Re: 67 short step Daily driver build, 5.3 and 33s
Got the front clip off yesterday, it went well no broken bolts which I couldn’t hardly believe
![]() Got the front suspension and steering all pulled to make way for all the new stuff ![]() Got that all done then tore the oil pan back off the motor so that I could drill out the block for the new dip stick, did that then put the pan back on. Pulled the intake to make sure the valley cover wasn’t leaking oil, it wasn’t but it was disgusting under there so took about a hour cleaning and getting it ready for new gaskets ![]() |
On to the trans mount, reused the trail blazer mount and modified the factory crossmember to hold it also made it kinda skid like since it hangs down more than I would like
Bottom ![]() Top cut out so that the mount can move ![]() In the truck ![]() Overall to see how low it hangs, couldn’t do any better trans is just off the floor boards ![]() |
