10-05-2019, 04:38 AM | #26 |
Re: SMOG LEGAL ENGINE SWAP TO LS yesterday passed!
What dose this mean for running a manual transmission? If the engine/trans donor has a manual trans it should be ok, or dose it have to be a computer controlled automatic? Also would that mean that only a 4.8 or 6.0 be used? As the 5.3 never came with a manual.
AJC |
10-05-2019, 07:19 AM | #27 | |
The original poster mentioned that the ECM coding had to be 100% stock in order to pass. Manual conversions require software tuning, otherwise they set the "check engine" light(another no-no) at a minimum.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
10-07-2019, 01:30 PM | #28 |
WOW. Glad I live in NY (can't believe I just said that!) You can put anything you want in a pre 96 car. 95 and older are safety only inspections. But then again you don't see many 30 year old cars on the road except on a weekend in the summer. Buddy put a crate 454 in a 95 Camaro . Just a PCV valve with a carb .
10-08-2019, 08:00 AM | #29 | |
Moderator
Then re-code the PCM with a J2534 passthrough ( I use a WiFi MDI clone ). You use that VIN with a single VIN license in the web applet at the AC Delco TDS web page. Program as a replacement PCM and it'll dutifully program your PCM with manual transmission parameters etc for that VIN.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
10-08-2019, 07:40 PM | #30 |
the trans thing is crazy how the hell does that make a difference in emissions. fuel economy possibly if you kept say a th350 or 400 but emissions aren't going to change. I wonder how they deal with replacement engines on stock cars or say if this engine failed can you just swap in another 5.3? so many more things I wonder but im in ky so no point in me asking.
10-09-2019, 09:55 AM | #31 | |
Moderator
If you have an LS with the ECM TCM setup the ECM expects to get feedback from the TCM. If the ECM or PCM doesn't get feedback from the TCM or transmission in response to its' requests it gets lost. Some ECM/PCM will drop you into limp mode and others just plain freak out. Harvey Hardway would brute force it with a tuning package. You run the risk of missing something minor that'll freak out the ECM/PCM in some obscure manner if you try to be Harvey Hardway. The easiest way to handle running a manual transmission or an older automatic transmission on a modern engine is to program the PCM or ECM using a manual transmission vehicle VIN and then fine tune the settings with your tuning package. The fuel and spark tables from a 3/4 or 1-ton truck may be advantageous as well.
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-09-2019 at 10:56 AM. |
10-10-2019, 05:17 PM | #32 | |
10-10-2019, 05:24 PM | #33 |
I don't live in cali will never live in cali so I don't want to clutter up his thread only curious
10-10-2019, 05:52 PM | #34 |
Moderator
The peoples republic of California is run by the un-elected pencil pushers that have their little feifdoms for the benefit of the aforementioned pencil pushers.
What they do doesn't have to make sense. If you ask... it's because they say so.
02-25-2020, 10:37 PM | #35 |
Just wanted to clarify because Im planning a swap in my 79 C10, are you using the OEM blazer tank or the OEM tank from your donor? My 79 has saddle tanks that Id like to reuse but I`ve also been thinking of swapping to a 87-91 Blazer tank to keep it simple with 1 tank.
Anthony |
02-26-2020, 09:47 AM | #36 |
Moderator
You can use the 87-91 saddle tanks with the baffles and senders with fuel pumps as high volume low pressure lift pumps and a fuel pump on the frame rail to push the pressure up to LS specs. You'll need to upgrade the NL2 dual tank valve to the motorized Pollack valve. The NL2 wiring and switch will need to be updated to the 1987-91 TBI setup using the fuel system power wire from the LS ECM in place of the same from the TBI ECM. This allows you to keep your 40 gallon capacity with two tanks.
The LS ECM should cut fuel pump power as soon as the engine stops so... as long as you're switching the fuel pump power with the ECM you don't need the oil pressure switch as a safety system. The 1987-91 Emissions and Driveability books in my manuals thread have detailed information on how the power feed from the ECM feeds the fuel pump relay and the NL2 valve power. Look up the Dual tanks theory of operation thread for more information as well. Several European and US automobiles use the in-tank HVLP lift pump to HP fuel pump scheme for fuel supply. The TBI pumps will push significantly more volume GPH or GPM at lower restriction/pressure. When tanks without baffles are your only option you can put a submersible LS fuel pressure pump in a slosh can with feed and return to-from the tanks and to-from the fuel rails. It's not needed with the 87-91 TBI fuel tanks.
02-29-2020, 03:33 PM | #37 | |
Anthony |
02-29-2020, 05:03 PM | #38 | |
Moderator
The rest of the LS version of the EVAP system is fairly simple. If you weren't in the Peoples Republic of California you could bypass the EVAP readiness test and plumb the less expensive components from the 1970's evap canister setup to the purge valve. It would work just as well as the LS system but your overlords have no doubt decreed you shall use the LS motor evap system or else... off with your head...
02-29-2020, 05:19 PM | #39 |
We generally do not mess with 1976 and newer vehicles due to smog laws.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
02-29-2020, 05:43 PM | #40 |
This is why I will not put an Ls in my '91 suburban. I'll go 383 or 400. They have no idea what's under the valve covers. As long as it passes visual and emissions I'm golden
03-02-2020, 08:41 PM | #41 |
I was going to put the Erod in my 90 3/4T Suburban but found out there is a weight limit for the vehicle and my suburban is 1000 lbs over the weight limit for the Erod LS3.
03-26-2021, 12:58 AM | #42 | |
1) no car engines (good bye plentiful Camaro 6.2/6L80e) 2) no "E-rod" conversions. Then I found out about the class 1 (<6.5k GVWR), 2a (6k-8.5k) & 2b (8.5k - 10k) My truck happens to be a non-CA R30 (1-ton dually C30 for 89) So, now I'm trying to figure out what more modern (but as said above "not too modern") trucks came with either a 6.0 or 6.2 along with a six speed automatic that will meet the GVWR criteria for the class 2b (8.5k-10k lbs GVWR). I have another call into my local smog ref and hope to pin down some more info. Though it doesn't help to whine about it, I am still amazed that I can't swap a much cleaner burning more modern engine/tranny and pull out the TBI 454, but "oh well". Funny thing is that it is the GVWR that is going to cost me a bunch of money and time and the only thing that I will tow is my woman and a couple of German Shepherds!!
Sent by the random thoughts from the voices in my head... |
03-26-2021, 10:16 AM | #43 |
Just here to tinker
Very good write up! That takes some dedication to get it right! Thank you for posting OP.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
03-26-2021, 10:30 AM | #44 |
EricU, what year is your truck?
03-26-2021, 12:19 PM | #45 |
At the body shop.
Praying this passes. Our 82 k5 would be 2000% easier
" That didnt make it any newer " " Dont antique the equipment " |
03-26-2021, 12:47 PM | #46 |
Big ol booty'd 89 2wd R30 in the middle of getting an attitude adjustment.
03-26-2021, 12:48 PM | #47 |
If that passed in CA, the prices of 76-82 Squarebodys would jump!
But I don't think that it will happen this time. From the inner-web: Legislation (AB 210) introduced in California to exempt motor vehicles manufactured prior to the 1983 model-year from the state’s biennial emissions inspection requirement failed to be considered prior to the legislative deadline for “two-year” bills. By rule, bills in California that are carried over from the previous year, also known as two-year bills, must be passed by January 31. Since this did not occur, the bill is dead for the legislative session.
Sent by the random thoughts from the voices in my head... Last edited by EricU; 03-29-2021 at 01:24 PM. |
03-26-2021, 12:53 PM | #48 |
At the body shop.
And 73 -76 value would drop a bit.
And my power choices for this pos K5 would open up dramatically
03-26-2021, 01:01 PM | #49 |
Well my current plan is;
1) Wait to hear back from my local smog Ref to dial down exactly what my options are. 2) Hopefully find a compliant 2wd 6.0 or 6.2 with a six-speed automatic combo that fits in my GVWR window (8.5k - 10k) that I can start searching for a relatively low mileage one to purchase out of wrecking yard (how hard could that be???) 3) Get the OP Steve Van Gent, who is "only" three short hours north of me to come down for the weekends to help sort out the wiring BS.
03-26-2021, 02:08 PM | #50 |
Dedicated work and great write-up. Nice job SVG.
Tags |
smog engine swap ls |
