11-11-2019, 06:42 PM | #26 |
Re: Rebuilding Engine
If you have all the electrical parts to make the 3 speed with OD work, do it. I love my 3 speed with OD, but it is definitely not a racing transmission. Great for highway cruising all day
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-12-2019, 03:23 AM | #27 |
I use a manual switch. I can switch it on in 2nd gear. I love doing 50 mph in 2nd. On flat ground I can use 1st locked up so I don't have to shift so much.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
11-13-2019, 02:17 PM | #28 |
I too love my 3 speed overdrive, hooked up with governor. Fun to drive.
What did you choose for a cam and are you keeping the 2bbl intake and carburetor? |
11-14-2019, 02:17 AM | #29 |
I think the cam has a 442 lift. Can't remember all the #'s. I have a stock 4 barrel Manifold I am going with. I will probably end up putting the 3 speed back in. I have some time to think about it plus, I don't know what the condition of the 700R4 is.
11-14-2019, 08:31 PM | #30 |
Just started on the heater and a picture of some extra stuff I have.
11-14-2019, 08:49 PM | #31 |
You can take that overdrive unit and put it on the back of a Saginaw four speed and have some fun. Just Sayin. It would not only teach the kid about shifting but how important gearing is. I wish they made overdrives for Muncies.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-17-2019, 10:29 PM | #32 |
I was going to use this Manifold. Just need a 4 barrel lower for my air cleaner.
11-18-2019, 12:09 AM | #33 |
Not a good intake to use unless you mod it.
That long slot on the front of the carb flange needs the holes on either end plugged off. Otherwise you’ll get excessive heat to the fuel bowl on your carb. And you need a gasket that has a metal plate to cover up the slot. Along with two thin base gaskets to seal the plate with. https://quadrajetparts.com/quadrajet...iac-p-375.html https://quadrajetparts.com/base-gask...965-p-106.html |
11-18-2019, 01:15 AM | #34 |
I also used that intake on my 283. I did the 68 base gasket that goes under the metal plate, stuck the metal plate on top of that, then put another gasket that wasn't for the "hot slot" manifold on top of the metal plate to help with sealing and act as a small insulator. I didn't plug the holes, but I haven't had any issues with it after over a year of driving the truck a lot.
For the air cleaner, I did this: http://67-72chevytrucks.com/vboard/s...&postcount=113 If you wanted to run a carb spacer, you could decrease the height of the air cleaner base by the amount of the spacer to clear the dizzy
11-18-2019, 02:56 PM | #35 |
Thanks I will take all that into consideration. And on another note, you know it must be bad if you're still leaking oil and there's no engine in the truck.
11-26-2019, 11:20 AM | #36 |
Was wondering what weight oil did you use as your break in.
11-26-2019, 08:22 PM | #37 |
Who Changed This?
For your area you should probably use 20 weight. If you are going with a flat tappet cam instead of a roller cam, be sure to use an additive during break in to avoid wiping out the cam. I've had good luck with the GM Super Engine Oil Supplement, but there are others out there.
12-04-2019, 04:08 PM | #38 |
Just adjusted the valves. It is slow going.
12-16-2019, 01:12 PM | #39 |
After cleaning some of the frame I was rolling the truck back to its spot and heard some clunking in the front end and grab my pry bar and though it is loose ends so why not rebuild the front and also. Is a good time to do it
12-16-2019, 08:50 PM | #40 |
Who Changed This?
It'll be a lot more fun now than laying under it later! I'd say you got your money's worth out of that upper control arm bushing, too!
01-04-2020, 06:59 PM | #41 |
I finally got the front and back together. Found a Spring compressor at Napa of all places for cheaper than Amazon. Figure while I was at it might as well recover one of the seats I have until I get the stock seat cover for the original seat. I'm not quite done with the seat, I need some 1" foam as these cheap covers are bigger than the originals
01-04-2020, 08:34 PM | #42 |
Good work!
06-25-2020, 12:53 AM | #43 |
Finally put some paint on the engine today.
06-25-2020, 01:44 AM | #44 |
can you post a photo of the spring compressor you used? I'm also about to dive in to front end while I've got my engine out and my compressor tool (hook/bolt type) is ok for macpherson's but doesnt fit between the control arms well. I was considering building a 2x4's wall frame between the frame of the truck and the ceiling joists in my garage and then just using a floorjack under the lower CA, but would prefer to avoid having to patch-fill the holes in the drywall later.
06-25-2020, 11:18 AM | #45 | |
06-25-2020, 02:07 PM | #46 |
engine looks good! What did you use for paint? Is it from "The Filing Station"? looks like the correct color.
06-25-2020, 10:15 PM | #47 |
I went to the paint store with my oil pan which had some paint left on it and I matched it up to color samples. This can has the formula on it. Black primer underneath
06-27-2020, 10:01 AM | #48 |
700R4 is what i would do
06-27-2020, 11:38 AM | #49 |
I have a 700r4 in one of my trucks and it is a great tranny. However my truck was already an auto and still requires a fair amount of new skills to adjust correctly as well as the shifter and lockup mechanism etc. Not to mention if you do any one of these things incorrectly BOOM! You already have a desirable transmission (look on fleabay) and it is already set up for it. I say reseal it and drive that truck. Saginaws are also very easy to rebuild. No special tools at all. My kit was about $80. I have never driven a 3 speed with OD but I sure want to. I guess it really is a 5 or 6 speed when you think about it. And tough to beat the reliability as well as the cool factor not to mention the little brats can't drive it if they try to steal it BWAHAHA!
06-28-2020, 02:31 AM | #50 |
I have a 700R4 in one of my trucks already. I
am just torn on what I want to do.
