Old 05-29-2023, 07:15 PM   #26
Lugnutz65
Lugnutz65's Avatar
Re: Steering column rebuild kit, anyone make them?
Originally Posted by 68-Mike View Post
I think I've got my column apart as far as I want to take it. Parts on order for the rebuild. Currently cleaning/painting the core parts.
One last question regarding a foam seal that is on the lower end of the shift tube. It's about to fall apart. Haven't tried to pull it off yet. Has anyone found any replacements for this? What' the downside of removing and not replacing?
Thanks!!
That’s a grease seal and should be made of thick felt. You can buy felt at a fabric store and replace your felt seal easily. Just coil the new felt around that same area until the diameter builds up to be the same as the ID of the tube. Then add grease to the felt to get it saturated. That will create a seal that keeps trash out trash.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
