tubular arms, as far as steering linkage geometry is concerned when related to the pitman and idler arm locations (someone please correct me if I’m under-thinking this). Stock type anti-sway bars can have the ends trimmed and linkage style bars might be able to absorb the difference (or have bushing locations redrilled, as you stated, thankfully, I’m starting from scratch there).
All that to say, it may not be too terribly complicated to gain that extra inch. 104” wheelbase is stock, so probably somewhere in the neighborhood of 105” will look “right”. I’m pretty excited to finally get to play with one (the yellow Blazer was already converted when I bought it). Let’s find out together
-Chris
Old 02-06-2018, 09:37 PM   #40
smbrouss70
smbrouss70's Avatar
Trust me, you won't be lonely in the crazy corner!
Welcome aboard!
You might have the inner tie-rod ends get too close to the crossmember if you move it forward, but that should be able to be "clearanced" or notched to provide enough room for them. Another issue that would come into play only if you are bagging it, is the fact that the steering column shaft may interfere with the upper control arm when laid out. Again, an easy fix for someone with your particular skill set.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-07-2018, 12:43 AM   #41
gringoloco
A guy with a truck
gringoloco's Avatar
This is why I like you guys, you get my brand of crazy
It’s a delicate balance between keeping it easy and hacking it up. I’d like to keep it bolt-in-ish. At least that’s the plan, for now...
-Chris
Old 02-07-2018, 01:40 AM   #42
smbrouss70
smbrouss70's Avatar
BTW, this explanation from Livrat sounds like the easiest way to correctly locate the holes for a 4x4 to 2wd swap. I don't know if you have access to a set of front framerails off of a 2wd truck though.
Originally Posted by Livrat View Post
The swap is a fairly easy one to do... I have done 6 of them in the last 20 years.. Mainly because I like 2WD blazers plus they are rare and are worth way more than 4X4's.. (at least here in WA)
The simplest way is to aquire a 71/72 2WD donor truck.. You will need the entire front crossmember assembly... all the brake lines... steering box.. motor mount towers.. shift linkage...(BB and SB are different)... radiator core support brackets... transmission crossmember.. and ... make sure to keep all the nuts and bolts.
Remove everything you can unbolt from the frame on the 4X4.. Get yourself a big hammer and chisel.. and knock the rivets out of the front spring hangers/core support brackets.. same with the rear spring hangars and outer shock plates... and remove..
I have found if you cut the donor trucks frame rails off at the firewall.. cut them into three pieces lengthwise at the corners, You can litterally bolt them on top of the frame on the conversion truck to line up the holes that need to be drilled... use a transfer punch to mark them... (available at most tool stores) then start drilling.. be prepared for alot of sweating..... then you should be able to bolt the 2WD front suspension crossmember and steering componets in and have the truck back on the ground... Bolt on the front radiator core brackets.. and all brake lines... slide the 2WD trans crossmember between frame rails close to where it should go... Whew.. by this time the hardest part is over... and you should have a steering and stopping truck...
For the engine mount towers I prefer to use the 72 style ones because they are stronger than the 67-71 ones.... since they are fairly expensive and you are at this point into drilling holes.. I opt to get them out of the 73-80 trucks.. BUT there are more than one style and you need to get the correct ones.. One will make your engine sit up too high... I can draw a picture of the style you need if you decide to go for it... (not sure exactly which truck/engine combo I get them from.. I just know what ones to look for..)
Depending on which engine/trans combo you will use you may or may not have to drill the holes for the engine towers.. I prefer to use a bare block and transmission assy and "mock it up' into the truck.. the lower bolts on the engine tower will usually just "line up"... again transfer punch the holes and drill then bolt them in.. On the transmission crossmember I like to use a 10inch long drill bit to drill both top and bottom holes at once... then bolt all together... On the trans shift linkage again.. you may or may not have to drill holes for the frame bracket.. will have to mock it up to see..
On to the rear end...
if the 4X4 is not a 69 ...(69 rear ends are narrower than the rest)
I opt to just put the 4X4 rear end on top of the leaf springs with either a flip kit.. or by welding on new spring perches.. I use "Moroso" spring perches for a Dana 60 which have the same tube diameter... If you are not a welder and are not familiar with setting the "pinion angle".. a flip kit would be the preferred method.... Then I use the axles and brake drums off the a 2WD to get the 5 lug pattern... Its a straight swap... You can use Axles/brakes from any 2WD 1971-80 12 bolt...
IF you decide to go ahead... feel free to email me and ask any questions... I love to talk trucks.. Just dont like working on em anymore...
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 02-07-2018, 11:41 AM   #43
gringoloco
A guy with a truck
gringoloco's Avatar
I do like this method, though it seems like you’d use a lot of cutoff wheels if you’re a regular guy like me without a plasma cutter. It think it would be easier to build a paper template or rubbing transfer. I at least have access to a torn-down C10, though there is a dropmember in the way now. Wish I’d had the foresight to build a template while it was apart Regardless, I may not end up in exactly the stock position, but we’ll see!
-Chris
Old 02-07-2018, 12:52 PM   #44
gringoloco
A guy with a truck
gringoloco's Avatar
These frame diagrams have been reposted a number of times here on the forum. They do not contain all of the required info, but are a great start. Big thanks to the original poster, Rod, whoever/wherever you are...
-Chris
Old 02-07-2018, 01:00 PM   #45
gringoloco
A guy with a truck
gringoloco's Avatar
Notice that the front crossmember on the 2wd is located based on axle centerline (CL), which is only possible to find with control arms and spindles installed, and at ride height. It is much easier to locate axle CL on the 4wd frame as it’s centered in the bumpstops.
We can decipher that the factory placed the front axle CL 21.90” behind the core support bushing CL. This is found by subtracting the 16.50” measurement from the seemingly arbitrary line drawn 38.40” behind the core support mounts. This measurement is the same on both 4wd and 2wd frames.
-Chris
Old 02-07-2018, 01:13 PM   #46
lolife99
lolife99's Avatar
Any chance you can "plumb bob" the centerline of the front wheels by using the blazers front sheeetmetal with all the suspension removed.
Kinda like the guys did in the old days when addinging subframes to straight axle vehicles.
Draw everything out on the floor.
I agree you will have to assemble some of the crossmember,... but without springs in place it shouldn't be too hard to mock up exactly where you want the wheel to set in the front fenders.
Or am I over simplifying things?
Keith
Old 02-07-2018, 02:06 PM   #47
gringoloco
A guy with a truck
gringoloco's Avatar
That’s almost exactly what I have in mind. I want to get all of the DEG parts bolted in place, hang the rear suspension, and plot the front from there. I plan to temporarily hang the front suspension and steering to see what works best for visual and functional placement, then drill and bolt for final install.
-Chris
Old 02-07-2018, 02:32 PM   #48
gringoloco
A guy with a truck
gringoloco's Avatar
Moving to the rear, we see that GM located the trailing arm crossmember 70.43” from the core support CL. This is derived by adding the seemingly arbitrary 38.40” reference from the core support bushing CL to the 32.03” measurement, which appears to align with the forward-most upper crossmember mounting hole. Correctly ocating the trailing arm crossmember also correctly located the rear axle CL.
This measurement seems to fairly accurately correlate with findings here on the board of previous conversions (including my own), which utilize existing holes in the 4wd frame, following removal of the existing bracket (photo courtesy member notsolo). This reference gets us in the neighborhood. We will see how it pans-out with the location of the DEG c-notch, which due to the contours of the frame, is relatively fixed.
-Chris
Old 02-07-2018, 03:04 PM   #49
gringoloco
A guy with a truck
gringoloco's Avatar
Here’s a pic of my old Blazer showing how the wheel is centered in the rear wheel well when using the “existing hole” method:
-Chris
Old 02-07-2018, 03:14 PM   #50
gringoloco
A guy with a truck
gringoloco's Avatar
Member sierragrande71 located his front crossmember using two existing holes in the frame, which looks to fairly closely center the front wheels in the arches. Kinda hard to tell, due to the angle and height of fenders.
-Chris
