11-27-2018, 01:31 AM | #26 |
Re: Blueprint vs ATK Engines
i set mine up like this,
Edelbrock RPM Air Gap MSD HEI street fire distributor FItech 600 hp easy street Summit brand 304 ss short headers into a JBA 304 ss Y pipe March 2 belt Sport Track billet brackets Air cleaber is to be determined, i have the edelbrock with the flow through top...but debating a closed factory look, modded to dual snorkel |
11-27-2018, 09:39 AM | #27 |
Thanks all for correcting my lack of effort on what goes out the door at BP engines.
I've been looking at big block engineson their website, everyone has a "Blueprint" cast into the block at the top near where the intake sets. Stormin, what are your plans for crank case ventilation??? |
11-27-2018, 03:00 PM | #28 |
Moderator
Well I called and got a recording I guess they dont answer e-mails.
You know what? I think I will just wait and save for the Chevy Performance SP350 357HP Crate Engine 19367080. They're in Texas anyway.
11-27-2018, 03:15 PM | #29 | |
j
White K20 |
11-27-2018, 07:48 PM | #30 |
i have a cast aluminum angled breather similar to the link, it is painted black and will mount on the outside of the pass valve cover right between the bolts.
https://www.speedwaymotors.com/Garag...her,93825.html |
11-27-2018, 11:37 PM | #31 | |
60-66 Nut
That will let air in, but you need a place to connect a PCV valve on the other side of the engine.
11-28-2018, 01:13 AM | #32 |
i am debating running check valves down into the exhaust...venting from the rear of the valve covers. otherwise, a bung will be added to the driver side.
11-28-2018, 09:29 AM | #33 | |
I've also thought about running one on the other side and running a PCV from it. THe breathers I have looked at are on www.mooneyesusa.com, under auto accessories. |
11-28-2018, 07:54 PM | #34 |
mine is a cast finish (easier to paint) with the finned top...but has a hidden set screw. i have it wrapped up and in the box still, i will check on the name.
05-24-2019, 05:39 PM | #35 |
Bringing this back from the dead. Rocknrod, what did you ever decide as far as the engine goes?
05-25-2019, 06:07 PM | #36 |
Moderator
My plan is to go with the Blueprint engine. I'm in Iowa right now working to get money to finish this truck the way I want.
I was just looking further into this when i saw this thread. Yes the Blueprint engine.
05-29-2019, 01:14 PM | #37 |
i just made 2 trips around the block on memorial day...i ended up drilling my driver valve cover near the rear and adding a stock style pcv for now.
i may run the mewagner dual stage pcv in the near future. |
01-12-2020, 09:02 AM | #38 | |
Moderator
01-12-2020, 10:05 PM | #39 |
60-66 Nut
I didn't realize that. That engine should have a nice choppy/lopey idle but also a little low on vacuum.
01-13-2020, 08:59 AM | #40 | |
Moderator
01-14-2020, 06:11 PM | #41 |
driving is in my blood
The LSA is slightly tight but the duration is mild he'll be fine with brakes IMO.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-14-2020, 06:15 PM | #42 |
Moderator
On the GM engine?
10-07-2021, 12:50 PM | #43 |
Which engine did you end up getting. Were you happy with your choice?
10-07-2021, 04:34 PM | #44 |
Moderator
Me?
10-07-2021, 04:44 PM | #45 |
10-07-2021, 05:05 PM | #46 |
Moderator
I went with the Blueprint 350/385. Vortec head, 1 peice rear main seal, roller cam & lifters. They have great proceedures to pre startup and I have had zero issues with it. Better quality than I expected for the price.
10-15-2021, 03:53 PM | #47 |
Moderator
I just watched this video (plant tour and assembly) - https://youtu.be/Jzr2U8bGpvc
They talk about making they're own blocks, but I bought a seasons block.
