Old 05-09-2019, 11:33 AM   #26
theastronaut
theastronaut's Avatar
Re: 1966 F100 Short Bed Styleside Metal/Body/Paint Work
The driver side bed corner fit pretty well at the bottom but stuck out past the bedside towards the top.
I was able to reach the spot welds through the taillight opening with an extended nose grinder and carbide burr. You can see how much I moved the panel inward to make the two flanges flush.
We decided to shave the stake pockets, so I cut out the flanged lip and made a filler panel that keeps and extends the seam so it looks like a factory panel.
I drilled a couple holes to plug weld the filler panel's flange in place like the rest of the corner's flange.
Coated the inside of the corner with epoxy before welding it shut.
Finished.
theastronaut is offline   Reply With Quote
Old 05-09-2019, 01:43 PM   #27
mongocanfly
Post Whore
mongocanfly's Avatar
That stake pocket cap and wheel tubs looks great!...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-09-2019, 03:03 PM   #28
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
It's looking great. You make it look so easy!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-10-2019, 02:39 PM   #29
jhrusk
Work looks great as always.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 05-14-2019, 06:57 PM   #30
Russell Ashley
Russell Ashley's Avatar
You notice details that are so small that some of us would never notice they need fixing.
Russell Ashley is offline   Reply With Quote
Old 05-14-2019, 09:33 PM   #31
Ol Blue K20
Amen!!!! But now I notice them. Iwish I could fix them like he does.....
Dale
Old 05-15-2019, 07:45 AM   #32
Very nice work on the ole girl!
Old 05-15-2019, 04:49 PM   #33
theastronaut
Thanks guys!!
The passenger side pocket was a bit more work since the seam was crooked at the top. I rounded off an air chisel tip and used that to move the edge of the long panel over to where it should've been.
After moving it over, still not perfect but much better than before.
Patch made, determining the right spot to make the bend so the gap is even.
Bent, fitted, and welded weld in.
The front bed pockets were opened up to get back to flat metal, then were straightened, spot blasted to touch up missed areas of rust, primed, and welded shut.
Old 05-15-2019, 04:52 PM   #34
theastronaut
The second wheelwell came in so I started getting it ready to install. The shock notch was welded up first, then I had to narrow the mounting flange to clear the raised lip on the inner bedside.
I scribed a line on the patch, then trimmed with tin snips for a near-exact fit with no grinding needed. This saves grinding discs and makes less dust in the shop.
Difference in flange width.
Old 05-15-2019, 04:56 PM   #35
theastronaut
I welded in the header panel using the original spot weld holes, but some of those were halfway off the edge of the panel so I used a copper spoon to keep the weld contained and the edge straight.
The upper seams weren't pretty from the factory and they won't really be seen once the truck is assembled. I welded them up and ground down the welds so that all of it would look decent once seam sealer is applied.
Old 05-15-2019, 08:08 PM   #36
mongocanfly
Post Whore
Outstanding!!!....I'm jealous of your skills and how well your making that metal look....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-15-2019, 10:19 PM   #37
Ol Blue K20
X2!! Very nice work
Dale
Old 07-26-2019, 09:26 AM   #38
theastronaut
I''ve made a bit more progress, just haven't been posting. The hood, doors, and fenders are all stripped now. One fender is trashed too bad to fix, the other is in pretty good shape, both doors are pretty straight with the normal rust at the bottom edge, and the hood is really nice except the edge of the nose.
I also started the bodywork on the upper part of the bedsides. I'll wait to do the lower section once the bed floor is welded back in, it's too flimsy as-is.
I always block the "flat" sections first, first the top and then the side, leaving the rolled area for last. The flats need to be established first before rounding the curved area. I stopped blocking as soon as I saw epoxy showing through, continuing to block will result in low spots.
Once the flats are blocked straight I spray more guide coat on the flat areas then carefully block the curved section until it blends evenly into the flat areas. The guide coat shows how far you're blending the curve into the flats.
All work up to this point is done with 80 grit on a 3/8" thick acrylic sanding block. The acrylic has a hard surface force the sandpaper to cut the high areas down quickly and 3/8" is stiff enough to not flex. 80 grit is aggressive enough to shape the surface without leaving excessively deep scratches. Once everything is shaped with 80 grit I clean the surface well and apply more guide coat, then block it again with 180 to prep for primer. This round of blocking will show if you blended the curves into the flats evenly.
After spraying a couple coats of epoxy to seal the bodywork. You can see how straight the flats are, how crisp the edges are, and how evenly the curved areas blend into the flat areas. This will be further refined with polyester high build.
Old 07-26-2019, 09:37 AM   #39
theastronaut
Same process with polyester primer. Flats first, more guide coat, then curves blended into the flats.
Same approach with the rear corner, except with thinner/flexible acrylic blocks.
Old 07-26-2019, 10:54 AM   #40
Ol Blue K20
Looking good, your attention to detail is amazing. I also learn a lot keep it coming.
Dale
Old 07-26-2019, 10:57 AM   #41
mongocanfly
Post Whore
looks great John..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-26-2019, 02:01 PM   #42
ClydeDale
John, catch us up on this project.
ClydeDale is offline   Reply With Quote
Old 09-26-2019, 03:07 PM   #43
67C10Step
67C10Step's Avatar
Great work and project. Saddens me to say it but back in the early 1990's I was given a truck exactly like yours, color and everything. It was my great grandfather's truck and my grandfather wanted to give it to me. I was in college at the time and had no place to keep it or money to spend on it so he ended up giving it to my cousin.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 09-27-2019, 01:26 PM   #44
theastronaut
Thanks!!
The bed is ready for the floor to be welded in once the flat spots are reshaped to form continuous ribs. I've sent samples of the rib shape, as of last night the dies are cut and are being fine tuned now. More on that soon.
Thanks for checking it out! That's unfortunate about your granddad's truck, it's always cool to keep them in the family when possible. My granddad also had a 60's F100, dad has it now but it's been sitting up for about 25 years. It's on the list of my other 397,903 projects I'll get to eventually
Old 09-30-2019, 11:12 AM   #45
67ChevyRedneck
67ChevyRedneck's Avatar
Looking good!
The front fenders look pretty decent, what was so bad on it? I've seen you fix so many things that looked so much worse? Repair vs. better fender cost?
I also just noticed someone put GM stepside back up lights on the bed.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-30-2019, 01:39 PM   #46
theastronaut
Originally Posted by 67ChevyRedneck View Post
Looking good!
One fender was pretty good so I'll save it, the other was really rough once it was stripped. Plus I try to save costs when it's easier/cheaper to replace than to repair.
Here's an update on the bed floor, ya'll might recognize this guy.
Old 09-30-2019, 03:52 PM   #47
mongocanfly
Post Whore
looks good John.....
looks like somebody is just showing off...haha
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-01-2019, 05:47 PM   #48
MP&C
MP&C's Avatar
Hey that place looks familiar. Deja vu or something......
Robert
MP&C is offline   Reply With Quote
Old 10-30-2019, 07:54 PM   #49
MP&C
MP&C's Avatar
A teaser pic.... Pre-stretching on the wheeling machine. Kramer looks on.
Robert
Old 10-31-2019, 09:44 AM   #50
Ol Blue K20
That's a teaser alright.....lol
Dale
