08-08-2019, 11:56 PM | #26 |
I'm trying....
Re: Makers marks on OEM bolts
Fuse panel screws. "GL" with a nice flower petal flange.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
09-11-2019, 10:37 PM | #27 |
I'm trying....
Door striker bolts. I think an important note is that these were sourced from a couple of different trucks from different assembly plants...all either '69 or '70.
09-12-2019, 09:22 AM | #28 |
Carpe manana
Aren't those pretty! Thanks for posting.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-12-2019, 11:14 AM | #29 |
The door striker plate bolts on my 71 are stamped "C". I do have an L5 bolt though, which is a 3/8"cotter pin bolt for the push rod to brake pedal assembly.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-21-2019, 05:02 PM | #30 |
I'm trying....
Tony-all 8 of striker plate bolts on our Blazer had the same triangles/grade lines (markings can be seen in pic), so I re-plated them and re-used them. She had had a hard life so there's no guarantee that they're original, I assumed they were (70 St. Louis Blazer FWIW). The L5s did come off different trucks. I was just looking for the best 8 bolts (least corrosion) to re-plate.
01-09-2021, 05:03 PM | #31 |
Carpe manana
Just wanted to give a shout out to the folks at Arrow Plating Co in Ft Worth, TX. I just received a batch of replated fasteners from them. Invoice was in the box, payment on the honor system.
It’s my second go round with Arrow and am very pleased. It may take a few weeks until they accumulate enough parts to run a batch so plan accordingly if you make use of their services. My first batch was returned in days. http://www.arrowplating.com/
01-09-2021, 09:58 PM | #32 |
I'm trying....
Thanks for the referral Pete. It won't be long before I'll be sending a few boxes their way. Definitely needed a new vendor in this area. Looks like you got good results.
