02-23-2019, 04:55 PM | #26 |
Re: 1951 3100 4BTA Cummins
Joedoh - dang autocorrect
02-24-2019, 12:20 PM | #27 | |
There is a local IH that the owner swapped in a 4BT. The installation looks like it came from the factory and it runs like a top. I'll see if I can track down pictures that I took in 2016. -Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917 |
02-24-2019, 12:27 PM | #28 |
Purcell69 - Ya. I have a "recipe" for around 400hp and 800ftlbs of torque. The Kuntz Bros has one with that for a daily driver with no problems. They also have a drag racing bread truck that is pretty awesome.
01-26-2021, 05:35 PM | #29 |
What did you do for pedals? Installing a gas and clutch pedal is one of my major hurdles as im not sure where to start. I already have the brake pedal installed via a power disc brake conversion kit i ordered online 5 years ago (https://www.performanceonline.com/19...-bolt-pattern/)
01-26-2021, 05:43 PM | #30 |
I used s10 pedal assembly and followed skymangs s10 how to thread. Instead of vacuum brakes I went to the junkyard and got hydraulic brake booster out of a 90's astro van. Runs off of my power steering pump.
01-27-2021, 09:46 AM | #31 |
props on the kill switch! i've been thinking about how to do something tricky and that trumps all my ideas so far.
01-27-2021, 12:09 PM | #32 |
Thanks, I was just trying to figure out how I could use the space because patching it and trying to match the paint would be a nightmare.
02-05-2021, 10:54 PM | #33 |
Very nice. Looks as though the 4bt came in there. Sounds like rod knock or a tractor is funny, I have been told mine sounds like an old transport truck. When you turn your motor up to 10 it should really move.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
02-10-2021, 05:02 PM | #34 |
Ya, I have an NV4500 in it now so I could turn it up a little bit. Just have to spend the money for parts so that it can be turned up safely.
