Old 06-21-2018, 09:38 PM   #26
Whamo
Whamo's Avatar
Re: 1973 C20 Semi-build
aaannndd, I'm'a followin...
Just a Hillbilly in the Hood
http://67-72chevytrucks.com/vboard/s...d.php?t=622194
Whamo is offline   Reply With Quote
Old 06-21-2018, 09:51 PM   #27
Dads79GMC
Dads79GMC's Avatar
looking good!!! Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 06-22-2018, 12:40 PM   #28
aggie91
I'm just glad to be here!
aggie91's Avatar
What are you using for your de-rusting solution?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-22-2018, 01:06 PM   #29
Wraith
It varies for what I am doing but the most is done with the industrial alkaline solution and if I need to go further I am using an industrial wall cleaner. Both are diluted for the specific task at hand.
Wraith is offline   Reply With Quote
Old 06-22-2018, 09:30 PM   #30
Wraith
Got a jump on the weekend paint festivities
Even the torque converter got some love
Old 06-24-2018, 02:06 PM   #31
Wraith
Clean
Sandblast
Paint
Remove fingerprints while cleaning
Groundhog day repeats itself.
Old 06-27-2018, 08:20 PM   #32
Wraith
PARTS!!!!
Old 07-01-2018, 01:51 PM   #33
Wraith
Doesn't everyone degrease, abrasive tumble, and paint their bolts? LOL
And frame paint today. Anywhere I can't get to when the engine is back in
Old 07-02-2018, 08:48 AM   #34
aggie91
aggie91's Avatar
Nice progress. Yes, on my last full build, we did the same to all the bolts that we reused...
Karl
The LST Challenge:
Old 07-02-2018, 10:31 AM   #35
buffydores
buffydores's Avatar
I love this type of build. I love seeing things cleaned up and maintained properly. I love the rich color of the paint that buffing uncovered. Good stuff.
Old 07-02-2018, 10:09 PM   #36
Wraith
Core support back together and engine brackets/pulleys back on.
Old 07-03-2018, 09:53 AM   #37
aggie91
aggie91's Avatar
I think you need more cribbing blocks...lol
Karl
The LST Challenge:
Old 07-03-2018, 10:41 AM   #38
Wraith
LOL. I had a couple but most were made from used wood when I tore apart my tip-tissorie from my Malibu.
https://youtu.be/LWLotuKJ0UU
Old 07-03-2018, 01:18 PM   #39
moregrip
moregrip's Avatar
don't forget to file the threads on those bolts!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 07-03-2018, 02:32 PM   #40
Wraith
Every thread stainless wire brushed by hand.
Old 07-05-2018, 12:23 PM   #41
Honest Bob
Honest Bob's Avatar
I love the truck but I also love where you stored your cribbing. I got a bunch of 4x4's to cut up into cribbing just havent done it yet.
Honest Bob is offline   Reply With Quote
Old 07-05-2018, 09:41 PM   #42
Wraith
I'd always seen them on forums and thought they would work well, after building them I have wondered how I lived without them. I even stole the small one I built for my jack to raise up my battery back-up for the home computer.
Old 07-07-2018, 08:53 AM   #43
Wraith
Finished up cleaning the firewall as much as I will for this time, may buff it out though...
I guess they write the color down on the firewall?
And the nasty chrome wheels and off road tires are gone, need to run the originals down and get new rubber.
Old 07-08-2018, 06:23 PM   #44
LT7A
Excellent work on the firewall. I think cleaning up the original looks good, remains utilitarian, and retains character that I like. Often the paint itself is in good shape. And even though I'm not a concours resto guy, I still like to see those factory markings. Crazy to think that some guy wrote that by hand 40 years ago and it's still there.
Old 07-08-2018, 09:55 PM   #45
Wraith
Hot with no breeze this morning but work got done.
Old 07-09-2018, 08:45 AM   #46
Greenlee
Greenlee's Avatar
Nice work!
Greenlee is offline   Reply With Quote
Old 07-22-2018, 01:26 PM   #47
Wraith
Got out before it got hotter than the surface of the sun here in Texas and truck was still in the shade. Installed the headers(dropped right in as they should!) after cutting off a little bit of the down pipes for the stock manifolds, installed power steering pump/brackets after making a spacer to go with the headers, new soft fuel lines to the pump, installed thermostat/gasket/housing, and dropped in the distributor. I'm either lucky, good, or crafty as the balancer was at 8* BTDC and the distributor dropped in straight away. I'm buying lottery tickets later today.....
Old 07-29-2018, 06:35 PM   #48
Wraith
Texas has been so hot but this morning was just a little cooler. Got out and cleaned up the plug wires with Goop hand cleaner, swapped out the blue wire holders for a set of black one I think I bought in 90', detailed the distributor cap, cleaned up the permanent cork gaskets off the valve covers, new filter/vac caps on carb, and installed it all on the engine.
Old 08-31-2018, 12:48 AM   #49
Billy81
Billy81's Avatar
It's been awhile any updates?
Billy81 is offline   Reply With Quote
Old 09-01-2018, 01:12 PM   #50
Wraith
It all looks the same in the bay, finished up wiring/vacuum last week, picked up new battery cables, and fired it this morning on starter fluid. I'd forgot how loud open headers were. The ignition switch is clicky/sticky as all get out so I pulled the top of the steering apart to fix and called it a day.
